Topic: I used EAC+PlexTools but PT doesn’t support my new offset—other progs? (Read 1738 times) previous topic - next topic
  • Deuterium
Hello!
I recently purchase a Plextor PX-L890SA, my old 504 comes to an end! My problem is that I use for ripping, EAC and PlexTools 3.13, simultaneously with a Plextor  161040, which still works perfectly, giving me four extractions to compare each other; yes, I'm a perfectionnist! The problem? The offset of the 890 is +6, I must thus wait for an overread of 24 bytes in my extractions, and that's OK with EAC. With Plextools 3.13 (and also 3.16 I tried!), no overread, but a displacing of all the file with 24 bytes! I explain: if the hexadecimal adress of the first no null byte is X with EAC, it's X-18 (24 hexadecimal) with PlexTools, and in all tracks of a CD! I know PlexToolds is very old, but is it an other reliable software (excluding, of course, EAC, that I already use) that I can use to replace it? PlexTools don't give any offset information with this drive!
Deuterium
  • greynol
  • Global Moderator
foobar2000, CUERipper, dBpoweramp
  • Deuterium
Great! I've already heard about Foobar 2000, I will try it... in november, because of holidays!
Thanks for your feedback!
Deuterium
