Topic: How do I update LAME command line to new EAC’s parameter placeholders? (Read 4016 times) previous topic - next topic
  • hydrogenxx
hi, could somenone please write the lame command line option for the newest eac to be exactly like this below i used in the older version, i would be very very thankful:
"-V 0 --vbr-new --add-id3v2 --ignore-tag-errors --ta "%a" --tt "%t" --tg "%m" --tl "%g" --ty "%y" --tn "%n" %s %d"
ok, i tried to fill it in and hopefully this is ok:
"-V 0 --vbr-new --add-id3v2 --ignore-tag-errors --ta "%artist%" --tt "%title%" --tg "%genre%" --tl "%albumtitle%" --ty "%year%" --tn "%tracknr%" %source% %dest%"
  • Last Edit: 04 January, 2012, 10:08:56 AM by hydrogenxx
  • db1989
  • Global Moderator
That looks fine.
It also provides me with an opportunity to plug my own Knowledge base article: http://wiki.hydrogenaudio.org/index.php?ti...AC_placeholders
Isn't vbr-new the default meanwhile?
  • db1989
  • Global Moderator
Yes; good point. (I always overlook that!) So that could be removed.
  • hydrogenxx
I see, thanks... so, I'm changing it to:
"-V 0 --add-id3v2 --ignore-tag-errors --ta "%artist%" --tt "%title%" --tg "%genre%" --tl "%albumtitle%" --ty "%year%" --tn "%tracknr2%" %source% %dest%"
Oh, another thing, the latest lame.dll tab doesn't seem to show up anymore in the latest version of EAC, the compression options tabs... I have tried putting that same lastest lame.dll in a pre 1.0 EAC folder and the dll tab is there, but in the latest EAC it is not. Anyone knows anything about it maybe?
  • Last Edit: 05 January, 2012, 07:54:39 AM by hydrogenxx
  • pdq
Why would anyone want to use the dll when you can use the exe?
  • lvqcl
From News.rtf file in EAC folder:
LAME DLL produces defective, stuttering MP3s (bug exists since 1.0 beta 1!). By the way, it seems that only LAME.DLL (VC6 compiled) is compatible with EAC...
So it is better not to use it.
  • hydrogenxx
I was just interested in why (if) it didn't work anymore in EAC...
  • Last Edit: 05 January, 2012, 10:38:25 AM by hydrogenxx
