Topic: Apple Lossless = Varying Bits (Read 2418 times) previous topic - next topic
When I click on information in iTunes to see the bit rate of the song, I see different rates. One song has, say, 850kb, another 76-, and so on.
Why does this make sense?
  • greynol
  • Global Moderator
Bit rates are different because songs are different.  You should be concerned if it wasn't this way.
Knowing that lossless is lossless, it really shouldn't matter.
  • saratoga
http://en.wikipedia.org/wiki/Data_compress...dio_compression
  • db1989
  • Global Moderator
What makes sense is doing even the most basic research about a concept if it has a feature that you do not understand. Closing thread.
