Topic: Converter feature: add ability to pass all/most titleformatting (Read 835 times) previous topic - next topic
  • kompot
Hello,
i've seen a request here that converter should allow embedding album art on the fly.
And recently I needed that myself. So pretty obvious way for an advanced user is to write a batch script and pass required params to it.
I wrote the following code that work quite well when called from command line like
convert.bat output.m4a < input.wav
but when I try to specify %path% as a third (%3) parameter - it just is not passed to external converter by foobar2000.
If some content tag is passed (like %album%) - everything goes well and I can get %3 in the script, but %path% doesn't work.
From the outside it seems like it should be really easy.
IF EXIST "%~d1%~p1front.jpg" (
) ELSE (
  SET COVER=cover-not-found
neroAacEnc.exe -q 0.46 -ignorelength -if "%1" -of "%2"
IF NOT %COVER% == "cover-not-found" (
  echo adding cover %COVER%
  rem neroAacTag.exe "%2" "-add-cover:front:%COVER%"
Any thoughts?
