Topic: play/pause issue with win7 and phonic firefly (Read 1747 times) previous topic - next topic
Hello everyone,
first i would like to thank you all for your great work at this forum!
I'm using foobar2000 v1.1.8 (wich is (hopefully) the latest version) on a 64 bit win7 computer and a phonic firefly 302 firewire interface.
When i pause foobar only for a few seconds and press play afterwards everything works fine, but if it's paused for a longer break it woudln't play.
sometimes it works again after restarting, sometimes i have to restart my audio interface.
If this happens the Console displays:
Opening track for playback: "D:\file.mp3"
no error message. But foobar seems to get some information from the track because i can see the the spectrum visualisation flickering - and changing if i scroll in the seekbar, but it just won't play.
all my drivers (an bios) are on the latest version. It Could be a problem of windows threads taking controll of the interface but changing the regarding settings didn't help.
Do you have an idea?
Thank you for your help,
5ilver
You may want to hit the report button and ask a mod to move this to where it will receive appropriate views. Hydrogenaudio hosts a Foobar2000 subforum.
http://www.hydrogenaudio.org/forums/index....amp;s=&f=28
Take a look at the sticky in the support subforum and it will help you to provide enough information to receive competent help.
