Topic: foo_uie_lyrics3 (Read 903200 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
foo_uie_lyrics3
Reply #1550
foobar can tag wav files but other software might not be able to read them. the most sane thing to is convert those wav files to flac. if you use itunes/ipods/iphone/ipads etc then apple lossless would be a better choice.
That's not an option for me. I need a way to do it via the folder structure.
Just convert and tag them.
If you have files and directories named consistently (artist - album - filename) you may try to extract search strings parameters from them using title formatting, I don't know: $directory(%path%,2) for artist and $substr(%filename%,6,100) for title if filename is 01 - title.
foo_uie_lyrics3
Reply #1551
Using these parameters is what I thought of as well. If I use yours, it seems to work in general, but it cuts off the beginning of the title name in the title search field ("yond" instead of "09 Beyond"). Can you explain what $directory, (%path%), %substr% and the numbers 2, 6 and 100 mean in this context?
Thank you.
foo_uie_lyrics3
Reply #1553
Thank you.
From the link above:
$substr(s,m,n) Returns substring of string s, starting from m-th character and ending at n-th character.
In your case m=4 09 Beyond
$directory(x,n)[edit]
Extracts directory name from the file path x; goes up by n levels.
So if you have "artist" folder above "album" folder(s) than n=2.
foo_uie_lyrics3
Reply #1554
Alright, now everything works perfectly fine and I get lyrics for all my songs. Thanks for your help.
foo_uie_lyrics3
Reply #1555
I seem to get best results using this for title during search:
[%title%] "lyrics.wikia.com" OR "genius.com" OR "oldielyrics.com" OR "lyricsfreak.com" -azlyrics.com
azlyrics.com wont let you load lyrics so it's blocked on the end with the minus sign.
So add any site to end with minus sign to not use that site for lyrics search.
LyricsFreak.com seems to work the best for the music I listen to. Mainly country.
God Bless U.S.A
foo_uie_lyrics3
Reply #1556
Is there any chance to add fullscreen support? like a karaoke mode?
foo_uie_lyrics3
Reply #1558
Version 0.4.5 can't retrieve lyrics from www.azlyrics.com.
So I build lyric spource compoment,from the "Lyric source SDK".
https://github.com/tripod31/foo_lyricsource
I can confirm it works. The Readme needs a little work (and a spellcheck).
After installing the new component and placing the 2 DLLs in the Foobar directory, Go to Preferences > Tools > Lyric Show 3 and add "www.azlyrics.com" from 'Available Sources' to 'Search Order'.
I would suggest deactivating the "Online DB: Google Search" by moving it back to 'Available Sources'.
I hope this helps clear things up.
Good work, Tripod31, I appreciate it.
foo_uie_lyrics3
Reply #1559
I followed the instructions for foo_lyricsource but I get:
Failed to load DLL: foo_lyricsource.dll
Reason: Unsupported format or corrupted file
foo_uie_lyrics3
Reply #1560
Working flawless here. Check the size of the file (should be 198.144 Bytes).
If it's wrong try loading it again here.
Greetings, ...
foo_uie_lyrics3
Reply #1561
Thanks, it works now!
foo_uie_lyrics3
Reply #1562
Where do you enter this string in the preferences? Thank you.
foo_uie_lyrics3
Reply #1563
Still getting "Load Failed" on Genius and Wikia Google searches. See picture:
Any fix would be appreciated.
foo_uie_lyrics3
Reply #1566
Quote from: Arcane-BLUE link=msg=0 date=
foo_uie_lyrics3
Reply #1567
a component made years ago , adding 4 or 5 more lyric sources for lyrics3:
????/ttplayer  (timestamps 2 or 3 )?
????/xiami.com
????/mp3.baidu.com
qq??/music.qq.com
download:
https://userscloud.com/2xn3muinb1ir
Can you please reupload the plugin? The link is dead.
https://userscloud.com/8cubgnmhqrbf
by the way, xiami.com is only available in mainland China.
foo_uie_lyrics3
Reply #1568
Need option to save lyric as lrc and in a tag at the same time as possible in minilyrics
foo_uie_lyrics3
Reply #1569
And what about possibility to make lyric clickable? Point to some string goes to that part of file with proper timing
foo_uie_lyrics3
Reply #1570
Is it possible to make the lyrics panel have a minimize option?
I hate the fact that its focus has to be on top at all times and it blocks the rest of my Foobar window / other objects on my screen.
I'd like to be able to minimize it, closing the lyrics panel and reopening it is not very intuitive, but I wouldn't be surprised if this was some limitation in Foobar..
Much appreciate your work, this is a great plugin!
Thank you.
foo_uie_lyrics3
Reply #1571
How fast disable lyric search? With one checkmark like audoscrobbler? Can't find that option in settings
foo_uie_lyrics3
Reply #1572
AzLyrics has nothing to do with my request or issue but here's your pat on the head. Congrats. Well done.
foo_uie_lyrics3
Reply #1574
Does anyone know how to bypass the "local lyric already exists" false positive?
The situation: I got several versions of my audio files in different versions - mostly FLAC 44100 for "on the go" purposes, FLAC 96000 or 192000 for home listening.
However, just because I do have a .lrc for a 192k, that does not mean that I shouldn't be able to automatically save an .lrc for a different version. For a different dir, different file.
Yes, the artist-title is the same, but the directory is different, and even the filename is different. (all my FLACs are renamed to include bitrate on filename!)
All feedback appreciated.
