Topic: CDex vs. EAC (Read 2517 times) previous topic - next topic
  • acid-art
CDex vs. EAC
Is it possible to compare CDex "Paranoia, Full" method with EAC "Secure mod"? Which one produces best quality on good CD (without any scrtaches)?
  • Jan S.
CDex vs. EAC
With perfect cds the output should be the same (except for the offset); otherwise EAC is considered to be the best if you set it up properly.
Please use the search function; this has been discussed many times.
  • Last Edit: 05 May, 2003, 12:07:06 PM by Jan S.
  • acid-art
CDex vs. EAC
Tanks!
2Moderator: You may remove this post.
