Topic: foo_uie_lyrics3 (Read 513075 times) previous topic - next topic
  • Falstaff
foo_uie_lyrics3
Reply #50
happens on mousewheel scroll too ...
  • Falstaff
foo_uie_lyrics3
Reply #51
hmm, no more glitches this morning, can't reproduce it ... weird, i keep testing, but this morning, it looks perfect
EDIT: @#!ù!!! glitches are back (i've just modded background from plain to transparent and ...)
aera in the red rectangle. Glitches appears on track change, mouse move on the top left corner (this area) ...
  • Last Edit: 21 August, 2011, 04:21:50 AM by Falstaff
  • The vern
  • Developer
foo_uie_lyrics3
Reply #52
Does it just happen with a transparent background? Any other type of bg? Can you check if it happens with a very simple CUI/DUI layout?
Can anyone else confirm this? I can't reproduce it at all.
  • Falstaff
foo_uie_lyrics3
Reply #53
Sorry, my bad ! the problem was not with your plugin ^^ all is fine now, i've found what's wrong with my config by following your advise and testing on a simple CUI config
I apologize
  • The vern
  • Developer
foo_uie_lyrics3
Reply #54
I apologize
No worries. Your queries made me solve some flickering on scrolling anyway!
I've made some progress with the crashes I think, I managed to reproduce them, and I think I've solved them (still testing...)
The saving of the lyric offset has also been reinstated.
Will be releasing soon providing all is working!
  • Last Edit: 21 August, 2011, 11:44:13 AM by The vern
  • The vern
  • Developer
foo_uie_lyrics3
Reply #55
Version 0.1.4 uploaded.
Changes:
- Crash fixes on track change.
- Reinstated saving of the timestamp offset.
- Fixed flickering whilst scrolling lyrics in transparent mode.
- Grayed out 'Save' context menu item when save method is 'Don't save'.
To the one person that downloaded 0.1.4 before I posted here - I've made some more changes, so you need to re-download.
  • Last Edit: 21 August, 2011, 01:28:01 PM by The vern
  • Ran Sagy
foo_uie_lyrics3
Reply #56
Thanks for the updates. One suggestion on the archive format - Could you put the files in a components/ directory inside it?
This way foobar2000's component install option works with it.
  • tpijag
foo_uie_lyrics3
Reply #57
Works fine here as is. Foobar2000 1.1.8 b4
  • Jny
foo_uie_lyrics3
Reply #58
finally! thanks
what about new databases? lyricsplugin.com plyrics.com darklyrics.com
  • Andu
foo_uie_lyrics3
Reply #59
This works very well so far - thanks very much!
If I may humbly offer a feature suggestion - I find that available lyrics are continually getting better and better, but I struggle to upgrade saved "bad" rated lyrics to "medium" or better.  Any way to automatically search for lyrics and download and overwite existing lyrics in cases where something with a higher rating is found?  thanks
I second this request.
Also thanks a lot for taking up this project and doing a fine job so far.
  • tpijag
foo_uie_lyrics3
Reply #60
Edge case bug.
I've a number of track titles associated with live shows that may carry a slightly different name. For example Saint of Circumstance vs Saint of Circumstance >. The > denoting that it leads into a following track as part of a medley. I save all lyrics to a single user defined folder. Over time, this folder will have lyrics saved twice. One under the simple track name and one under trackname_.txt. The _ being windows automatic change of the > character.
This has not caused any issue with previous versions of lyric show but now there is an issue. Lyrics3 is not picking up that the tracks ending with a > already have a local lyric file and will go to the internet. Regardless of the 'save' setting. If I delete the file name lyric file of the medley track, lyrics3 will save the track lyric_.txt file appropriately. With a subsequent playing of the track, the lyric file with the _ .txt name will again not be found and lyrics3 will go to the net.
