Topic: Possible to make a multi-column theme? + switch themes using a button? (Read 1718 times) previous topic - next topic
  • MasterMatt
Hi there.
First of all, excuse my English. I am a new foobar2000 user since a few months right now. I have added some great components but I'm looking for more! I would like to know if there is an existing plugin which can do the following thing : when I press a button (or the maximize button, would be better), to switch from
this (my actual theme) :
to this (quickly designed under paint.net) :
I searched the web to find some plugins, but it was unsuccessful. Is it possible to do this with Column UI (I don't think so)? Thank you!
w00t
  • shakey_snake
  • Moderator
Generally, playlist play files in order from top to bottom; multiple columns kinda throws a wrench into that whole concept.
You can use foo_facets to browse your library (which also likely contains toute la musique). It offers a multiple column display with album artwork.
  • Last Edit: 05 October, 2011, 11:45:19 PM by shakey_snake
elevatorladylevitateme
  • Anomalous
EsPlaylist can display albums/artists in multiple columns, but doesn't show individual tracks.
  • MasterMatt
Thank you for your answers. For developers around here, how hard is it to write such a thing? I am a new software engineer but I have never wrote a plugin for foobar or whatsoever.
w00t
  • marc2003
to write a proper component requires c++ knowledge. you can look at the SDK here... http://www.foobar2000.org/SDK
an alternative might to be look at columns UI (an alternative user interface) and the panel stack splitter component. this allows you to resize the foobar window with buttons. you can also set it to hide/show panels depending on panel size. it's not a language as such - merely an extension of the title formatting functions provided by foobar itself. for example to do something conditionally based on panel size, you could use $ifgreater which is native to foobar itself but then it has it's own variables such as %_width% and %_height% which are exclusive to that component only.
to get familiar with foobar title formatting, you can look at the full reference here.
http://wiki.hydrogenaudio.org/index.php?ti...tting_Reference
  • MasterMatt
Thank you for your answer. I know quite well C++. However, I don't really want to implement my own Panel UI or Display UI, because I am already using a 3rd party component called SimPlaylist. Unfortunately, it seems that Simplaylist is not open source, so I cannot rely on the official foobar SDK. My idea was to write a flow panel layout using Simplaylist. But it seems complicated because I don't know how the playlist is rendered : is it a big instance of a panel, a list/stack/etc of panels?
I could start to implement just a simple flow layout panel with every album art on my playlist. Maybe after that I'll know better of how I could improve it, and it will be a first proof of concept. A flow layout panel is not really complicated to write, but it will be the first time for me to produce a plugin for foobar.
  • Last Edit: 12 October, 2011, 01:43:59 PM by MasterMatt
w00t
