Hi
I've ripped some CD (Dazzling Killmen - 'Face of Collapse') and EAC (1.0 beta 3) told me:
Exact Audio Copy V1.0 beta 3 from 29. August 2011
EAC extraction logfile from 14. January 2012, 23:53
Dazzling Killmen / Face of Collapse
Used drive : TEAC CD-W512EB Adapter: 1 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : No
Make use of C2 pointers : No
Read offset correction : 685
Overread into Lead-In and Lead-Out : No
Delete leading and trailing silent blocks : No
Null samples used in CRC calculations : Yes
Used interface : Native Win32 interface for Win NT & 2000
Gap handling : Not detected, thus appended to previous track
Used output format : User Defined Encoder
Selected bitrate : 1024 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files (x86)\FLAC\flac.exe
Additional command line options : --best --replay-gain -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%"
-T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" %source% -o %dest%
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 0:00.32 | 3:18.53 | 32 | 14934
2 | 3:19.10 | 5:46.60 | 14935 | 40944
3 | 9:05.70 | 1:29.47 | 40945 | 47666
4 | 10:35.42 | 5:52.30 | 47667 | 74096
5 | 16:27.72 | 2:08.18 | 74097 | 83714
6 | 18:36.15 | 4:44.30 | 83715 | 105044
7 | 23:20.45 | 13:58.42 | 105045 | 167936
8 | 37:19.12 | 4:51.40 | 167937 | 189801
Track 1
Filename C:\test\01. Staring Contest.wav
Peak level 100.0 %
Extraction speed 4.5 X
Track quality 100.0 %
Copy CRC 0FE338D9
Cannot be verified as accurate (confidence 4) [80402B7F], AccurateRip returned [C3CADD86] (AR v2)
Copy OK
Track 2
Filename C:\test\02. Bone Fragments.wav
Peak level 100.0 %
Extraction speed 7.0 X
Copy CRC 3C40F4B7
Cannot be verified as accurate (confidence 4) [5DDA0B22], AccurateRip returned [7DE2EC1F] (AR v2)
Copy OK
Track 3
Filename C:\test\03. My Lacerations.wav
Peak level 100.0 %
Extraction speed 6.6 X
Track quality 99.8 %
Copy CRC A71AE63D
Cannot be verified as accurate (confidence 4) [629B1A38], AccurateRip returned [8E3B976A] (AR v2)
Copy OK
Track 4
Filename C:\test\04. Blown (Face Down).wav
Peak level 100.0 %
Extraction speed 8.1 X
Copy CRC 26B6DEE4
Cannot be verified as accurate (confidence 4) [7BC5F09A], AccurateRip returned [9D1E9E38] (AR v2)
Copy OK
Track 5
Filename C:\test\05. Windshear.wav
Peak level 97.3 %
Copy CRC D1770805
Cannot be verified as accurate (confidence 4) [EEF8C853], AccurateRip returned [DF4DEAFD] (AR v2)
Copy OK
Track 6
Filename C:\test\06. Painless One.wav
Peak level 100.0 %
Extraction speed 9.0 X
Copy CRC 4391F36C
Cannot be verified as accurate (confidence 3) [044C84A4], AccurateRip returned [DF6F945C] (AR v2)
Copy OK
Track 7
Filename C:\test\07. In the Face of Collapse.wav
Peak level 100.0 %
Extraction speed 9.6 X
Copy CRC 6B8E251E
Cannot be verified as accurate (confidence 3) [9DEFD13E], AccurateRip returned [9473916D] (AR v2)
Copy OK
Track 8
Filename C:\test\08. Agitator.wav
Peak level 100.0 %
Extraction speed 9.3 X
Track quality 99.9 %
Copy CRC 1154EE8F
Cannot be verified as accurate (confidence 3) [BBC52D17], AccurateRip returned [F096E25B] (AR v2)
Copy OK
No tracks could be verified as accurate
You may have a different pressing from the one(s) in the database
No errors occurred
End of status report
Ok, so probably a different pressing.
Now, CueTools (2.1.2a) reports that:
[CUETools log; Date: 2012-01-14 23:55:37; Version: 2.1.2a]
Pregap length 00:00:32.
[CTDB TOCID: bycM8W5OU3i1LW.s8K0tnO.AQpA-] disk not present in database.
CUETools DB: discs with pregaps not supported in this protocol version.
[AccurateRip ID: 000b0ccf-004c57c9-5a09e208] found.
Track [ CRC ] Status
01 [22b9a807] (0/4) No match
02 [6d926b47] (0/4) No match
03 [9ae02225] (0/4) No match
04 [36ad9519] (0/4) No match
05 [07773ea9] (0/4) No match
06 [d7b0140b] (0/3) No match
07 [fdf2c3f4] (0/3) No match
08 [0b282caf] (0/3) No match
Offsetted by 727:
01 [c3cadd86] (4/4) Accurately ripped
02 [7de2ec1f] (4/4) Accurately ripped
03 [8e3b976a] (4/4) Accurately ripped
04 [9d1e9e38] (4/4) Accurately ripped
05 [df4deafd] (4/4) Accurately ripped
06 [df6f945c] (3/3) Accurately ripped
07 [9473916d] (3/3) Accurately ripped
08 [f096e25b] (3/3) Accurately ripped
Track Peak [ CRC32 ] [W/O NULL] [ LOG ]
-- 100,0 [F4F73CDA] [B90D9DAF]
01 100,0 [0FE338D9] [230405A6] CRC32
02 100,0 [3C40F4B7] [26C48A99] CRC32
03 100,0 [A71AE63D] [D347C191] CRC32
04 100,0 [26B6DEE4] [CAA60E05] CRC32
05 97,3 [D1770805] [89CCBD65] CRC32
06 100,0 [4391F36C] [44CC54BA] CRC32
07 100,0 [6B8E251E] [50CE7E26] CRC32
08 100,0 [1154EE8F] [29730525] CRC32
If I undestand correctly it tells me that the different pressing is +727, but overall my rip should be ok. Right?
I've re-ripped the CD using EAC and
a) an external TSSCORPCD/DVDW SH-S182M
b) some Optiarc BD
What is puzzling me is an output from CueTools
a) TSSCORPCD/DVDW SH-S182M
[CUETools log; Date: 2012-01-14 23:56:47; Version: 2.1.2a]
Offsetted by 727:
-- 100,0 [EB9F1908] [4D4CE60D]
08 100,0 [0E3CCB5D] [827C20B2]
b) Optiarc BD
[CUETools log; Date: 2012-01-14 23:58:12; Version: 2.1.2a]
Offsetted by 727:
-- 100,0 [BABF742A] [F3B1BEA4]
08 100,0 [5F1CA67F] [FB6ABD48]
Why CRC32 of the last track is different in every case?
a) TEAC 512EB - 1154EE8F
b) Samsung SH-S182M - 0E3CCB5D
c) Optiarc - 5F1CA67F
Shouldn't that mean that ripped data is different? But why CueTools reports the same result from AccurateRip?
