Hopefully there should be a new version of foo_uie_lyrics3 on it's way. I have had 3 tests versions from The vern over the last few weeks.
I thought I would point out this package that's been around for a while "Extend Sources For Lyrics3.fb2k-component" which contains 4 timestamp (sync) databases that are working and 1 unsync database (scroll down the web page until you see the package).
Hell, I've been looking for that chinese sources plugin for quite a while, could only find dead links. Seems like I've been looking in the wrong places. Thanks for posting this.
Not much of a help as they are (except for azlyrics) all in Chinese.
I'll just wait impatiently for the vern.
The sites are chinese, but they don't only have chinese lyrics. In fact, they have loads of stuff. I think even more than default sources ever had in terms of synced lyrics.
There is one major drawback though. The most useful of them do not support exact match search, or it is not implemented. So if you're searching for more obscure lyrics, you'll get a lot of wrong results and will have to click "next lyrics" several times. Sometimes a lot of times.
So yeah, we're all looking forward for the vern to update this.Hello,
The custom source I've made one year ago for ML is still working. I just had to patch lyrics loading in a rush because of DNS who breaks about a month ago.
So if The Vern has no plan time to release an updated version in the following days, I can publish it if someone is interested. But you will have to be lenient because I am not very skilled at C++ so it must inevitably contain some memory leaks, or even worse.
Someone is very interested ![Grin ;D](https://hydrogenaud.io/smileys/default/grin.gif)
On a side note, how come the default fallback text has no progress bar?
![](https://hydrogenaud.io/index.php?PHPSESSID=e0u1dqq636jgpiohqj28a47gcl&action=dlattach;topic=90338.0;attach=9665;image)
$if(%search_state% $not(),$progress2(%search_progress%, 100, 25,'█','░'))$if(%search_state% $not(), ,No lyrics available. Tough luck.
๐·°'('৹˃̵﹏˂̵৹')'°·๐)