EDIT: In working through this I have been able to generate a couple of Foobar2000 crashes. One of the crash reports is below.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 7C918FEAh
Access violation, operation: write, address: 00000010h
Last win32 error: 6
Call path:
lyric_searcher::SearchProc=>lyric_loader::ReadThread
Code bytes (7C918FEAh):
7C918FAAh:  0B 64 A1 18 00 00 00 0F B6 4D 0B 89 88 84 0F 00
7C918FBAh:  00 38 1D 30 C0 97 7C 0F 85 CC 04 00 00 A0 48 C1
7C918FCAh:  97 7C F6 D8 57 1B C0 F7 D0 25 40 C1 97 7C 8B F8
7C918FDAh:  8B 46 10 3B C3 89 45 FC 0F 84 9E 00 00 00 8B 06
7C918FEAh:  FF 40 10 8B 45 FC 83 E0 01 89 45 E8 8B 06 FF 40
7C918FFAh:  14 F6 05 F0 02 FE 7F 01 0F 85 E6 92 02 00 39 5D
7C91900Ah:  E8 57 53 0F 85 AC DE 01 00 FF 75 FC E8 99 59 FF
7C91901Ah:  FF 3D 02 01 00 00 0F 84 53 93 02 00 3B C3 0F 8C
Stack (05ABFD98h):
05ABFD78h:  00000000 00000000 00000000 00000000
05ABFD88h:  00000000 00000000 00000000 00000000
05ABFD98h:  00000001 01DCEF50 7C901005 05ABFD90
05ABFDA8h:  05ABFF34 01D5F770 FFFFFFFF 05ABFDD8
05ABFDB8h:  01CF96C0 00000001 05ABFE10 00000001
05ABFDC8h:  00000001 00000000 05ABFE00 01CF9D74
05ABFDD8h:  05ABFE00 01CF9DDD 00000000 01DCE758
05ABFDE8h:  01DCE758 01CF9DEA 01D98018 FFFFFFFF
05ABFDF8h:  00000000 D12BBA70 05ABFE18 00000000
05ABFE08h:  000005A8 05ABFE34 7C90104B 00DCF020
05ABFE18h:  01D044E1 01DCF020 00000001 01DCEF50
05ABFE28h:  01D9802C 01DCF020 01D9C280 05ABFF40
05ABFE38h:  01D04C21 01DCEF50 3F088801 D12BBB30
05ABFE48h:  003D0000 01DCF7D8 06140710 00000001
05ABFE58h:  0000001A 01D9C280 FFC00000 3F088801
05ABFE68h:  00000001 000000BC 01000001 F1B55B6C
05ABFE78h:  85BBF100 8054AB38 05ABFE90 00000000
05ABFE88h:  7C9105C8 06140708 05ABFF5C 7C910551
05ABFE98h:  01DC1348 7C91056D 01D9AAE8 06140710
05ABFEA8h:  06140710 00000000 F1B55BAC 804E46B5
Registers:
EAX: 00000000, EBX: 00000000, ECX: 000005A8, EDX: 01DCF030
ESI: 01DCF020, EDI: 00000000, EBP: 05ABFE0C, ESP: 05ABFD98
Crash location:
Module: ntdll
Offset: 18FEAh
Symbol: "RtlpWaitForCriticalSection" (+5Bh)
Loaded modules:
foobar2000                      loaded at 00400000h - 005F3000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F5000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F02000h
Secur32                          loaded at 77FE0000h - 77FF1000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 7E410000h - 7E4A0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
DSOUND                          loaded at 73F10000h - 73F6C000h
ole32                            loaded at 774E0000h - 7761D000h
WINMM                            loaded at 76B40000h - 76B6D000h
VERSION                          loaded at 77C00000h - 77C08000h
UxTheme                          loaded at 5AD70000h - 5ADA8000h
dbghelp                          loaded at 59A60000h - 59B01000h
SHELL32                          loaded at 7C9C0000h - 7D1D5000h
zlib1                            loaded at 5A4C0000h - 5A4D4000h
shared                          loaded at 10000000h - 1002B000h
imagehlp                        loaded at 76C90000h - 76CB8000h
COMDLG32                        loaded at 763B0000h - 763F9000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
MSCTF                            loaded at 74720000h - 7476B000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
