Topic: foo_uie_lyrics3 (Read 903106 times) previous topic - next topic
0 Members and 6 Guests are viewing this topic.
foo_uie_lyrics3
Reply #425
Yeah, the offset adjustment is fantastic.
foo_uie_lyrics3
Reply #426
Finally Lyrics Wikia!! THANKS A LOT!!!
foo_uie_lyrics3
Reply #427
It's not finding lyrics in darklyrics for me, is it working for anyone? Also lyrdb search is returning lots of wrong results :/
Both darklyrics and lyrdb have given me consistent bad results (darklyrics for anything non-english, lyrdb just in general). I removed them both for now...
foo_uie_lyrics3
Reply #428
I'm not sure if this is the right place to post this. Anyhow, I just upgraded from lyrics 2 and I'm loving the changes.
However, I'm a bit stuck trying to get a UI button of mine working now that the menu commands have changed some. Instead of going through Menu - View/Lyrics Show 2/Online search, I'd right click the panel and bring up the menu like that. I'm not sure how to specify that in the script.
$imagebutton(8,5,42,19,$get_ps_global(IPath)\Button\lrc\search.png,$get_ps_global(IPath)\Button\lrc\search_$get_ps_global(color)_h.png,
COMMAND:View/Lyric Show v2/Online search,,)
I usually love figuring things out on my own and browsing through the posts on the forums, but I'm a bit stumped here. I've gone through http://wiki.hydrogenaudio.org/index.php?ti...mmandline_Guide and looking through panel scripts on some of my alternate layouts. I can't find anything that would properly execute the new "Lyric search" command available in the context menu of the updated component.
What am I missing?
Thanks in advance.
foo_uie_lyrics3
Reply #429
Hit "shift" while clicking on "view", and you'll see "lyrics show 3" and then you can reach "lyric search" and a bunch of other commands.  I don't know if the shift key is required for scripting.  Hope that helps.
foo_uie_lyrics3
Reply #430
Doesn't seem to work for me. When I go to Menu -> View -> Lyric Show v3, it just brings up the panel. There's no submenu with the other commands even if I press Shift while clicking. Might be different versions or layouts we have. I did have the commands there in an older version of foo uie lyrics 3 I initially tried.
foo_uie_lyrics3
Reply #431
I'm using Columns, Foobar2000 v1.1.10 and the latest version of Lyrics3, and I see without shifting menu>view>lyric show panel v3, which brings up the panel.  And if I hit shift and then menu>view I see near the bottom "Lyrics Show 3", which has the command you want in a drilldown menu to the right.  I don't see anything that brings up "Lyric Show v3".
foo_uie_lyrics3
Reply #432
I'm using Columns, Foobar2000 v1.1.10 and the latest version of Lyrics3, .... I don't see anything that brings up "Lyric Show v3".
DUI, "Lyric Show v3" is there and lets the panel shine blue.
@fancysocks, why don't you use right mouse click on the lyric show panel?
foo_uie_lyrics3
Reply #433
hi there,
would it be possible to have the lrc files save to a special folder within the folder of the currently playing song?
like:
playing file: D:/music/album/file.mp3
--> lrc save to: D:/music/album/lyrics/file.lrc
cheers
foo_uie_lyrics3
Reply #434
Use: save to user defined directory with the below code
$directory_path(%path%)\lyrics
foo_uie_lyrics3
Reply #435
The local file search doesn't work like I expect.
My lyrics are saved in the same folder the music file is saved and it has the same name, e.g. "F:ArchivAlbenAnimal Collective[2009] Merriweather Post Pavilion\01. In The Flowers.flac".
What custom search path I have to type in?
foo_uie_lyrics3
Reply #436
From the change log:
"your lyrics must have the artist and track name in the filename for it to be found"
foo_uie_lyrics3
Reply #437
i moved the local directory for lyrics, changed the path also in "lyric saving" tab and changed it in local file search/properties. but it won't load the saved lyrics (saving lyrics is ok). do i have to change it elsewhere too to make it work? thanks.
anyone who can help me? when i copy some of the lyrics to the old directory, it's working ok, but i already changed the path in "local file search/properties" to the new one. any help is appreciated. thanks
foo_uie_lyrics3
Reply #438
thanks for that bro. works like a charm.
now for something maybe a little more difficult ;-)
is it possible to save the lyrics to file and tag?
my problem is that i prefer the lrc files for my rockboxed ipod, as it seems to have problems with lyrics in ID3 tags.
But on the other hand i do have 2 columns in my foobar setup that display a symbol if a lyric tag is available in a file (sync or unsync).
