Topic: Converting to ALAC from FLAC (Read 11293 times) previous topic - next topic
I've been trying to figure this out: how does one convert to ALAC using the converter in FB2K v.1.1.10? I have some hi-res FLAC that I want to play on my ipod. I can't seem to find anything relating to M4A/lossless AAC in the converter component.
  • tpijag
converter dialog>highlight AAC in output file format>Select ADD NEW>Select Custom from Encoder drop down list> adjust settings, such as format = lossless >done
  • Last Edit: 11 December, 2011, 02:13:48 PM by tpijag
What are the different parameters I can adjust? Is there documentation for this?
Does this still apply? http://www.hydrogenaudio.org/forums//lofiv...php/t59294.html
  • tpijag
Documentation for ALAC? Have not the foggiest as I have never used it. I would check the wiki here or use Google. Imagine there is lots of info readily available.
  • lvqcl
1) Download refalac from http://sites.google.com/site/qaacpage/cabinet , current file is qaac_1.09.zip. Copy refalac.exe into foobar2000 folder.
2) Create new preset with the following settings:
Encoder: refalac.exe
Extension: m4a
Parameters: --silent --ignorelength - -o %d
Format: lossless (or hybrid)
Highest BPS: 24
Wow, thank you lvqcl!
One more question, I have a 64-bit version of Win7, but FB2K is x86, does it matter which refalac version (ie. x86 or x64) I use? And I used the parameters you recommended but is there a reference for settings? I found a little bit on that site link you posted, but it doesn't mention the "--silent" parameter.
  • Last Edit: 12 December, 2011, 09:18:02 AM by db1989
  • lvqcl
Yes, you can use refalac64, it's a bit faster than 32-bit version.
About parameters: http://sites.google.com/site/qaacpage/refalac-usage
refalac shares much of codes and functions with qaac
http://sites.google.com/site/qaacpage/usage
BTW, --no-optimize option can be also added to the parameters:
When you run qaac from some front-end like foobar2000, or always edit metadata or something after encoding, they will also touch MP4 container, so you might not need this optimization by qaac.
Thanks again!