wdmaud                          loaded at 72D20000h - 72D29000h
msacm32                          loaded at 72D10000h - 72D18000h
MSACM32                          loaded at 77BE0000h - 77BF5000h
midimap                          loaded at 77BD0000h - 77BD7000h
mslbui                          loaded at 605D0000h - 605D9000h
OLEAUT32                        loaded at 77120000h - 771AB000h
foo_skip                        loaded at 00FB0000h - 00FDD000h
foo_autoupdate                  loaded at 00FF0000h - 01030000h
POWRPROF                        loaded at 74AD0000h - 74AD8000h
foo_dsp_delta                    loaded at 01040000h - 0105F000h
foo_fileops                      loaded at 01080000h - 010C7000h
foo_run                          loaded at 010F0000h - 0114F000h
foo_dynfil                      loaded at 01170000h - 01197000h
foo_input_std                    loaded at 012C0000h - 01429000h
foo_facets                      loaded at 01450000h - 01605000h
MSIMG32                          loaded at 76380000h - 76385000h
foo_playlist_manager            loaded at 01630000h - 01674000h
foo_queuecontents                loaded at 016A0000h - 0170D000h
foo_whatsnew                    loaded at 01730000h - 01770000h
foo_dbsearch                    loaded at 01790000h - 01800000h
foo_scheduler                    loaded at 01820000h - 018FC000h
foo_rgscan                      loaded at 01920000h - 0196B000h
foo_uie_tagger_mod              loaded at 01990000h - 019DE000h
foo_cdda                        loaded at 01A00000h - 01A4E000h
foo_utils                        loaded at 01A70000h - 01AB4000h
foo_random_pools                loaded at 01AE0000h - 01B0F000h
foo_preview                      loaded at 01B30000h - 01B52000h
foo_quicksearch                  loaded at 01B70000h - 01BC7000h
WindowsCodecs                    loaded at 53000000h - 530B4000h
foo_dsp_xgeq                    loaded at 01BF0000h - 01C1D000h
foo_verifier                    loaded at 01C40000h - 01C83000h
foo_uie_lyrics3                  loaded at 01CB0000h - 01DB0000h
WININET                          loaded at 771B0000h - 77256000h
foo_simplaylist                  loaded at 01E80000h - 01FCC000h
foo_playcount                    loaded at 01DF0000h - 01E2E000h
foo_albumlist                    loaded at 01FD0000h - 0202D000h
foo_texttools                    loaded at 02030000h - 02064000h
foo_osd                          loaded at 02090000h - 020C1000h
foo_simplaylist_manager          loaded at 020F0000h - 021C8000h
foo_jesus                        loaded at 021F0000h - 0220A000h
foo_dsp_std                      loaded at 02220000h - 02268000h
foo_abx                          loaded at 02290000h - 022C2000h
foo_converter                    loaded at 022F0000h - 0236B000h
foo_playlists_sort              loaded at 02390000h - 023A0000h
MSVCR90                          loaded at 78520000h - 785C3000h
foo_masstag                      loaded at 023C0000h - 02414000h
foo_playlist_attributes          loaded at 02440000h - 02494000h
foo_ui_columns                  loaded at 024C0000h - 02650000h
urlmon                          loaded at 7E1E0000h - 7E280000h
USP10                            loaded at 74D90000h - 74DFB000h
