hi, im new here really, and hope im posting this in the right place.a long time ago, i ripped some cd's with eac, accurate rip enabled etc.now i have finally seen the light and started using foobar2000, and have casually been checking my albums against the accurate rip database as i play them.there's some different results coming up, i think maybe with albums only i have submitted to the database.
ill post some logs below so it is easy to see what is happening.
eac log
Exact Audio Copy V1.0 beta 1 from 15. November 2010
EAC extraction logfile from 18. May 2011, 17:46
Cinema 90 / The Sunny Juice EP
Used drive : TEAC DV-W28S-RT Adapter: 1 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 48
Overread into Lead-In and Lead-Out : No
Delete leading and trailing silent blocks : No
Null samples used in CRC calculations : Yes
Used interface : Native Win32 interface for Win NT & 2000
Gap handling : Appended to previous track
Used output format : User Defined Encoder
Selected bitrate : 768 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files\Exact Audio Copy\FLAC\FLAC.EXE
Additional command line options : -8 -V -T "ARTIST=%a" -T "TITLE=%t" -T "ALBUM=%g" -T "DATE=%y" -T "TRACKNUMBER=%n" -T "TOTALTRACKS=%x" -T "GENRE=%m" -T "ALBUM ARTIST=%v" -T "ALBUMARTIST=%v" -T "COMMENT=EAC V1.0 Beta 1, Secure Mode, Test & Copy, AccurateRip
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 0:00.00 | 5:05.40 | 0 | 22914
2 | 5:05.40 | 3:07.15 | 22915 | 36954
3 | 8:12.55 | 4:05.00 | 36955 | 55329
4 | 12:17.55 | 4:50.06 | 55330 | 77085
5 | 17:07.61 | 4:46.61 | 77086 | 98596
Track 1
Filename C:\EAC\01 - So Sweet feat. Karin Bettley & Billy Fluid.wav
Pre-gap length 0:00:02.00
Peak level 98.0 %
Extraction speed 3.0 X
Track quality 100.0 %
Test CRC 894DA3E3
Copy CRC 894DA3E3
Track not present in AccurateRip database
Copy OK
Track 2
Filename C:\EAC\02 - Sunny Day Juice feat. T-Minus.wav
Peak level 98.0 %
Test CRC 4F44551D
Copy CRC 4F44551D
Copy OK
Track 3
Filename C:\EAC\03 - World You Are feat. Mimsy Cable.wav
Peak level 98.0 %
Extraction speed 3.3 X
Test CRC 3CA7BA84
Copy CRC 3CA7BA84
Copy OK
Track 4
Filename C:\EAC\04 - Feel The Sun.wav
Peak level 98.0 %
Extraction speed 3.7 X
Test CRC 524FA02D
Copy CRC 524FA02D
Copy OK
Track 5
Filename C:\EAC\05 - You And I feat. Clare Simmons.wav
Peak level 98.0 %
Extraction speed 3.9 X
Test CRC E7EB3835
Copy CRC E7EB3835
Copy OK
None of the tracks are present in the AccurateRip database
No errors occurred
End of status report
==== Log checksum 70CA3AF36E4536FD1FCEBEEC9277995C26BC21CC420E1E478833EB88B703D568 ====
now the results when i check the same rip via cuetools
[CUETools log; Date: 8/11/2011 6:31:49 a.m.; Version: 2.1.2a]
[CTDB TOCID: B7vD_1MG77.z3vR1rjbXMzNKKUY-] disk not present in database.
[AccurateRip ID: 00047043-0014ad14-3c052205] found.
Track [ CRC ] Status
01 [1c2ca684] (0/1) No match but offset
02 [eb6607f3] (0/1) No match but offset
03 [f6212915] (0/1) No match but offset
04 [2189c326] (0/1) No match but offset
05 [e1f5a662] (0/1) No match but offset
AccurateRip v2:
01 [ea8f55c3] (1/1) Accurately ripped
02 [67dffa40] (1/1) Accurately ripped
03 [6ddfc198] (1/1) Accurately ripped
04 [2eb59afd] (1/1) Accurately ripped
05 [09c6db4a] (1/1) Accurately ripped
Track Peak [ CRC32 ] [W/O NULL] [ LOG ]
-- 98.0 [BCCB8EDF] [C547F288]
01 98.0 [894DA3E3] [2102CFDC] CRC32
02 98.0 [4F44551D] [C4585C85] CRC32
03 98.0 [3CA7BA84] [1D580CF5] CRC32
04 98.0 [524FA02D] [1EC4AB60] CRC32
05 98.0 [E7EB3835] [C072ABBA] CRC32
now with the accurate rip check in foobar
Track Status
01 NOT ACCURATE even with offset: 0(1).
02 NOT ACCURATE even with offset: 0(1).
03 NOT ACCURATE even with offset: 0(1).
04 NOT ACCURATE even with offset: 0(1).
05 NOT ACCURATE even with offset: 0(1).
these checks are all done on the same files that i ripped originally in the eac log, does foobar do something differently than other programs, or maybe because i am only person who has submitted this rip is the problem somehow?
thanks for any help here, it is appreciated
