Topic: extract dts from iso (Read 10051 times) previous topic - next topic
hi guys,
how can I extract - convert dts-5.1 files from iso?
I have an iso (Sony PS3 SACD to ISO | DST 1bit-2822,4kHz 2.0, 5.1 | 3.58GB ) ripped file, from which
I want to extract dts single files, ...but:
1. I can't mount it through daemon tools ---> error
2. I can't open it with powerIso ---> error
I can only open it with foobar2000, but even though I have installed dts decoder, it converts it in stereo (wav) files.
thanks
You confused DTS and DST. Sadly, I don't know how or if you can extract the audio and convert it to a usable format for PC-based playback.
hi guys,
thanks
As far as I know, there is no way to read a SACD on a PC.  I ran across this site today:
http://www.ps3sacd.com/dsd_downloads.html
You might find information there.
There is a cli windows program called "scarletbook.exe" if you google enough you can find it.
you would then have to register the decoder,
regsvr32 DecoderComp.dll
then run scarletbook
scarletbook.exe -c -m -iexample.iso
Edit:
I believe that "scarletbook.exe" was written by the guy who led the sacd-ripper project for the PS3 on code.google.com
Since you are using the foobar2000, install the foo_input_sacd component (if you already haven't installed it) and configure it to the desired PCM samplerate. Load the SACD ISO file into the playlist, and select the desired track(s). But be sure that they are the multichannel ones. Usually, there is also a stereo mix on a SACD, so you have 2 sets of tracks in the playlist. Open the converter, choose the encoder (FLAC for example, if you want lossless) and convert the tracks. It works, I've tried it.
Cheers
Re: extract dts from iso
Cheers
Could not load component "foo_input_sacd.fb2k-component": This component was built for a different processor architecture.
You are replying to a post from 2011 (and which also isn't correct about losslessness).
Back then, everything was for 32-bit. As far as I understand, fb2kv2 support has experimental status. Try to redownload the newest version from the source. If you cannot get it work, use fb2k 32-bit.
And again, non-DST DSD can be losslessly contained in WavPack.
