Topic: Q: improving sound of old .mp3 files by filtering artifacts? (Read 14774 times) previous topic - next topic
  • Porcus
Before shouting «no, you cannot know what has been deleted»: this is not about knowing, it is about guessing better than one could once upon a time in the previous millennium.
Back in the 90's, you could way more often than today single out an mp3 file by its artifacts (for given bitrate in suitable range
  • ). Of course we could not know without the original whether a certain signal is an encoding artifact or is part of the music, but back in those days we could fairly often make an educated guess by listening -- doing «ABX except without the A and B».
    So, the last 15 years have brought forth lossy encoders which are better at avoiding audible artifacts: Not only do we know better what to avoid, we also know better how to avoid it. And in principle, it might very well be possible to use this improved knowledge to (i) detect in an old mp3 file «what would have been avoided today», and (ii) filter it out. Not to achieve the impossible certainty that this part of the signal was not in the original source, but to achieve fewer audible nuissances more often than not.
    Q: Has this been attempted, successfully or not?
    (Any such tool could be easily testable if one has an old encoder and a lossless source and a few good ears.)
  • I presume that http://listening-tests.hydrogenaudio.org/s...8-1/results.htm should keep TOS#8 moderation off my back.
  • saratoga
How often do you have three or copies of the same track each from a different encoding?  Seems like even if this were possible you'd never actually have a use for it.
  • Porcus
No, I am talking of one. One old mp3 with artifacts we could by now know how to identify algorithimically and filter away in a way that more often than not results in an improvement.
  • saratoga
I assumed you mean A/Bing multiple samples to figure out what was an artifact.  If not, how exactly do you propose to figure out what is an artifact?  And what would you do about it?
  • MichaelW
I take it that what Porcus meant was that some kinds of sounds are characteristically artefacts of bad MP3 coders, so that if he hears, say, ringing in an old MP3 file, he doesn't for sure know it's an artefact, but he'll take the chance and remove it, if that is possible. It might have been deliberately introduced--you could only tell for sure by comparing--but he'd still like it gone. Would that be possible?
  • saratoga
How do you "remove" something without knowing what it sounds like?  Aside from muting the audio that is
Its rather hard to "remove" something that occurs due to missing information or excessive approximation.
  • nu774
  • Developer
Processing filters to remove encoding artifacts such as blocking, banding, ringing are rather common in video.
Of course lost information cannot be recovered. They are applied just to get better perceived quality...though they usually have unwanted side-effect, too (removing noise usually removes not only noises but also details).
OP might be thinking of something like that... just a guess.
  • Porcus
We know what it «sounds» like. I tried to explain that in fair detail in the original post, but again: even if we do not know for certain for every given sample that this particular property is an artifact or not, we know enough to guess better than 50/50 on real-world music (this for the relevant bitrange).
We also have knowledge about how to avoid it, given that we know the original. Again, not perfect knowledge, but fairly good knowledge -- this is the reason why you can encode a 1000 kbps FLAC file from CD into a 100 kbps mp3 file and still sounds ... if not transparent, so arguably superior to a random 90% removal of information.
And this knowledge has improved over the last 15 years. (Of course, Moore's law makes it harder to distinguish between improved knowledge and improved ability to utilize it.)
So then comes the question: has the science of psychoacoustics gotten us far enough to filter even without the exact original? We do not need to be able to filter everything -- it suffices that for a suitable percentage of low-bitrate files, it improves, and the rest it can leave untouched.
Good point. Another example is the crackle/pop removal algorithms for digitalization of vinyl. (And the good'ole subsonic filter on phono pre-amps.)
  • 2Bdecided
  • Developer
It's just an audio restoration challenge that (AFAIK) know one has really tackled yet. (IIRC creative claimed some of their sound cards did this, but I don't know if they really did).
When there's enough content that only exists as low-ish quality lossy audio that people want to re-issue in <tomorrow's new wonder audio format>, someone will come along and invent a process for making it sound better.
If it was me, I'd go after the splashy metallic artefacts that ruin the high frequencies first. Little idea how to though - most attempts to re-synthesize high frequencies sound pretty metallic themselves.
  • slks
I think one very crude way to do this could be to just use a lowpass filter. Indeed, some of the most annoying MP3 artifacts come from poorly-encoded high frequencies. You could add a lowpass filter at, say, 7 kHz and remove all the high-frequency content, and your audio might sound less artifacted. However, this assumes there aren't also artifacts in the lower frequencies (which is often the case with poor encodes). And you'd also be able to tell very apparently that the audio had been lowpassed, it'd sound like something recorded in the 1950s. Whether or not that sounds better than leaving the artifacted high freqs intact is entirely subjective.
I don't know much about the theoretical side of audio processing, FFTs and such, but it seems like removing MP3 artifacts would be very difficult, if not impossible, and the results would not be that great. Doesn't sound like something that would be worth someone's time to develop.
  • Gumboot
For badly encoded voice you might try recompressing it with a speech codec to see if that is forced to throw away some artefacts it considers unencodable.
  • Specy
I know this is an old thread, but I came to this forum today to ask something about this subject and found this thread.
