Topic: foo_uie_lyrics3 (Read 513041 times) previous topic - next topic
foo_uie_lyrics3
Crash report:
This component may crash fb2k when you:
1. Fast continuously switch next or previous song;
2. Manually search lyrics, close the "lyric search" box before finish searching and mouse click other songs in playlist;
Crash dmp and txt files have been uploaded.
Test environment:
Win7 x64 sp1
WinXp sp3
fb2k 1.1.7 with both DUI and CUI
  • The vern
  • Developer
foo_uie_lyrics3
@ Erich_2:
Was the lyric you were playing saved in the tag? This would cause properties to open as the editor. If the lyric is saved as a file, it will open the external editor.
I will add the 'Esc' to exit the lyric search.
@holyrevenger:
noted, will look into.
  • Last Edit: 20 August, 2011, 04:33:16 AM by The vern
  • NEMO7538
  • Developer
foo_uie_lyrics3
Crashes here as well ....
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Edit: [/size]even when no panels are loaded
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 7C92B21Ah
Access violation, operation: write, address: 00000010h
Call path:
lyric_searcher::SearchProc=>lyric_loader::ReadThread
Code bytes (7C92B21Ah):
7C92B1DAh:  0B 64 A1 18 00 00 00 0F B6 4D 0B 89 88 84 0F 00
7C92B1EAh:  00 38 1D C4 E0 98 7C 0F 85 0C 89 FF FF A0 E8 E1
7C92B1FAh:  98 7C F6 D8 57 1B C0 F7 D0 25 E0 E1 98 7C 8B F8
7C92B20Ah:  8B 46 10 3B C3 89 45 FC 0F 84 9E 00 00 00 8B 06
7C92B21Ah:  FF 40 10 8B 45 FC 83 E0 01 89 45 E8 8B 06 FF 40
7C92B22Ah:  14 F6 05 F0 02 FE 7F 01 0F 85 3E 87 02 00 39 5D
7C92B23Ah:  E8 57 53 0F 85 F8 84 01 00 FF 75 FC E8 03 2D FF
7C92B24Ah:  FF 3D 02 01 00 00 0F 84 AB 87 02 00 3B C3 0F 8C
Stack (0FD9FD98h):
0FD9FD78h:  00000000 00000000 00000000 00000000
0FD9FD88h:  00000000 00000000 00000000 00000000
0FD9FD98h:  00000000 0167E978 7C911000 9DFA2AA8
0FD9FDA8h:  00000004 00000007 00000004 00350000
0FD9FDB8h:  00340031 00360032 00000000 00000000
0FD9FDC8h:  00000007 003D0000 00740000 0000002E
0FD9FDD8h:  00000073 00000000 00000000 00000007
0FD9FDE8h:  7C8106F9 18830000 00000064 0FD90000
0FD9FDF8h:  00000023 00000000 00000007 00000000
0FD9FE08h:  000004C4 0FD9FE34 7C911046 0067EA48
0FD9FE18h:  015B44E1 0167EA48 00000000 0167E978
0FD9FE28h:  00000000 0167EA48 0164C280 0FD9FF40
0FD9FE38h:  015B4C21 0167E978 3F2AAA00 C391711D
0FD9FE48h:  003D0000 0167ED08 188308C8 00000000
0FD9FE58h:  0000001A 0164C280 00000006 3F2AAA00
0FD9FE68h:  00000000 00000006 016E6830 806E6900
0FD9FE78h:  0256DD25 00000000 0FD9FE90 00000000
0FD9FE88h:  7C9200B8 188308C0 0FD9FF5C 7C920041
0FD9FE98h:  01671348 7C92005D 0164AAE8 188308C8
0FD9FEA8h:  188308C8 8053582D 87396D90 00000038
Registers:
EAX: 00000000, EBX: 00000000, ECX: 000004C4, EDX: 0167EA58
ESI: 0167EA48, EDI: 00000000, EBP: 0FD9FE0C, ESP: 0FD9FD98
Crash location:
Module: ntdll
Offset: 1B21Ah
Symbol: "RtlpWaitForCriticalSection" (+5Bh)
Loaded modules:
foobar2000                      loaded at 00400000h - 005F2000h
ntdll                            loaded at 7C910000h - 7C9C9000h
kernel32                        loaded at 7C800000h - 7C906000h
COMCTL32                        loaded at 77390000h - 77493000h
msvcrt                          loaded at 77BE0000h - 77C38000h