foo_ui_std                      loaded at 02720000h - 02839000h
foo_textdisplay                  loaded at 026B0000h - 026FB000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
browseui                        loaded at 75F80000h - 7607D000h
xpsp2res                        loaded at 20000000h - 202C5000h
KsUser                          loaded at 73EE0000h - 73EE4000h
wsock32                          loaded at 71AD0000h - 71AD9000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
RASAPI32                        loaded at 76EE0000h - 76F1C000h
rasman                          loaded at 76E90000h - 76EA2000h
NETAPI32                        loaded at 5B860000h - 5B8B4000h
TAPI32                          loaded at 76EB0000h - 76EDF000h
rtutils                          loaded at 76E80000h - 76E8E000h
sensapi                          loaded at 722B0000h - 722B5000h
USERENV                          loaded at 769C0000h - 76A73000h
mswsock                          loaded at 71A50000h - 71A8F000h
hnetcfg                          loaded at 662B0000h - 66308000h
wship6                          loaded at 58D40000h - 58D47000h
DNSAPI                          loaded at 76F20000h - 76F47000h
iphlpapi                        loaded at 76D60000h - 76D79000h
winrnr                          loaded at 76FB0000h - 76FB8000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
wshtcpip                        loaded at 71A90000h - 71A98000h
rasadhlp                        loaded at 76FC0000h - 76FC6000h
Stack dump analysis:
Address: 7C901005h (ntdll+1005h), symbol: "RtlEnterCriticalSection" (+0h)
Address: 01D5F770h (foo_uie_lyrics3+AF770h)
Address: 01CF96C0h (foo_uie_lyrics3+496C0h)
Address: 01CF9D74h (foo_uie_lyrics3+49D74h)
Address: 01CF9DDDh (foo_uie_lyrics3+49DDDh)
Address: 01CF9DEAh (foo_uie_lyrics3+49DEAh)
Address: 01D98018h (foo_uie_lyrics3+E8018h)
Address: 7C90104Bh (ntdll+104Bh), symbol: "RtlEnterCriticalSection" (+46h)
Address: 01D044E1h (foo_uie_lyrics3+544E1h)
Address: 01D9802Ch (foo_uie_lyrics3+E802Ch)
Address: 01D9C280h (foo_uie_lyrics3+EC280h)
Address: 01D04C21h (foo_uie_lyrics3+54C21h)
Address: 01000001h (foo_autoupdate+10001h)
Address: 7C9105C8h (ntdll+105C8h), symbol: "RtlFreeHeap" (+18Bh)
Address: 7C910551h (ntdll+10551h), symbol: "RtlFreeHeap" (+114h)
Address: 7C91056Dh (ntdll+1056Dh), symbol: "RtlFreeHeap" (+130h)
Address: 01D9AAE8h (foo_uie_lyrics3+EAAE8h)
Address: 100027D8h (shared+27D8h), symbol: "uPrintCrashInfo_OnEvent" (+B1h)
Address: 01D71750h (foo_uie_lyrics3+C1750h)
Address: 01D60DDCh (foo_uie_lyrics3+B0DDCh)
Address: 01D04CE6h (foo_uie_lyrics3+54CE6h)
Address: 01D60E19h (foo_uie_lyrics3+B0E19h)
Address: 01D36362h (foo_uie_lyrics3+86362h)
Address: 01D3E7B0h (foo_uie_lyrics3+8E7B0h)
Address: 01D363ECh (foo_uie_lyrics3+863ECh)
Address: 7C80B683h (kernel32+B683h), symbol: "GetModuleFileNameA" (+1B4h)
Address: 7C839AA8h (kernel32+39AA8h), symbol: "ValidateLocale" (+2B0h)
Address: 7C80B690h (kernel32+B690h), symbol: "GetModuleFileNameA" (+1C1h)
Address: 01D36388h (foo_uie_lyrics3+86388h)
Environment:
App: foobar2000 v1.1.8 beta 4
OS: Windows 5.1.2600 Service Pack 2 x86
CPU: Intel® Celeron® CPU 2.50GHz, features: MMX SSE SSE2
Audio: Realtek AC97 Audio
UI: Default User Interface 0.9.5
Components:
Core (2011-08-07 07:01:02 UTC)
