Topic: Joint Stereo & Stereo (Read 7219 times) previous topic - next topic
  • topaz
I have the need to rip music from CD to mp3, but the question I have is when I rip to lame mp3 should I use the joint stereo or stereo setting for the rip?
Reason for asking is that once I have ripped I then join the files together as one whole mp3 which can be over an hour long, and I then have multiple files burned onto a DVD in order to play on my DVD player with a particular image on screen,but I noticed that if I have my TV audio set to whatever the sound on certain tracks sounds like some instruments are being muffled and or missing, and I wondered if this was because I was using the wrong setting being JS or just Stereo.
Any help much appreciated, any other info please let me know.
Regards
I am what I am.
  • tpijag
  • topaz
I am what I am.
  • probedb
If you use the standard presets shown in the Wiki you wouldn't have to worry, it'll use what it needs to.
  • topaz
Many thanks, will read through it.
  • Last Edit: 20 January, 2012, 05:27:54 AM by topaz
I am what I am.
  • mjb2006
  • topaz
As I wanted to have the latest LAME 3.99.3 I have downloaded it and extracted it to a folder I have made called LAME 3.99.3.
Can someone let me know what I need to do now so that this version will work on dampower or mediamonkey etc?
I am what I am.
  • topaz
When I downloaded the Lame 3.99.3 and extracted it there are many files, and unsure which one I should copy and paste into an encoder program if any.
I am what I am.
  • tpijag
Sounds like you downloaded the source code. Unless you plan to compile it yourself, you should be grabbing a ready to use version.
http://www.rarewares.org/mp3.php
  • Last Edit: 20 January, 2012, 10:00:40 AM by tpijag
  • topaz
I forgot to mention that I am using a very old system in 98 although I use KernelEx allowing me to use some progs that are normally not allowed on older systems.
I tried the lame_enc.dll (3.99.3) modified to use INI File Setup: and after deleting the older lame driver and replacing it with the newer the conversions were incorrect in that the time length showed as double and some would only convert half the size so say an mp3 was 2mins it would show as 1 min and play at twice the speed.
I am wondering if this is down to the system I use as per above and perhaps I should only use lame 3.98.
The lame I use due to system limitation for dBpowerAMP is Lame Version 3.93.1 (Dibrom's switches) and on Media Monkey it's 3.98
  • Last Edit: 20 January, 2012, 11:07:48 AM by topaz
I am what I am.
