Topic: To convert FLAC to MP3 at 320 kbps, are my settings correct? (Read 4699 times) previous topic - next topic
i convert the flac format to mp3 320kbps with foobar2000 program
by the foobar2000 converter setup it stands for output format-format:mp3(lame),320kbps cbr
(i downloaded lame.exe from the net)
is this way of converting allright or did i make something wrong by converter setup and need to change it
sometimes i convert flac to mp3 320kbps with the program anyaudioconverter which i have too
(i didnt mention i rip the original cds with jetaudio in flac and after that i convert it in mp3 32okbps in foobar or anyaudioconverter)
The foobar2000 settings you are using are fine so long as you want 320kbps CBR mp3 files.  I cannot comment about anyaudioconverter because I have never used it and I don't even know what mp3 encoder it uses.
  • xnor
What are your custom encoder settings?
"I hear it when I see it."
i dont know
where must i go to read that what my custom encoder settings are
do you think in foobar or?(sorry my english is bad so i didnt really understand you about custom enc.setting)
  • Last Edit: 25 September, 2011, 06:37:42 PM by takeshibeat
  • xnor
Oh you can just pull the slider (in Converter Setup - Output Format - MP3) all the way to the right, no need for custom encoder settings.
I guess that's how you did it so everything is ok.
  • Last Edit: 25 September, 2011, 06:52:48 PM by xnor
i dont have any slider in converter setup-output format and i coudn t find anywhere custom encoder settings