   foobar2000 core 1.1.8 beta 4
foo_abx.dll (2009-06-07 12:25:26 UTC)
   ABX Comparator 1.3.4
foo_albumlist.dll (2011-08-07 06:59:30 UTC)
   Album List 4.5
foo_autoupdate.dll (2010-09-23 09:03:58 UTC)
   Automatic Updater 2 beta
foo_cdda.dll (2011-08-07 06:59:24 UTC)
   CD Audio Decoder 3.0
foo_converter.dll (2011-08-07 06:59:08 UTC)
   Converter 1.5
foo_dbsearch.dll (2007-01-26 03:58:48 UTC)
   Database Search 1.4
foo_dsp_delta.dll (2008-10-24 20:57:16 UTC)
   Noise Sharpening DSP 1.0.0
foo_dsp_std.dll (2011-08-07 06:59:34 UTC)
   Standard DSP Array 1.0
foo_dsp_xgeq.dll (2011-05-07 23:10:35 UTC)
   Graphic Equalizer 0.1.0
foo_dynfil.dll (2011-02-20 23:34:15 UTC)
   Dynamic Fields 1 beta 4
foo_facets.dll (2011-08-18 18:56:32 UTC)
   Facets 1.0
foo_fileops.dll (2011-08-07 06:58:34 UTC)
   File Operations 2.1.3
foo_input_std.dll (2011-08-07 06:59:14 UTC)
   Standard Input Array 1.0
foo_jesus.dll (2010-09-23 09:53:56 UTC)
   Autosave & Autobackup 10
foo_masstag.dll (2009-09-18 15:01:36 UTC)
   Masstagger 1.8.4
foo_osd.dll (2010-11-26 16:23:54 UTC)
   On-Screen Display GDI+ 1.68
foo_playcount.dll (2011-07-13 21:03:45 UTC)
   Playback Statistics 3.0.2
foo_playlist_attributes.dll (2010-05-23 19:22:21 UTC)
   Playlist Attributes 0.3.0
foo_playlist_manager.dll (2011-05-23 13:28:55 UTC)
   Playlist Manager 1.0.2
foo_playlists_sort.dll (2009-06-13 21:57:33 UTC)
   Playlist Sorter 0.1.9
foo_preview.dll (2011-07-14 16:25:57 UTC)
   Preview 1.4
foo_queuecontents.dll (2011-08-10 12:28:15 UTC)
   Queue Contents Editor 0.4.4
foo_quicksearch.dll (2011-05-29 16:35:49 UTC)
   Quick Search Toolbar 3.2
foo_random_pools.dll (2011-03-28 19:56:44 UTC)
   Random Pools 0.0.2.3
foo_rgscan.dll (2011-08-07 06:59:14 UTC)
   ReplayGain Scanner 2.1.2
foo_run.dll (2009-06-07 21:15:18 UTC)
   Run services 0.3.7
foo_scheduler.dll (2011-08-21 20:16:35 UTC)
   Scheduler 4.07
foo_simplaylist.dll (2011-08-18 18:56:32 UTC)
   SimPlaylist 1.0
foo_simplaylist_manager.dll (2011-08-18 18:56:32 UTC)
   SimPlaylist Manager 1.0
foo_skip.dll (2011-07-04 20:13:53 UTC)
   Skip Track 1.7.4
foo_textdisplay.dll (2011-05-29 16:35:39 UTC)
   Text Display UI Element 1.1 beta 1
foo_texttools.dll (2011-03-30 02:55:47 UTC)
   Text Tools 1.0.5
foo_ui_columns.dll (2011-04-26 21:39:17 UTC)
   Columns UI 0.3.8.8
foo_ui_std.dll (2011-08-07 06:59:36 UTC)
foo_uie_lyrics3.dll (2011-08-21 20:46:34 UTC)
   Lyric Show Panel 3 0.1.2
foo_uie_tagger_mod.dll (2010-11-19 21:33:08 UTC)
   Tagger Panel 1.2.4
foo_utils.dll (2008-02-09 04:26:58 UTC)
   Playlist Tools 0.6.2 beta 6
foo_verifier.dll (2009-10-05 17:39:20 UTC)
   File Integrity Verifier 1.1
foo_whatsnew.dll (2008-08-30 20:45:00 UTC)
   Feature Watcher 1.0.6
Recent events:
"*X Played" : 0:00.505493
"*XD XRate" : 0:00.274692
"Recent" : 0:00.698217
Startup time : 0:10.193112
Opening track for playback: "T:\@Music\Dead\1982-04-06 The Spectrum\203-Saint Of Circumstance-.mp3"
[foo_dynfil] Calculation took 26.01835 s
Opening track for playback: "T:\@Music\Dead\1982-04-06 The Spectrum\304-Sugar Magnolia.mp3"
Opening track for playback: "T:\@Music\Dead\1982-04-06 The Spectrum\202-Lost Sailor-.mp3"
  • Last Edit: 21 August, 2011, 05:07:57 PM by tpijag
  • hejiamei
foo_uie_lyrics3
Reply #61
Changes:
I am very happy of your work.
