Topic: FLAC Cue question. (Read 2515 times) previous topic - next topic
  • PixieStix
FLAC Cue question.
I ran this cd  through medival cue splitter, but what does this mean when I load a cue  n it says:
#CUE Splitter log file#
1|23|No track was specified for previous "FILE" command.
1|39|No track was specified for previous "FILE" command.
1|50|No track was specified for previous "FILE" command.
REM ACCURATERIPID 000f275c-006d5d89-8209f609
REM DATE 1975
REM DISCID 8209F609
REM COMMENT "ExactAudioCopy v0.99pb5"
PERFORMER "AC/DC"
TITLE "T.N.T."
CATALOG 9399746526228
REM DISCNUMBER 1
REM TOTALDISCS 1
FILE "01 - It's a Long Way to the Top (If You Wanna Rock 'n' Roll).flac" WAVE
  TRACK 01 AUDIO
   TITLE "It's a Long Way to the Top (If You Wanna Rock 'n' Roll)"
   PERFORMER "AC/DC"
   INDEX 01 00:00:00
FILE "02 - Rock 'n' Roll Singer.flac" WAVE
  TRACK 02 AUDIO
   TITLE "Rock 'n' Roll Singer"
   PERFORMER "AC/DC"
   INDEX 01 00:00:00
  TRACK 03 AUDIO
   TITLE "The Jack"
   PERFORMER "AC/DC"
   INDEX 00 05:04:73
FILE "03 - The Jack.flac" WAVE
   INDEX 01 00:00:00
FILE "04 - Live Wire.flac" WAVE
  TRACK 04 AUDIO
   TITLE "Live Wire"
   PERFORMER "AC/DC"
   INDEX 01 00:00:00
FILE "05 - T.N.T..flac" WAVE
  TRACK 05 AUDIO
   TITLE "T.N.T."
   PERFORMER "AC/DC"
   INDEX 01 00:00:00
  TRACK 06 AUDIO
   TITLE "Rocker"
   PERFORMER "AC/DC"
   INDEX 00 03:35:23
FILE "06 - Rocker.flac" WAVE
   INDEX 01 00:00:00
FILE "07 - Can I Sit Next to You Girl.flac" WAVE
  TRACK 07 AUDIO
   TITLE "Can I Sit Next to You Girl"
   PERFORMER "AC/DC"
   INDEX 01 00:00:00
  TRACK 08 AUDIO
   TITLE "High Voltage"
   PERFORMER "AC/DC"
   INDEX 00 04:11:15
FILE "08 - High Voltage.flac" WAVE
   INDEX 01 00:00:00
FILE "09 - School Days.flac" WAVE
  TRACK 09 AUDIO
   TITLE "School Days"
   PERFORMER "AC/DC"
   INDEX 01 00:00:00
Here is screen shot of when i try to burn it to an image on nero
Uploaded with ImageShack.us
Can this be fixed? Im also getting it happening with cue tools splitting....
of image +cue of other cds
  • Last Edit: 15 October, 2011, 11:59:53 AM by greynol
  • Rollin
FLAC Cue question.
Maybe flac is corrupted?
  • Last Edit: 15 October, 2011, 07:30:25 AM by Rollin
  • greynol
  • Global Moderator
FLAC Cue question.
The problem is with the burning program.
It looks like perfectly good noncompliant cue to me.
Decompress the flacs to wave, replace all instances of .flac in the cue sheet to .wav, and then try loading it into EAC.  You will probably not have any errors.
  • Last Edit: 15 October, 2011, 01:08:59 PM by greynol
  • mjb2006
FLAC Cue question.
More helpfully: Cue sheets are "officially" designed for "image" rips, where all of the audio is in one file.* You have a rip where the audio is in separate files. It's impossible to have a valid cue sheet for this kind of rip, unless one of the rules for cue sheet formatting is relaxed (the rule about where FILE is allowed). Exact Audio Copy (EAC) is a ripper & burner which relaxes the rule so that the cue sheet can apply to the very common and useful file-per-track type of rip. EAC can create these "noncompliant" cue sheets, and can also burn from them if the source files are WAV, hence greynol's advice to convert them first. The other software you are using is more strict when it reads these cue sheets, even though it doesn't really need to be.
You should read the cue sheet article in our wiki for more info.
* Cue sheets don't have an official spec; they're just a format invented for one of the very first ripping/burning programs, and no one has bothered to turn it into a more general, open, and flexible standard that works with every kind of rip. And technically, they do officially support file-per-track rips, but only when the files are cut with very unusual boundaries ("gaps prepended").
  • sauvage78
FLAC Cue question.
I am ashamed  ... Greynol is right once again  ... I was misslead by the non-codeboxed CUE (no layout) & the line number error messages.
I have an AR(50+) CDImage of a different pressing of your CD ... I splitted it & it looks almost exactly as yours except for timings. I doubt the CUE is damaged at all, I think it's a burning software issue, the software doesn't seem to support CUE with two TRACK command for one FILE command.
Anyway medieval cue splitter is crap, it's more surprising for Nero ... try something specialized in audio like Burrrn, I don't think it is supported anymore but I can't think of anything else as I don't burrrn anymore. Anyway Gambit still rrrullz, so it should work.
  • Last Edit: 16 October, 2011, 11:24:49 PM by sauvage78
Rip & Check: EAC Secure [Low/C2]+CUETools [AR Confidence 2+]
NAS (Backup): Flac -4 (for Speed) | CDImage+CUE with F2K
DAP (Playback): Opus 128Kbps | Tracks with F2KM on Android (LG G5)
Video: AV1 (2160p30@24Mbps-2Pass) Asap !!!
