Topic: foo_uie_lyrics3 (Read 903166 times) previous topic - next topic
Re: foo_uie_lyrics3
Reply #1778
Can I open "external editor" without windows prompt standing by?
Re: foo_uie_lyrics3
Reply #1779
Hello,
I can't see/change/reach all panel settings  :(
see attachment
System:
  • Windows 10 - 1809
  • DPI 150%
  • foobar2000 - 1.4.3
  • foo_uie_lyrics3 - 0.5
Re: foo_uie_lyrics3
Reply #1780
Hi guys. Im using version 0.5 (last one i think) but again, i cant get any lyric at all to actually save to custom defined folder. I deactivated auto saving just in case and i save lyrics automatically with right click-> save. But nothing is saved.
Is this still an issue? o.O
EDIT: Ok, so it appears that if i change the folder to root D:\whatever it works. But if i save the song to the app directory, c:\program files\foobar2000\lyrics   for example, it doesnt.
Any clue?
Re: foo_uie_lyrics3
Reply #1781
Any clue?
Certain windows folders you need to run the application so you can write to them, I believe that the one you indicated and that you are not saving is one of them, or you run foobar2000 at the administrative level or choose other folders that do not require this. I think.
Re: foo_uie_lyrics3
Reply #1782
Hello the Vern. I'm reporting a issue.
I noticed that for embedded synced lyrics (in ID3v2 tag, the most common tag for mp3), the plugin read and write a user defined frame (TXXX) called LYRICS. Is there any reason that the SYLT frame (standard ID3v2 frame for synced lyrics) was not used? Lyrics embeded in other software like MusicBee, Minilyrics, JetAudio can't be displayed in this plugin because of this. Maybe consider adding support for SYLT frame? (it will make a lot more sense as SYLT is the intended and standard way to embed synced lyrics).
For more help:
You can find more info about frames like USLT, SYLT, TXXX at the ID3v2 website (http://id3.org/id3v2.3.0).
You can check a mp3 file's tag structure with a software called "MP3 Diag", you can use it to check what frame (USLT/SYLT/TXXX) is in a mp3 file.
It's just my suggestion though, as making things more standardized makes more sense to me, and it will allow users to see lyrics on different platforms.
Re: foo_uie_lyrics3
Reply #1783
Same problem here at 200% scaling.
I wanted to try and fix this myself and submit a pull request, but I could not get the component to compile, due to all the SDK and other libs needing old/XP versions of the Visual Studio toolset, and not all of them having the source code to rebuild the libs. :(
I'd be happy to help fix the code if I can. Have lots of experience with DPI stuff in Windows, and it should be quite simple.
There are a couple of workarounds for people experiencing this problem:
1) If you close foobar then right-click foobar2000.exe, Properties, Compatibility and set DPI scaling to System (or System Enhanced), it will be tricked into thinking Windows is in standard DPI and you can go in and make changes to the settings, then undo that. Unfortunately, some of the settings themselves are subject to DPI changes, so you may find you have to go back & forth a few times until you have everything how you want.
2) Better, but requires you grab nircmd.exe or a similar tool that can resize other programs' windows. You can resize the plugin's settings window with a command like this:
"C:\Program Files\NirCmd\nircmdc.exe" win setsize title "Lyrics show Settings" 0 0 800 700
Experiment with the last two numbers to get a size that's right on your system.
The OK and Cancel buttons will still be in the wrong place, maybe on top of something else and impossible to click, but you can just use Return or Esc instead of those. This made things work well enough for me to get the plugin configured. Hope it helps!
Re: foo_uie_lyrics3
Reply #1784
Does anyone know where to properly upload timestamped lyrics (.lrc) to since Minilyrics has just murdered the website? (Website gives 404 on pretty much all pages, old lyrics are gone and new ones can't be uploaded even with a new account).
Makes me wonder how much has been lost really, very sad. (Is there any backup out there?)
Making timestamped lyrics is a bit of a hobby and a way to keep my mind of things while working on songs that I love.
I know this plugin uses these sources:
Online DB: Timestamped 1: https://www.cicyzone.com/Lyrictest
Online DB: Timestamped 2a: http://lrcct2.ttplayer.com/
Online DB: Timestamped 2b: http://ttlrcct.qianqian.com/
Online DB: Timestamped 2c: http://ttlrccnc.qianqian.com/
Online DB: Timestamped 3: http://www.viewlyrics.com/
Online DB: Timestamped 4: http://music.baidu.com/search/lrc
Online DB: Timestamped 5: http://lp.music.ttpod.com/
Online DB: Timestamped 6: http://www.lirik.mobi/
But none of them seem to really show how to upload to them or don't even exist.
Re: foo_uie_lyrics3
Reply #1785
The Minilyrics website (https://www.crintsoft.com/minilyrics/) is up for me as of this post and loading all pages, maybe they were just down for maintenance, give it another try.
