Topic: foo_seek.dll Usage (Read 1257 times) previous topic - next topic
  • spockman
  • Members (Donating)
foo_seek.dll Usage
OK, I've started a new topic here as I just realised my previous post was in the wrong forum (Uploads - fb2k) - see here
From grimes' replies:
loop length is predefined for 6,8,10,12,14,16,18,20 seconds.
How/where is this predefined?  How do I change the value?
Alternatively set endpoint mode, seek to start point in seekbar manually, wait for x seconds and set end point by shortcut.
How exactly do I set endpoint mode and how do I set the end point?  I can't find any shortcut(s) for this.
an example for first mode:
    Enable loop length 6s
    Enable "loop" (by shortcut)
    Seek to a start point in seekbar
To enable loop length of 6s do I need to go through Advanced Preferences or is there another way?
Thanks very much for your help.
Spockman
  • grimes
foo_seek.dll Usage
Menu | Playback | Seek Control | Loop length
You can assign shortcuts in Preferences | Keyboard Shortcuts
The relevant commands are "Set end point" and "Remove end point" in Loop length submenu.
Yes.
  • Last Edit: 27 January, 2012, 07:58:12 PM by grimes
  • spockman
foo_seek.dll Usage
I don't seem to have the 'Menu | Playback | Seek Control | Loop length' option in my menu.  See attached screenshot.
Nor can I find the 'Set end point' and 'Remove end point' in the Preferences | Keyboard Shortcuts section.
foo_seek.dll Usage
Are you sure to have installed the latest version of foo_seek?
This component has already its own thread: http://www.hydrogenaudio.org/forums/index....showtopic=89964
german support forum: www.foobar-users.de / user: qwert73
  • spockman
foo_seek.dll Usage
[quote name='q-stankovic' date='Jan 28 2012, 09:07' post='783973']
Arrrhhh!  Got my 1.0 and 0.1 mixed up.  That's done the trick.  Humblest apologies.
Spockman.