I'm planning to try to make a filter like this. I'm pretty sure that it's possible - the only thing is that I don't have too much time to spend on this, so I'll give it a try for a few days to see how far I can get. Before I do that, I just want to check:
- Is there anything available like this now? I have searched, and only found this: http://www.fidelityamplifier.com/ , which seems to do a kinda fair job at restoring high frequencies after lowpass filtering, but it doesn't improve MP3s at all - actually it makes them sound worse due to what appears to be incorrect lowpass filter frequency detection.
- It would help to have a precise description of the type of MP3 artifacts that can occur. Some are obvious (holes in the spectrum which are probably related to the metallic sound, pre- and postringing - but it would be useful to know if there are exact times that they can assume (I know MP3 works with 1152 samples, but I don't know how big the overlap between blocks is, and it can also use a more fine-grained block size when needed). Also, different encoders with different settings might make different choices, so just encoding a bunch of files at low bitrates and analyzing them isn't sufficient to determine what's possible.
I know that many people are going to say that if data is gone you cannot restore it - just to show that I'm serious about this, 3 years ago I was tired of clipped audio on source material and created a declipper - see https://www.youtube.com/watch?v=oqOljvx9KaM . Right now, I'm tired of bad quality MP3s, so I want to try to do something similar for MP3 (and maybe also other lossy) audio. Because it's probably impossible to reliably detect MP3 artifacts (*) it will not be perfect - but it would really be nice if I could make MP3s sound a lot better.
(*) actually it might be. If I look at the spectrum in my own software, I see frequency ranges with absolute silence in low bitrate MP3 files, which I have never seen in uncompressed audio. But I think this won't help to detect pre/post ringing.
  • Last Edit: 19 April, 2014, 07:17:03 PM by Specy
  • J.Fleming
StereoTool now includes a filter that is exactly what is described in this thread.
However, it is still in the "experimental" stage.
To enable it, you have to set StereoTool to "Extreme Tweaker", and the filter appears in the StereoTool interface. It is called the "Delossifier." It is designed for filtering ringing from compressed audio.
  • Last Edit: 10 July, 2014, 03:24:59 AM by J.Fleming
  • Mach-X
I think the biggest problem with that idea is how to determine if the 'warbling' for example is intentional or not. IE is it intentional vibrato from a guitar amp or some electronic effect? Or is it a real mp3 artifact? Oh how many times I've chased THAT tail while abx'ing lossy codecs...
  • hightype
Just a heads-up on this topic, there is a shareware Photoshop plugin that cleans JPEG artifacts and does an amazing job at that (it's called Topaz DeJpeg) and has some before/after images at the bottom of their website: https://www.topazlabs.com/dejpeg
It does an amazing job and although I don't know this could be of any use at MP3 de-noising, but if JPEG images can be restored this effectively, it most probably can be done with MP3s too... and I'm also interested in any such software!
  • saratoga
Thats mostly just blending the transform blocks.
MP3 already takes care of that by using the MDCT.
  • Specy
Re: Q: improving sound of old .mp3 files by filtering artifacts?
That was just a thing that removes pre-ringing, but now it actually has a filter that reconstructs the spectrum. It's still called the 'Delossifier', but it now consists of 2 parts: Pre-ringing killer and Spectral Hole Filler. It's not perfect but it definitely makes the sound less annoying, mainly at lower bitrates.
  • nastea
Malware warning, Virustotal:
  • bennetng
Looks like false positive, detection rate is low and almost all of them are heuristic. I tried the VST version and attached a sample, the flac is processed with Delossifier.
  • bennetng
A 32kbps mp3 processed by Delossifier 20 times. Spectrophiles must love this plugin. BTW each time I processed it the volume also decreased a bit, don't know why.
  • knutinh
Let us assume that modern codecs represent the very state of the art in knowledge about how to recreate a piece of music in a way that is perceptually "believable" and "non-annoying" using a minimum amount of bits to transfer that information. If there is a way to (on average) improve the listening experience without transferring more information, new codecs would probably embrace that technology.
However, older codecs might not have had access to the current knowledge. Further, it seems fair to assume that 20 or 30 year old codecs would have been severly limited by the available processing power and memory.
So what if one used a state-of-the-art representation of human hearing (some auditory filter bank with masking etc) to analyze known references (CDs) as well as known "noisy" output (lossy compressed/decompressed versions using a given codec/parameters) using (trendy tool of the day) machine learning. Could such a black box "learn" something about systematic errors when judged on a subjectively sensible set of parameters?
Naiively, one might hope for a tool that _recognize_ Beethovens 5th symphony in a poor recording, at extremely low bitrate and _substitute_ it for a pristine recording. Somewhat less naiively, one might hope that subjectively important "structure" present in typical music, ignored/distorted by bad encoders could be fixed up?
-k
  • Last Edit: 21 September, 2016, 08:22:44 AM by knutinh
  • DVDdoug
Somebody told me you can digitize a vinyl record an upload it to iCloud and iTuned Match will replace the scratchy vinyl with the clean iTunes version.
But, that's not compression.  It's indexing.