I was told it was not possible to have the column field check for the availability of the lrc or txt files.
so it would be nice to either have the plugin save the lyrics to file and tag, or after downloading the lrc file add something to the comment tag of the file saying "lyric".
cheers
foo_uie_lyrics3
Reply #440
First sorry for my english. I need your help i'm using Xch4ange by Br3tt Config. I changed the lyrics v2 -> v3. The ".dll" file I have copied to "...\appdata\roaming\foobar2000\user-components" and deleted the old one (v2). Now I have something like this:
when I use Menu -> View -> Lyric Show Panel v3 it opens a white window and there are the lyrics, but in the main window of foobar there are no lyrics (like on the screenshoot). What should i change? I can click there the right mouse button and use "refresh" but nothing happens.
foo_uie_lyrics3
Reply #441
All components install into their own directory AND they have a config file in the configuration directory. Not sure why you choose to manually install instead  of following standard practice of loading via the preferences>configuration>install. If it were me, I would delete all references to lyrics component in both locations and install properly. YMMV.
The author of your skin supports it via the site you downloaded it from.
foo_uie_lyrics3
Reply #442
man! you are on fire!
awesome work, i actually came here to report one tiny defect with the search order but it seems you fixed it after v0.2.0
i like the new custom search feature!
thnx
and thnx for the changelog too
components like these keep my boat sailing
foo_uie_lyrics3
Reply #443
I'm using the skin from http://gasdaumin.deviantart.com/#/d34fq3p
I like it quite a bit and there's a little search button the author added in to the skin. I got used to the button. It's really a cosmetic thing and I love the updated foo_uie_lyrics3. Going to experiment a bit more and see if I can't figure out the command. So far, nothing's worked though. Not CONTEXT or COMMAND.
foo_uie_lyrics3
Reply #444
I assume what you mean is that you want to show the lyric search dialogue box and that the button is in panel stack splitter. If that's the case use
COMMAND:View/Lyrics Show 3/Lyric search
foo_uie_lyrics3
Reply #445
Could you maybe make the plug-in save the lyrics when it picks one and downloads it instead of when the song's over? I'm using a custom lyrics display and I'm only using lyrics3 as a lyrics downloader, but I need the lyrics to be saved while the song's playing, not after, otherwise I don't have any lyrics displayed the first time.
foo_uie_lyrics3
Reply #446
A further question: the local sources (tag or file) are handled in same way like the online sources when they are queried? If prefer synced is enabled and a tag with unsynced lyrics exists then the component queries the online databases for lyrics? If so: Does the component consider the lyrics tag as best one? If not that would explain the behaviour that confused me. IMO the local sources should - when it comes to comparison in certain circumstances (depending by user settings) - always be considered as better than the lyrics from online sources.  <and so on>
Well, i am not sure if that is a good idea in the sense that many people will like it but it would make all the things clearer and remove such stuff like save, next and reload from context menu because they wouldn't be necessary anymore as result of reduced complexity: the strict seperation of online searching from local search that would require that lyrics founded in online sources are saved directly and not and end of song.
I mean that in the lyrics display ui-element only locally saved lyrics are displayed and never online lyrics: a local lyric is found/displayed or an online lyric (if no local exists) is searched/found/saved/diplayed. Isn't one main purpose of the component anyway the saving of tags/files? If someone nevertheless wants then to see all online lyrics then the online search window could be used for that and all online lyrics could be displayed inside that dialogue. That ends up with two lists one for local and one for online search where the order can be specified.
In my eyes that would make the component easily understandable. Important would just be to use textfile saving as default and when tag saving is choosen from preferences to display a popup warning that from now all tags are saved automatically without any user interaction. That is probably what all like to have (auto-saving) but in case of tags it should be mentioned in form of a warning.
foo_uie_lyrics3
Reply #447
Thank you! That seemed to do it. Oddly enough, it didn't work right away. I had to remove the component and then reinstall it and add it back into the panel stack splitter. I'm not sure exactly what changed.
The button works just fine now.
foo_uie_lyrics3
Reply #448
Version 0.2.3 uploaded.
New version of Minilyrics output plugin (0.2). You can update via the button provided in the Minilyrics search properties.
Changelog
- Fixed lyrdb.com results.
- Added lrc123.com database.
- Fixed sort order of lyric results (it now matches your preferences).
- Fixed garbage from the end of Minilyrics lyrics.
- Fixed maintaining new lines in fallback text when converting from the old text formatting.
- Multiple crash fixes.
Happy new year!
foo_uie_lyrics3
Reply #449
Thank you! It's perfect!
But, just one issue, I installed Minilyrics and put mlp_foolyr.dll in components folder but it doesn't work. Show that Minilyrics is not installed.
My mistake, the plugin is for Minilyrics. Sorry!
Congratulations about the plugin!
Only get lyrics from MiniLyrics if the program is running.