ADVAPI32                        loaded at 77DA0000h - 77E4C000h
RPCRT4                          loaded at 77E50000h - 77EE3000h
Secur32                          loaded at 77FC0000h - 77FD1000h
GDI32                            loaded at 77EF0000h - 77F39000h
USER32                          loaded at 7E390000h - 7E421000h
SHLWAPI                          loaded at 77F40000h - 77FB6000h
DSOUND                          loaded at 73E60000h - 73EBC000h
ole32                            loaded at 774A0000h - 775DE000h
VERSION                          loaded at 77BD0000h - 77BD8000h
WINMM                            loaded at 76AE0000h - 76B0F000h
UxTheme                          loaded at 5B090000h - 5B0C8000h
SHELL32                          loaded at 7C9D0000h - 7D1F5000h
zlib1                            loaded at 5A4C0000h - 5A4D3000h
shared                          loaded at 10000000h - 1002B000h
imagehlp                        loaded at 76C40000h - 76C68000h
dbghelp                          loaded at 5D3F0000h - 5D491000h
COMDLG32                        loaded at 76340000h - 7638A000h
CRYPT32                          loaded at 779E0000h - 77A77000h
MSASN1                          loaded at 77A80000h - 77A92000h
gdiplus                          loaded at 4EB80000h - 4ED2B000h
IMM32                            loaded at 76320000h - 7633D000h
MSCTF                            loaded at 74690000h - 746DC000h
WINTRUST                        loaded at 76BE0000h - 76C0E000h
wdmaud                          loaded at 72C70000h - 72C79000h
msacm32                          loaded at 72C60000h - 72C68000h
MSACM32                          loaded at 77BB0000h - 77BC5000h
midimap                          loaded at 77BA0000h - 77BA7000h
apphelp                          loaded at 77B50000h - 77B72000h
msctfime                        loaded at 75140000h - 7516E000h
foo_masstag                      loaded at 01050000h - 010A4000h
foo_rgscan                      loaded at 010C0000h - 0110A000h
foo_dsp_resampler                loaded at 01130000h - 01172000h
foo_softplaylists                loaded at 011A0000h - 01208000h
foo_albumlist                    loaded at 01230000h - 0128D000h
foo_freedb2                      loaded at 012B0000h - 012F0000h
foo_vis_shpeck                  loaded at 01310000h - 01351000h
MSIMG32                          loaded at 76310000h - 76315000h
foo_utils                        loaded at 01380000h - 013C4000h
foo_playlist_revive              loaded at 013F0000h - 0141C000h
foo_audioscrobbler              loaded at 01440000h - 01473000h
foo_httpcontrol                  loaded at 014A0000h - 0150D000h
WS2_32                          loaded at 719F0000h - 71A07000h
WS2HELP                          loaded at 719E0000h - 719E8000h
WSOCK32                          loaded at 71A10000h - 71A1A000h
MPR                              loaded at 71A60000h - 71A72000h
foo_uie_lyrics3                  loaded at 01560000h - 01660000h
OLEAUT32                        loaded at 770E0000h - 7716B000h
WININET                          loaded at 77AA0000h - 77B4B000h
foo_dsp_std                      loaded at 016A0000h - 016E8000h
foo_uie_wsh_panel_mod            loaded at 01830000h - 018D7000h
