Topic: Plextor PX-L890UE for CD burning (Read 4257 times) previous topic - next topic
Hello, all. Just ordered a Plextor PX-L890 external burner to replace my Iomega Super DVD Writer.
Has anyone had an experience with the PX-L890? I know Plextor has rebadged Lite-On machines for several years, so perhaps someone can offer an update on how these have performed in the last two years or so.
My setup:
Music stored on HP laptop, purchased new in 2007. Windows XP - Service Pack 3
Nero 8 Essentials for burning
Currently I use my Iomega for burning only; I rip with the laptop's Acer drive. When I get the Plextor, I intend to both rip and burn with that drive.
Most of my music files are WMA @ 192 kpbs
Use Verbatim CD-Rs, typically Digital Vinyl on discs given to others, Shiny Silver for myself
Hmm. Nobody has one of these, eh? Didn't find anything on ClubMyce, either. Oh well. Guess I'll find out soon enough.
Okay. Last entry in this attempted thread. Log from my first CD burn with the L890UE.
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 9.4.39.100
Internal Version: 9, 4, 39, 100
(Nero Express)
Recorder:            <PLEXTOR DVDR  PX-L890UE>Version: 1.03 - HA 1 TA 3 - 9.4.39.100
Adapter driver:      <USB 2.0>                HA 1
Drive buffer  :      1536kB
Bus Type      :      via Inquiry data
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM:              <HL-DT-ST DVDRAM GSA-T20N >Version: WC05 - HA 1 TA 0 - 9.4.39.100
Adapter driver:      <IDE>                    HA 1
=== Scsi-Device-Map ===
CdRomPeripheral      : HL-DT-ST DVDRAM GSA-T20N        atapi Port 0 ID 0  DMA: On
DiskPeripheral      : WDC WD1600BEVT-60ZCT0          iaStor Port 2 ID 0  DMA: On
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-T20N  D:  CdRom0
PLEXTOR DVDR  PX-L890UE  E:  CdRom3
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE          : 0
Physical memory    : 2038MB (2087276kB)
Free physical memory: 848MB (869208kB)
Memory in use      : 58 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
Check supported media : Disabled (0)
24.1.2012
Audio CD
1:44:52 AM   #1 Text 0 File SCSIPTICommands.cpp, Line 433
   LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
1:44:53 AM   #2 CDADOC -1 File Cdadoc.cpp, Line 1586
   Audio item log info:
   Audio document burn settings:
   Burn mode: DAO,
   CD Text: On,
   Cache disk or network files: No,
   Cache small files: No,
   Cache files smaller than 65536 bytes.
   Audio Multisession: No
   List of audio tracks:
   Track 01: Length: 03:50.08, Pause frames: 150, Filters: 1, Name: '13 Main Title.wma'.
   Track 02: Length: 01:26.28, Pause frames: 150, Filters: 1, Name: '26 On The Way To San Mateo.wma'.
   Track 03: Length: 03:08.20, Pause frames: 150, Filters: 1, Name: '10 Once a Thief (Instrumental).wma'.
   Track 04: Length: 04:01.26, Pause frames: 150, Filters: 1, Name: '10 Sphyros.wma'.
   Track 05: Length: 07:18.60, Pause frames: 150, Filters: 1, Name: '11 Los Bandidos.wma'.
   Track 06: Length: 06:19.27, Pause frames: 150, Filters: 1, Name: '01 The Clan.wma'.
   Track 07: Length: 02:41.42, Pause frames: 150, Filters: 1, Name: '02 Hurt So Bad.wma'.
   Track 08: Length: 04:08.65, Pause frames: 150, Filters: 1, Name: '07 Nessa.wma'.
   Track 09: Length: 06:46.17, Pause frames: 150, Filters: 1, Name: '03 Unit 7.wma'.
   Track 10: Length: 04:00.62, Pause frames: 150, Filters: 1, Name: '05 Out Front.wma'.
   Track 11: Length: 07:32.20, Pause frames: 150, Filters: 1, Name: '09 Pensativa.wma'.
   Track 12: Length: 05:55.62, Pause frames: 150, Filters: 1, Name: '04 Easterly Winds.wma'.
