Topic: open foobar and have an empty playlist? (Read 3454 times) previous topic - next topic
Hi again.
everytime I open foobar I see the track's list of the last album played.
There's a way to open foobar and have an empty playlist?
thanx
Since whatever playlist played, its the default behaviour of the playlist to save it. So, i guess there isn't such option, or may be
there could be other playlist viewer which could provide such functionality.
first of all, I'm sorry for the wrong title, but my english is very bad.
anyway... if there's no option to clear the playlist, I'll keep it that way.
thanx
You can try this Command line setting
or you can look here  Foobar2000 Components and scroll down to foo_ playlistclear.  good luck
Hi rockberto,
have you tried the first suggestion in tpijags post?
It works without any component and does exactly what you want.
Hi rockberto,
Hi, yeh its working with album list, but not with facets.
[!--sizeo:3--][span style=\"font-size:12pt;line-height:100%\"][!--/sizeo--]foobar2000.exe.cmd — Start foobar2000 with a blank new playlist (using a Batch file)[/size][/font]
@ECHO OFF
COLOR 1F
MODE CON:COLS=82 LINES=11
PUSHD "%~dp0"
TITLE [foobar2000.exe.cmd]  "%CD%\foobar2000.exe" /command:"New Playlist"
ECHO.
ECHO   +----------------------------------------------+
ECHO   ^|  Start foobar2000 with a blank new playlist  ^|
ECHO.
ECHO.
ECHO   press any key to continue  (or CTRL+C to abort)
ECHO.
ECHO.
PAUSE > NUL
START "" "%CD%\foobar2000.exe" /command:"New playlist"
POPD
EXIT
===========================  M Y  N O T E S  ==================================
To use this batch file:
Name it "foobar2000.exe.cmd", and copy it to same location as foobar2000.exe,
and launch it directly or from a shortcut.
References:
"http://wiki.hydrogenaudio.org/index.php?title=Foobar2000:Commandline_Guide"
"http://www.hydrogenaudio.org/forums/index.php?showtopic=93219"
:EOF