foo_fileops                      loaded at 01900000h - 01947000h
foo_run                          loaded at 01970000h - 019CF000h
foo_input_std                    loaded at 019F0000h - 01B53000h
foo_runcmd                      loaded at 01B80000h - 01BB3000h
foo_ui_columns                  loaded at 01BE0000h - 01D6E000h
USP10                            loaded at 753C0000h - 7542B000h
foo_out_asio                    loaded at 01DA0000h - 01DD6000h
foo_quicksearch                  loaded at 01E00000h - 01E57000h
WindowsCodecs                    loaded at 74490000h - 74543000h
foo_converter                    loaded at 01E80000h - 01EFB000h
foo_plorg                        loaded at 01F20000h - 01F4A000h
MSVCP100                        loaded at 78050000h - 780B9000h
MSVCR100                        loaded at 78AA0000h - 78B5E000h
foo_scheduler                    loaded at 01F70000h - 0204B000h
POWRPROF                        loaded at 74A40000h - 74A48000h
foo_cdda                        loaded at 02070000h - 020BE000h
foo_uie_esplaylist              loaded at 020E0000h - 02149000h
foo_navigator                    loaded at 02170000h - 021A4000h
foo_osd                          loaded at 021D0000h - 02201000h
foo_dsp_delta                    loaded at 02230000h - 0224F000h
foo_ui_std                      loaded at 02270000h - 02388000h
foo_facets                      loaded at 023B0000h - 02565000h
foo_uie_biography                loaded at 02590000h - 025E7000h
foo_playcount                    loaded at 02610000h - 0264E000h
SXS                              loaded at 77210000h - 772C1000h
CLBCATQ                          loaded at 76F80000h - 76FFF000h
COMRes                          loaded at 77000000h - 770D4000h
jscript                          loaded at 75BE0000h - 75C5D000h
xpsp2res                        loaded at 0AE90000h - 0B16A000h
browseui                        loaded at 75F10000h - 7600D000h
mswsock                          loaded at 71990000h - 719D0000h
hnetcfg                          loaded at 62E40000h - 62E99000h
wshtcpip                        loaded at 719D0000h - 719D8000h
wm_hooks                        loaded at 0B280000h - 0B28E000h
asio4all                        loaded at 0F660000h - 0F793000h
KSUSER                          loaded at 73E30000h - 73E34000h
SETUPAPI                        loaded at 778E0000h - 779D8000h
DNSAPI                          loaded at 76ED0000h - 76EF7000h
rasadhlp                        loaded at 76F70000h - 76F76000h
RASAPI32                        loaded at 76E90000h - 76ECC000h
rasman                          loaded at 76E40000h - 76E52000h
NETAPI32                        loaded at 6FEE0000h - 6FF35000h
TAPI32                          loaded at 76E60000h - 76E8F000h
rtutils                          loaded at 76E30000h - 76E3E000h
msv1_0                          loaded at 77C40000h - 77C65000h
cryptdll                        loaded at 76730000h - 7673C000h
iphlpapi                        loaded at 76D10000h - 76D29000h
sensapi                          loaded at 72220000h - 72225000h
USERENV                          loaded at 76960000h - 76A16000h