   Track 13: Length: 04:47.24, Pause frames: 150, Filters: 1, Name: '02 Latina.wma'.
   Track 14: Length: 06:04.34, Pause frames: 150, Filters: 1, Name: '05 Dracula.wma'.
   Track 15: Length: 04:36.72, Pause frames: 150, Filters: 1, Name: '08 Malcolm X.wma'.
   Track 16: Length: 06:19.51, Pause frames: 150, Filters: 1, Name: '01 Teonova.wma'.
   Total size: 79:30.18
1:44:53 AM   #3 Text 0 File Burncd.cpp, Line 3317
   BURN-Proof activated
1:44:53 AM   #4 Text 0 File AudioCompilationImpl.cpp, Line 838
   DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
   DRM: Beginning burn process.
1:44:53 AM   #5 Text 0 File Burncd.cpp, Line 3649
   Turn on Disc-At-Once, using CD-R/RW media
1:44:53 AM   #6 Text 0 File DlgWaitCD.cpp, Line 313
   Last possible write address on media:  359843
   Last address to be written:            357617
1:44:53 AM   #7 Text 0 File DlgWaitCD.cpp, Line 325
   Write in overburning mode: NO (enabled: CD)
1:44:53 AM   #8 Text 0 File DlgWaitCD.cpp, Line 2845
   Recorder: PLEXTOR DVDR  PX-L890UE;
     CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
     ATIP Data:
       Special    Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
       Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
1:44:53 AM   #9 Text 0 File DlgWaitCD.cpp, Line 500
   >>> Protocol of DlgWaitCD activities: <<<
1:44:53 AM   #10 Text 0 File ThreadedTransferInterface.cpp, Line 739
   Setup items (after recorder preparation)
    0: TRM_AUDIO_NOPRE (13 Main Title.wma)
       2 indices, index0 (150) not provided
       original disc pos #0 + 17258 (17258) = #17258/3:50.8
       relocatable, disc pos for caching/writing not required/not required
       -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17258 blocks [E: PLEXTOR DVDR  PX-L890UE]
    1: TRM_AUDIO_NOPRE (26 On The Way To San Mateo.wma)
       original disc pos #0 + 6478 (6478) = #6478/1:26.28
       -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 6478 blocks [E: PLEXTOR DVDR  PX-L890UE]
    2: TRM_AUDIO_NOPRE (10 Once a Thief (Instrumental).wma)
       original disc pos #0 + 14120 (14120) = #14120/3:8.20
       -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14120 blocks [E: PLEXTOR DVDR  PX-L890UE]
    3: TRM_AUDIO_NOPRE (10 Sphyros.wma)
       original disc pos #0 + 18101 (18101) = #18101/4:1.26
       -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18101 blocks [E: PLEXTOR DVDR  PX-L890UE]
    4: TRM_AUDIO_NOPRE (11 Los Bandidos.wma)
       original disc pos #0 + 32910 (32910) = #32910/7:18.60
       -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 32910 blocks [E: PLEXTOR DVDR  PX-L890UE]
    5: TRM_AUDIO_NOPRE (01 The Clan.wma)
       original disc pos #0 + 28452 (28452) = #28452/6:19.27
       -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 28452 blocks [E: PLEXTOR DVDR  PX-L890UE]
    6: TRM_AUDIO_NOPRE (02 Hurt So Bad.wma)
       original disc pos #0 + 12117 (12117) = #12117/2:41.42
       -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12117 blocks [E: PLEXTOR DVDR  PX-L890UE]
    7: TRM_AUDIO_NOPRE (07 Nessa.wma)
       original disc pos #0 + 18665 (18665) = #18665/4:8.65
       -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18665 blocks [E: PLEXTOR DVDR  PX-L890UE]
    8: TRM_AUDIO_NOPRE (03 Unit 7.wma)
       original disc pos #0 + 30467 (30467) = #30467/6:46.17
       -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 30467 blocks [E: PLEXTOR DVDR  PX-L890UE]
    9: TRM_AUDIO_NOPRE (05 Out Front.wma)
       original disc pos #0 + 18062 (18062) = #18062/4:0.62
       -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18062 blocks [E: PLEXTOR DVDR  PX-L890UE]
   10: TRM_AUDIO_NOPRE (09 Pensativa.wma)
       original disc pos #0 + 33920 (33920) = #33920/7:32.20
