Topic: Copy music by genre? (Read 1297 times) previous topic - next topic
  • Meaning
Hello all,
I would like to find a way to use foobar's fabulous tag seach functionallity in addition to my explorer copier.
By this I mean that i would like to be able, for example, to search for the "techno" tag using foobar, get all the results, then select all the results and copy / paste the showed folders from the initial hard drive to another location.
Do any of you know a way to do that? It would be great!
  • Cutter
Library > Search (or open all of your music in one playlist and do Ctrl + F), then type GENRE IS techno. Right-click on one of the highlighted tracks and click on File operations > Copy...
  • Last Edit: 22 October, 2011, 05:22:14 PM by db1989
  • Meaning
yes this is indeed a beginning of solution. but it wont copy the countaining folders
  • Last Edit: 23 October, 2011, 08:07:38 AM by db1989
  • tpijag
There is an option to Copy entire source folder content.
Do you have it checked?
  • Meaning
It indeed does the trick!
Thank you so much for the help guys!