Re: foo_uie_lyrics3
Reply #1786
Not the case, the minilyrics application itself is still available but its lyric database website is broken: https://viewlyrics.com/
Been like this for weeks, you will see "Online DB: Timestamped 3" does never show up anymore in foo_uie_lyrics3 results because the database is cleared
Re: foo_uie_lyrics3
Reply #1787
You can check Lyrics.wikia.com or as it is called now https://lyrics.fandom.com/wiki. AFAIR it was all manual. Search for .lrc brings some time stamped lyrics. I'm not sure if it works as a source anyway.
Re: foo_uie_lyrics3
Reply #1788
Yep, I stand corrected there smiba.  The foo_uie_lyrics3_minilyrics plugin also throws the 404 message.  I seem to recall them being operationally offline for an extended period in the past, so hopefully they show up eventually.  If not, what a waste.
Re: foo_uie_lyrics3
Reply #1789
@The vern:
An issue with fallback text- I use the comment tag as fallback (mostly for catching podcast information, as that's commonly the tag used for podcast descriptions, etc.), but it seems that quite a few podcasters are on Macs (or maybe using iTunes to tag their pods?). Problem is (I think!), the end-of-line text character for Mac is CR (carriage return), while for Windows it's CRLF (carriage return-line feed), so on my Windows computer I end up getting text with no line breaks. Would it be easy/possible to fix this?
And also a couple of feature requests:
1. User configurable text buttons on the editor panel. Specifically for adding often repeated lines (PRECHORUS:, CHORUS:, REPEAT CHORUS, BRIDGE, FIRST VERSE, etc.). Pretty much have to be user configurable because of the various ways different users format such things (capitalization, parentheses, brackets and so on).
2. Get the "external editor" button to open up the specified editor even if the lyrics are saved in the tag (currently it opens the Properties dialog box). I have macros in Notepad++ for easily fixing/formatting common lyrics mistakes that, obviously, I can't run from Properties.
Really appreciate all the work you've done on this component over the years.
Re: foo_uie_lyrics3
Reply #1790
Hi guys, just wondering if I could make this plugin load a specific lrc file in the local directory? Thanks!
Edit: Never mind! I just figured it out in the Property/Local search! Thanks!
Re: foo_uie_lyrics3
Reply #1791
WTF?:?
Re: foo_uie_lyrics3
Reply #1792
@Mrakobes I get this also for more than a year. Usually it happens to me after I use Foobar for some hours and my and after double-clicking more than about 20 tracks.
Soon after it shows this foobar will not respond and I will have to kill its process.
I haven't yet inspected it but maybe if I disable my foo_facets plugin it won't happen.
@Mrakobes do you like me use foo_facets ?
Re: foo_uie_lyrics3
Reply #1793
I use, yes. I don’t want to disconnect, I’ll lose sorting, didn’t you disconnect too? Does not help?
Re: foo_uie_lyrics3
Reply #1794
it seems that the plugin doesn’t download the lyrics completely, stops at 60 - 90 percent and does not unload the previous ones
Re: foo_uie_lyrics3
Reply #1795
This happens when you start the next song with the active lyrics panel, when you switch to another tab and start the track, activate the lyrics panel - everything’s ok
Re: foo_uie_lyrics3
Reply #1796
Hello all of You!
At first I wanted to thank the creator of this lyrics-plugin for all the joy by using it!
Then, am I missing something (sorry if yes)? Since a couple of weeks now, the Lyric Show Panel 3 doesn't load lyrics anymore - only the already saved in the defined folder (Local search).
Many thanks in advance for any suggestions.
Win7 64bit; the registry entry (TLS 1.1 and TLS 1.2) done; Latest foobar2000 stable version (v.1.5.1); latest Lyric Show Panel 3 (v.0.5)
Re: foo_uie_lyrics3
Reply #1797
Working fine here.  What is your sources "Search Order", and what have you selected in "Search for this type of lyric:"?
Re: foo_uie_lyrics3
Reply #1798
Hi sveakul,
many thanks for Your response!
"Search for this type of lyric" > "Prefer synced"
"Search order:" all of the availabilities, except "Online DB: Timestamped 5".
Re: foo_uie_lyrics3
Reply #1799
Hi Miltiades,
I use only non-synced sources and no external files (only tagged), so that may be why our experiences differ.  I'm thinking a lot of the "timestamped" sources built-in to the component may have ceased operation, or changed their search formats so that what the plugin uses is no longer compatible.  FWIW,  I use the "prefer non-synced" setting, and my sources and search order are:
Tag Search
Online DB: metal-archives.com
Online DB: darklyrics.com
Online DB: lyrics.wikia.com
Online DB: Google search