I have a suggestion, why won't you add " drag lrc to control playing progress" capability
http://cid-7c6fa1eb8fb8f2b7.skydrive.live....bd%e5%90%8d.png
another saying : "Drag lyric of a song controlling the playing progress of a song"
if you know chinese,I will say "??????????"
  • kode54
  • Administrator
foo_uie_lyrics3
Reply #62
That is not necessary for the component install system to work. The only issue that may come up, as another developer discovered, is that some ZIP software may unnecessarily create ZIP64 files, which foobar2000 does not support. I don't think there are any such problems here, though.
  • free30
foo_uie_lyrics3
Reply #63
I just wanted to login a say "thank you".
Everybody needs somebody as useful as you!  (lickass)
  • Hawk
foo_uie_lyrics3
Reply #64
finally! thanks
I second this request. When you listen to metal 'darklyrics.com' is a must.
  • Peti
foo_uie_lyrics3
Reply #65
Hello,
thanks for great component. But I'm missing one thing from the v2. I'm saving my lyrics as %filename%, and there is no field for custom lyric name in the local file search, only directory.
  • Dexter_prog
foo_uie_lyrics3
Reply #66
I can't believe I missed this. Finally someone trying to make a decent lyrics plugin. I am gonna try it now.
Edit: good! it doesn't produced cpu spikes like lyrics show 2.
finally! thanks
+1
Thanks !
+1
+ wikilyrics  I've added some lyrics to wikilyrics that are not in darklyrics (e.g.: In Vain's songs that are in Norwegian)
  • Last Edit: 22 August, 2011, 11:03:24 AM by Dexter_prog
  • YoPen
foo_uie_lyrics3
Reply #67
finally! thanks
+1
Thanks !
  • tpijag
foo_uie_lyrics3
Reply #68
Yes, everyone is real excited. Can we stop the bumping the thread with nothing other than zero content +1 posts?
What is the point of a +1 post quoting a quote of a +1 post.
  • Last Edit: 22 August, 2011, 11:19:02 AM by tpijag
  • Dexter_prog
foo_uie_lyrics3
Reply #69
11.
foo_uie_lyrics3
Reply #70
Hello,
Did you try fill title field with %filename% only but leave artist field blank?
  • Peti
foo_uie_lyrics3
Reply #71
Hello,
Didn't work, and I also don't want to break the online search.
  • gxavz1
foo_uie_lyrics3
Reply #72
adiós foo_uie_lyrics2
foo_uie_lyrics3
Reply #73
Thanks for picking this up! So far it seems like it's stable, very nice!
I have a couple of requests...
- When switching codepage, it doesn't seem to remember this. So the next time you load the song, the text is garbled and you have to select the codepage again.
- Currently my work around for this is to choose the codepage, copy the lyrics with timestamp, and open the lyrics in an external editor and paste->save. If saving the codepage is impossible, that process could be automated, at least.
- If I have multiple copies of lyrics files, I can't seem to choose a preferred one. For example if I have one in native language and one translated. It seems to default to whichever was saved first? Also, relatedly, it'd be nice if I could save multiple instances of lyrics... Maybe in the search dialog you should be allowed to give a custom filename?
- A "reload lyrics" button would be useful in case of editing. It seems like Next Lyric does the job too, but it's not that clear and you have to go through the alternatives (if any).
Anyway, those are all minor points, not very important at all. Biggest point is that this is working and seems crash free! Thanks again!
  • Shemuel
foo_uie_lyrics3
Reply #74
Cheers Vern! This is an aspect of foobar that has been conspicuous in its non-usability until now. Certainly will better my current stopgap of lyrics_grabber2 with item_details!
