Topic: CUI: [feature request] Foobar only in tray (Read 2686 times) previous topic - next topic
  • wojtek
right now there is an option to minimize foobar2000 to the tray, but when the application is restore there is still a taskbar item. It might be helpful, but with the double-display setup when on has the application constantly visible on the second screen there is hardly a need for the taskbar item (especially when one has a lot of application running and taskbar is getting quite crowded)
http://foobar2000.pl/ :: unofficial polish forum
  • db1989
  • Global Moderator
Searching revealed several past threads on the same question. It seems that this isn’t possible (refs.: [1], [2]).
  • Last Edit: 01 October, 2011, 10:00:57 AM by db1989
  • shakey_snake
  • Moderator
In your unique situation, you may want to consider using a UI, such as columns, that can be customized to fit your unique needs.
As far as the Default UI, this won't be implemented because having an open window appear in the taskbar IS a usability and accessibility requirement.
elevatorladylevitateme
  • wojtek
Well, I'm using ColumnsUI but haven't found option there either. fortunatelly i've stambled upon <removed> which does the trick.
as for the requirement -- is it mandated by MS/Windows? also - how do *option* to do so violates this? It's meant for the (hate the phrase) 'power user' who should know the consequences of it..
  • Last Edit: 02 October, 2011, 12:51:18 PM by Frank Bicking
  • shakey_snake
  • Moderator
Well, I'm using ColumnsUI...
Great, then you should be asking musicmusic. Thread Moved
  • Last Edit: 02 October, 2011, 03:36:32 PM by shakey_snake
  • wojtek
I think that CUI developement has stopped
A noob question -- is it possible for an external plugin/componend to achieve that without violating SDK?
