Topic: How do I create an Auto Playlist? (Read 27383 times) previous topic - next topic
How do I create an Auto Playlist? I looked around but haven't seen any answers.
I can create new playlists, but I don't see anywhere to create an auto playlist.
I have a "Recently Added" auto playlist, but when I copy it the copy is a normal playlist.
The playlist manager won't let me create them there either...
I'm using Columns UI if that's relevant.
Problem solved: Auto Playlists are created from
Library -> Album List -> (right click an album) -> Create Autoplaylist
How convoluted!
Autoplaylists are queries. A simple method to build a query is what you describe. Once you have a query result, the context menu is one click and selecting autoplaylist is one click.  In your opinion, what part of the two clicks = convoluted!
You can also build autoplaylists from simple to complex search strings. However, to inform foobar2000 that you would like the search result to be an autoplaylist does require the user to push a button and a click on autoplaylist. Alas, once again foiled by the pesky two clicks
How convoluted!
Not sure why you want to create an autoplaylist from an entire album when you can just send the album to a regular playlist.
It may seem convoluted at first but it is quite logical and the power/flexibility offered by the foobar2000 autoplaylist method really shines when you sort and filter the album list.
Do you want an autoplaylist of a particular artist? Sort the album list by artist, right the artist's name and create a simple unfiltered autoplaylist.
Adding filters really lets you fine tune. Say you want an autoplaylist of Rock that you added in the last two weeks; in the filter field enter:
%added% DURING LAST 2 WEEKS
Then sort the album list by genre, rick click Rock in the list and create the autoplaylist.
For all podcasts: genre IS podcast
Since you can sort/filter virtually any factor in your album list you can make an autoplaylist based on any criteria. This can even help to standardize the library.
For a list of all songs missing Replaygain track calculations: %replaygain_track_gain% MISSING
I use them to keep my tags as I want them. I prefer a filename convention of <disc number>-<track number>-<title>and most rips do not add a disc number so I have a playlist showing which tracks I have without a disc number with a filter:
%disc number% MISSING
So that I can masstag these to add a disc number, then use the file operations rename function to rename the files according to my standard. This comes in handy for music I purchase via Amazon or download from Magnatune.