       -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 33920 blocks [E: PLEXTOR DVDR  PX-L890UE]
   11: TRM_AUDIO_NOPRE (04 Easterly Winds.wma)
       original disc pos #0 + 26687 (26687) = #26687/5:55.62
       -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 26687 blocks [E: PLEXTOR DVDR  PX-L890UE]
   12: TRM_AUDIO_NOPRE (02 Latina.wma)
       original disc pos #0 + 21549 (21549) = #21549/4:47.24
       -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21549 blocks [E: PLEXTOR DVDR  PX-L890UE]
   13: TRM_AUDIO_NOPRE (05 Dracula.wma)
       original disc pos #0 + 27334 (27334) = #27334/6:4.34
       -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 27334 blocks [E: PLEXTOR DVDR  PX-L890UE]
   14: TRM_AUDIO_NOPRE (08 Malcolm X.wma)
       original disc pos #0 + 20772 (20772) = #20772/4:36.72
       -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20772 blocks [E: PLEXTOR DVDR  PX-L890UE]
   15: TRM_AUDIO_NOPRE (01 Teonova.wma)
       original disc pos #0 + 28476 (28476) = #28476/6:19.51
       -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 28476 blocks [E: PLEXTOR DVDR  PX-L890UE]
1:44:54 AM   #11 Text 0 File ThreadedTransferInterface.cpp, Line 941
   Prepare [E: PLEXTOR DVDR  PX-L890UE] for write in CUE-sheet-DAO
   DAO infos:
    MCN: ""
    TOCType: 0x00; Session Closed, disc fixated
    Tracks 1 to 16:                                  Idx 0        Idx 1      Next Trk
     1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos            0        352800      40943616, ISRC ""
     2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos      40943616      41296416      56532672, ISRC ""
     3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos      56532672      56885472      90095712, ISRC ""
     4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos      90095712      90448512    133022064, ISRC ""
     5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos    133022064    133374864    210779184, ISRC ""
     6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos    210779184    211131984    278051088, ISRC ""
     7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos    278051088    278403888    306903072, ISRC ""
     8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos    306903072    307255872    351155952, ISRC ""
     9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos    351155952    351508752    423167136, ISRC ""
     10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos    423167136    423519936    466001760, ISRC ""
     11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos    466001760    466354560    546134400, ISRC ""
     12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos    546134400    546487200    609255024, ISRC ""
     13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos    609255024    609607824    660291072, ISRC ""
     14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos    660291072    660643872    724933440, ISRC ""
     15: TRM_AUDIO_NOPRE, 2352/0x00, FilePos    724933440    725286240    774141984, ISRC ""
     16: TRM_AUDIO_NOPRE, 2352/0x00, FilePos    774141984    774494784    841470336, ISRC ""
   DAO layout:
    ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
       -150 |  lead-in |  0 |    0x01 |        0 |        0 | 0x00
       -150 |        1 |  0 |    0x21 |        0 |        0 | 0x00
           0 |        1 |  1 |    0x21 |    17258 |        0 | 0x00
       17258 |        2 |  0 |    0x21 |        0 |        0 | 0x00
       17408 |        2 |  1 |    0x21 |    6478 |    17408 | 0x00
       23886 |        3 |  0 |    0x21 |        0 |        0 | 0x00
       24036 |        3 |  1 |    0x21 |    14120 |    24036 | 0x00
       38156 |        4 |  0 |    0x21 |        0 |        0 | 0x00
       38306 |        4 |  1 |    0x21 |    18101 |    38306 | 0x00
