FLAC creation on EAC 1Beta3
Reply #6 – 2011-10-22 12:53:30
Path to flac.exe is ok...See logExact Audio Copy V1.0 beta 3 from 29. August 2011 EAC extraction logfile from 22. October 2011, 12:50 Noel Gallagher's / Noel Gallagher's Used drive : HL-DT-STDVDRRW GSA-4166B Adapter: 0 ID: 0 Read mode : Secure Utilize accurate stream : Yes Defeat audio cache : No Make use of C2 pointers : No Combined read/write offset correction : 0 Overread into Lead-In and Lead-Out : No Fill up missing offset samples with silence : Yes Delete leading and trailing silent blocks : No Null samples used in CRC calculations : Yes Used interface : Native Win32 interface for Win NT & 2000 Gap handling : Not detected, thus appended to previous track Used output format : User Defined Encoder Selected bitrate : 32 kBit/s Quality : High Add ID3 tag : No Command line compressor : C:\Program Files (x86)\Exact Audio Copy\Flac\flac.exe Additional command line options : -6 -T "artist=%artist%" -T "title=%title%" -T "album=%albumtitle%" -T "album artist=%albumartist%" -T "date=%year%" -T "tracknumber=%tracknr%" -T "genre=%genre%" %source% TOC of the extracted CD Track | Start | Length | Start sector | End sector --------------------------------------------------------- 1 | 0:00.00 | 5:31.33 | 0 | 24857 2 | 5:31.33 | 4:29.22 | 24858 | 45054 3 | 10:00.55 | 4:09.08 | 45055 | 63737 4 | 14:09.63 | 3:29.20 | 63738 | 79432 5 | 17:39.08 | 4:23.20 | 79433 | 99177 6 | 22:02.28 | 4:24.35 | 99178 | 119012 7 | 26:26.63 | 3:22.27 | 119013 | 134189 8 | 29:49.15 | 3:35.20 | 134190 | 150334 9 | 33:24.35 | 4:02.48 | 150335 | 168532 10 | 37:27.08 | 5:06.67 | 168533 | 191549 Track 6 Filename \\MUSICNAS\media\Music\Noel Gallagher's\2011Noel Gallagher's\Noel Gallagher's - Noel Gallagher's - 06. AKA... What A Life!.wav Peak level 100.0 % Extraction speed 3.9 X Track quality 100.0 % Copy CRC 02DFA70F Copy OK No errors occurred End of status report
