Topic: Where is the default album art file located? (Read 2035 times) previous topic - next topic
  • Bob Brines
I would like to replace this file, but I can't find it. I searched the Foobar2000 folder in /Program Files and in appdata/roaming. A search of this forum got no hits. Someone knows!
Thanks,
Bob
  • Robertina
  • Banned
Do you mean the picture that is shown if neither embedded nor external artwork is available or matches your album art search patterns? This picture is hard-coded.
To change that picture, go to File > Display -> "Stub image path".
  • tpijag
what default art?
Guess you should follow above advice. I have never had a default art. Maybe I nuked it long ago and have long forgotten. For me, no art available = blank.
Edit: more explicitly blank image with text as noted below.
  • Last Edit: 12 September, 2011, 04:55:10 PM by tpijag
  • marc2003
what picture?  the default UI artwork viewer displays text saying [no image] when no artwork is found. if you mean the musical note logo then of course that only applies to columns UI.
  • Robertina
  • Banned
Ouch. Yes, I am using Columns UI and thought the DUI would behave similar concerning this matter. Probably I should more often switch to the default user interface.
Anyhow, the "Stub image path"-function belongs to the DUI and then replaces that text saying "no image", doesn't it? If I am wrong again or the OP meant something other, moderators will please delete my contributions to this thread.
  • Bob Brines
That's it! Thanks.
Bob