       56407 |        5 |  0 |    0x21 |        0 |        0 | 0x00
       56557 |        5 |  1 |    0x21 |    32910 |    56557 | 0x00
       89467 |        6 |  0 |    0x21 |        0 |        0 | 0x00
       89617 |        6 |  1 |    0x21 |    28452 |    89617 | 0x00
     118069 |        7 |  0 |    0x21 |        0 |        0 | 0x00
     118219 |        7 |  1 |    0x21 |    12117 |  118219 | 0x00
     130336 |        8 |  0 |    0x21 |        0 |        0 | 0x00
     130486 |        8 |  1 |    0x21 |    18665 |  130486 | 0x00
     149151 |        9 |  0 |    0x21 |        0 |        0 | 0x00
     149301 |        9 |  1 |    0x21 |    30467 |  149301 | 0x00
     179768 |      10 |  0 |    0x21 |        0 |        0 | 0x00
     179918 |      10 |  1 |    0x21 |    18062 |  179918 | 0x00
     197980 |      11 |  0 |    0x21 |        0 |        0 | 0x00
     198130 |      11 |  1 |    0x21 |    33920 |  198130 | 0x00
     232050 |      12 |  0 |    0x21 |        0 |        0 | 0x00
     232200 |      12 |  1 |    0x21 |    26687 |  232200 | 0x00
     258887 |      13 |  0 |    0x21 |        0 |        0 | 0x00
     259037 |      13 |  1 |    0x21 |    21549 |  259037 | 0x00
     280586 |      14 |  0 |    0x21 |        0 |        0 | 0x00
     280736 |      14 |  1 |    0x21 |    27334 |  280736 | 0x00
     308070 |      15 |  0 |    0x21 |        0 |        0 | 0x00
     308220 |      15 |  1 |    0x21 |    20772 |  308220 | 0x00
     328992 |      16 |  0 |    0x21 |        0 |        0 | 0x00
     329142 |      16 |  1 |    0x21 |    28476 |  329142 | 0x00
     357618 | lead-out |  1 |    0x01 |        0 |        0 | 0x00
1:44:54 AM   #12 Phase 9 File dlgbrnst.cpp, Line 1802
   Prepare audio writing
1:45:34 AM   #13 Phase 12 File dlgbrnst.cpp, Line 1802
   Finishing
1:45:44 AM   #14 Text 0 File SCSIPTICommands.cpp, Line 246
   Error on LockVolume: Access is denied.
1:45:44 AM   #15 Text 0 File Burncd.cpp, Line 4479
   Caching options: cache CDRom or Network-No, small files-No (<64KB)
1:45:44 AM   #16 Phase 36 File dlgbrnst.cpp, Line 1802
   Burn process started at 16x (2,400 KB/s)
1:45:44 AM   #17 Text 0 File ThreadedTransferInterface.cpp, Line 2695
   Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
1:45:44 AM   #18 Text 0 File ThreadedTransferInterface.cpp, Line 2695
   Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #17408
1:45:44 AM   #19 Text 0 File ThreadedTransferInterface.cpp, Line 2695
   Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #24036
1:45:44 AM   #20 Text 0 File ThreadedTransferInterface.cpp, Line 2695
   Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #38306
1:45:44 AM   #21 Text 0 File ThreadedTransferInterface.cpp, Line 2695
   Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #56557
1:45:44 AM   #22 Text 0 File ThreadedTransferInterface.cpp, Line 2695
   Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #89617
1:45:44 AM   #23 Text 0 File ThreadedTransferInterface.cpp, Line 2695
   Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #118219
1:45:44 AM   #24 Text 0 File ThreadedTransferInterface.cpp, Line 2695
   Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #130486
1:45:44 AM   #25 Text 0 File ThreadedTransferInterface.cpp, Line 2695
   Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #149301
1:45:44 AM   #26 Text 0 File ThreadedTransferInterface.cpp, Line 2695
   Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #179918
1:45:44 AM   #27 Text 0 File ThreadedTransferInterface.cpp, Line 2695
   Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #198130
1:45:44 AM   #28 Text 0 File ThreadedTransferInterface.cpp, Line 2695
   Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #232200
1:45:44 AM   #29 Text 0 File ThreadedTransferInterface.cpp, Line 2695
   Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #259037
1:45:44 AM   #30 Text 0 File ThreadedTransferInterface.cpp, Line 2695
   Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #280736
1:45:44 AM   #31 Text 0 File ThreadedTransferInterface.cpp, Line 2695
   Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #0): write at #308220
1:45:44 AM   #32 Text 0 File ThreadedTransferInterface.cpp, Line 2695
   Verifying disc position of item 15 (relocatable, no disc pos, no patch infos, orig at #0): write at #329142
1:45:44 AM   #33 Text 0 File MMC.cpp, Line 17516
   StartDAO : CD-Text - On
1:45:44 AM   #34 Text 0 File MMC.cpp, Line 21767
   Set BUFE: BURN-Proof -> ON , Adapt writespeed to disc : ON
1:45:44 AM   #35 Text 0 File MMC.cpp, Line 17746
   CueData, Len=272
   21 00 00 41 00 00 00 00
   21 01 00 00 00 00 00 00
   21 01 01 00 00 00 02 00
   21 02 00 00 00 03 34 08
   21 02 01 00 00 03 36 08
   21 03 00 00 00 05 14 24
   21 03 01 00 00 05 16 24
   21 04 00 00 00 08 1e 38
   21 04 01 00 00 08 20 38
   21 05 00 00 00 0c 22 07
   21 05 01 00 00 0c 24 07
   21 06 00 00 00 13 36 43
   21 06 01 00 00 13 38 43
   21 07 00 00 00 1a 10 13
   21 07 01 00 00 1a 12 13
   21 08 00 00 00 1c 3b 3d
   21 08 01 00 00 1d 01 3d
   21 09 00 00 00 21 0a 33
   21 09 01 00 00 21 0c 33
   21 0a 00 00 00 27 3a 44
   21 0a 01 00 00 28 00 44
   21 0b 00 00 00 2c 01 37
   21 0b 01 00 00 2c 03 37
   21 0c 00 00 00 33 24 00
   21 0c 01 00 00 33 26 00
   21 0d 00 00 00 39 21 3e
   21 0d 01 00 00 39 23 3e
   21 0e 00 00 00 3e 17 0b
   21 0e 01 00 00 3e 19 0b
   21 0f 00 00 00 44 1d 2d
   21 0f 01 00 00 44 1f 2d
   21 10 00 00 00 49 08 2a
   21 10 01 00 00 49 0a 2a
   01 aa 01 01 00 4f 1e 12
1:45:44 AM   #36 Text 0 File ThreadedTransfer.cpp, Line 273
   Pipe memory size 83836800
1:51:01 AM   #37 Text 0 File WriterStatus.cpp, Line 245
   <E: PLEXTOR DVDR  PX-L890UE> start writing Lead-Out at LBA 357618 (574F2h), length 0 blocks
1:51:13 AM   #38 Text 0 File DVDPlusDualLayer.cpp, Line 1452
   SetDriveCaps: Set LAST LBA of layer 1 to 0
1:51:13 AM   #39 Phase 37 File dlgbrnst.cpp, Line 1802
   Burn process completed successfully at 16x (2,400 KB/s)
1:51:13 AM   #40 Text 0 File AudioCompilationImpl.cpp, Line 863
   DRM: DRM burn session terminated.
1:51:13 AM   #41 Text 0 File AudioCompilationImpl.cpp, Line 892
   DRM: Closing entire DRM handling. Bye.
1:51:13 AM   #42 Text 0 File SCSIPTICommands.cpp, Line 297
   SPTI - Error 5 on DismountVolue: Access is denied.
1:51:13 AM   #43 Text 0 File Cdrdrv.cpp, Line 11601
   DriveLocker: UnLockVolume completed
1:51:13 AM   #44 Text 0 File SCSIPTICommands.cpp, Line 433
   UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
If your burns play fine on what ever your trying to play it on then there is nothing more to worry about.
Or am i missing something?
Not all users are satisfied with the performance of the Plextor PX-L890UE (external version) or with the PX-L890SA (internal version).
Some Audio CD's are not recognized AT ALL. There seems to be no fix yet. Complainers feel Plextor techn. dept. seems to let them down.
http://www.plextoramericas.com/index.php/f...=6&start=24
http://www.plextoramericas.com/index.php/f...t-protected-cds
I wasn't worried. I initially posted just to see if anyone else had any experience with the Plextor PX-L890UE. Subsequently it arrived, and I tried it out for the first time. It seems fine.
Well, the L890 seems to burn CDs reasonably well, but on this unit the Lightscribe function doesn't work. After being walked through various solutions, I keep getting the same error message saying that the drive has lost communication with my laptop.
Given Amazon's excellent return policy, I'm just not going to play games with this thing. I'm going to get a refund, and buy the LG GE24LU20 that has been recommended to me.
