Topic: What is the best ADC equipment to rip my vinyls? I have Thorens TD-147 (Read 6950 times) previous topic - next topic
  • NRWler04
Gentlemen,
a few years ago i started with digital music. I have around 200 Vinyls and I want to Play them via my Linn Majik DS. I have a Thorens Td-147 and want to rip my Vinyls to 24/96 or Even better behause there are some really Nice MFSL's and direct cut's in my Collection.
What is the best ADC Equipment to rip my Vinyls?
Merry Christmas from Germany
  • pdq
Nearly any modern sound card, including most built-in cards, are adequate for the limited dynamic range of vinyl. What card do you have now?
  • db1989
  • Global Moderator
If you can provide any evidence that you or any other human can hear anything above about 20 kHz or 16 bits, and that vinyl records contain any meaningful frequencies beyond that and are capable of even 14 bits of dynamic range, then please let us know and feel free to rip at whatever quality you need! Otherwise you’ll just be wasting disk space and possible money, for the sake of the placebo effect.
You might want to search for the countless past threads about vinyl ripping, since it’s all been said before.
  • Last Edit: 25 December, 2011, 02:48:38 PM by db1989
  • hlloyge
Well, I would suggest using 24 bit / 48 kHz setting - your vinyls will be perfectly captured. I would suggest 24 bit just because you could do later edits with more precision (fadein, fadeout, some noise processing).
  • Xenion
44.1kHz is probably the best choice if you intend burning your vinyls on cd because you won't have to resample then.
If you're looking for some good software for restoration, click-repair, etc. check into iZotope RX2. It's not inexpensive however.
The Loudness War is over. Now it's a hopeless occupation.
  • NRWler04
I have a Reson RH1 for Recording my lp's. But the original LDP Sounds Better then the rip in cd Quality. That's the Reson why I'm Looping for a better Quality.
I tried a Juli soundcard, but i was Not satiesfied with the Result.
  • pdq
Could you be more specific? The problem may not be with the sound card. What does your setup look like? What kind of cartridge, what preamp, etc.?
  • ExUser
  • Read-only
I'm assuming this test was sighted, which means, of course, that it is inadmissible as a demonstration of audio quality around these parts.
What was your testing methodology?
I use E-MU for A/D to 24/192
Wavelab (24/192) > manual click removal
analyze (no clipping, no DC Bias offset) > resampling and dithering to 24/96 with iZotope RX
Goodluck
  • Last Edit: 26 December, 2011, 11:35:42 PM by TERIYAKI BUKKAKE
  • Gumboot
I can't say that I've tested a sound card recently, or that I've tested many sound cards, but on the one occasion I tried using one, thought it was terrible, and investigated, I found that with the input shorted to ground the card was picking up a constant tone near the top end of the spectrum and piles of other crap scattered around the rest.
Have things really changed so much in the past few years?
  • NRWler04
My TT is a Thorens TD147 with a Benz MC cartridge. My Amp is a Nytech Ca252/CXA252 with ARC050 Loudspeakers. I connected the Soundtrack to the line Out Connection of my Nytech.
I recorded in 24/96. MFSL's and Direct Cut's I could Not Record. I've got no clear signal, seem's to be to High the Lourdes Level.
The SW I Used was Audacity and Wavelab. Maybe I did something wrong ....
  • kraut
Are you saying the problems you have are only with the specified records, and not with others?
In audacity you have an input level indicator. Does it indicate too high an input level?
I ripped about 100 lp's with "spin it again". Given that the analogue signal enters my soundcard and will be digitized anyway even for normal listening (I run every audio signal through my server to the amps) I cannot distinguish between digitized and non digitized signal. I have however in the past compared a digitized lp analogue signal from the preamp with a direct signal and could not discern any quality differences. That is why I converted to using a computer as an audio tool.
  • Last Edit: 28 December, 2011, 09:11:03 AM by kraut
  • mixminus1
What is your sound card - built in to your PC's motherboard, PCI card, external USB...?
My guess is that you're plugging in to the mic input of your sound card, hence the level being too high and not "clear"...I've also seen some sound cards - primarily the onboard sound on several laptops - that have a "combo" mic/line input, but that can't really handle a true line-level input without distorting.
Edit: Just saw that you "tried" a Juli sound card - you should definitely be able to get good results with that, as it's a line-level only card designed specifically for recording.
  • Last Edit: 28 December, 2011, 12:38:07 PM by mixminus1
  • NRWler04
I have an Intel MB. DH57DD and today a DH67BL (or so ....;-)). I think they have a Realtek on Board.
Seem's, that I should trey the Juli more deeply ....
  • Last Edit: 28 December, 2011, 06:10:11 PM by db1989