urlmon                          loaded at 7DF30000h - 7DFD3000h
Stack dump analysis:
Address: 7C911000h (ntdll+1000h), symbol: "RtlEnterCriticalSection" (+0h)
Address: 7C8106F9h (kernel32+106F9h), symbol: "CreateThread" (+22h)
Address: 7C911046h (ntdll+1046h), symbol: "RtlEnterCriticalSection" (+46h)
Address: 015B44E1h (foo_uie_lyrics3+544E1h)
Address: 0164C280h (foo_uie_lyrics3+EC280h)
Address: 015B4C21h (foo_uie_lyrics3+54C21h)
Address: 016E6830h (foo_dsp_std+46830h)
Address: 7C9200B8h (ntdll+100B8h), symbol: "RtlFreeHeap" (+18Bh)
Address: 7C920041h (ntdll+10041h), symbol: "RtlFreeHeap" (+114h)
Address: 7C92005Dh (ntdll+1005Dh), symbol: "RtlFreeHeap" (+130h)
Address: 0164AAE8h (foo_uie_lyrics3+EAAE8h)
Address: 100027D8h (shared+27D8h), symbol: "uPrintCrashInfo_OnEvent" (+B1h)
Address: 01621750h (foo_uie_lyrics3+C1750h)
Address: 01610DDCh (foo_uie_lyrics3+B0DDCh)
Address: 015B4CE6h (foo_uie_lyrics3+54CE6h)
Address: 01610E19h (foo_uie_lyrics3+B0E19h)
Address: 015E6362h (foo_uie_lyrics3+86362h)
Address: 015EE7B0h (foo_uie_lyrics3+8E7B0h)
Address: 015E63ECh (foo_uie_lyrics3+863ECh)
Address: 7C80B729h (kernel32+B729h), symbol: "GetModuleFileNameA" (+1BAh)
Address: 7C839AD8h (kernel32+39AD8h), symbol: "ValidateLocale" (+2B0h)
Address: 7C80B730h (kernel32+B730h), symbol: "GetModuleFileNameA" (+1C1h)
Address: 015E6388h (foo_uie_lyrics3+86388h)
Environment:
App: foobar2000 v1.1.7
OS: Windows 5.1.2600 Service Pack 3 x86
CPU: IntelĀ® Core™ Duo CPU      T2400  @ 1.83GHz, features: MMX SSE SSE2 SSE3
Audio: USB Sound Blaster HD; SoundMAX HD Audio; USB Sound Blaster HD SPDIF
UI: Default User Interface 0.9.5
Components:
Core (2011-06-05 09:16:20 UTC)
   foobar2000 core 1.1.7
foo_albumlist.dll (2011-06-05 09:14:24 UTC)
   Album List 4.5
foo_audioscrobbler.dll (2010-08-15 09:06:41 UTC)
   Audioscrobbler 1.4.7
foo_cdda.dll (2011-06-05 09:14:20 UTC)
   CD Audio Decoder 3.0
foo_converter.dll (2011-06-05 09:13:50 UTC)
   Converter 1.5
foo_dsp_delta.dll (2010-09-08 17:30:54 UTC)
   Noise Sharpening DSP 1.0.0
foo_dsp_resampler.dll (2010-12-19 10:00:00 UTC)
   SoX Resampler 0.5.5
foo_dsp_std.dll (2011-06-05 09:14:22 UTC)
   Standard DSP Array 1.0
foo_facets.dll (2011-08-20 07:36:56 UTC)
   Facets 1.0
foo_fileops.dll (2011-06-05 09:13:12 UTC)
   File Operations 2.1.3
foo_freedb2.dll (2011-06-05 09:13:14 UTC)
   freedb Tagger 0.6.4
foo_httpcontrol.dll (2011-08-20 07:36:56 UTC)
   HTTP Control 0.97.12
foo_input_std.dll (2011-06-05 09:13:58 UTC)
   Standard Input Array 1.0
foo_masstag.dll (2010-08-23 06:30:35 UTC)
   Masstagger 1.8.4
foo_navigator.dll (2010-03-02 08:43:15 UTC)
   Navigator 0.64
foo_osd.dll (2011-03-06 08:37:57 UTC)
   On-Screen Display GDI+ 1.69
foo_out_asio.dll (2011-03-27 18:50:37 UTC)
   ASIO support 1.2.7
foo_playcount.dll (2011-08-20 07:36:56 UTC)
   Playback Statistics 3.0.2
foo_playlist_revive.dll (2011-03-27 18:21:20 UTC)
   Playlist Revive 0.2
foo_plorg.dll (2011-05-05 17:19:18 UTC)
   Playlist Organizer 2.4
foo_quicksearch.dll (2011-05-29 08:31:09 UTC)
   Quick Search Toolbar 3.2
foo_rgscan.dll (2011-06-05 09:13:54 UTC)
   ReplayGain Scanner 2.1.2
foo_run.dll (2010-08-23 06:33:17 UTC)
   Run services 0.3.7
foo_runcmd.dll (2010-08-23 06:32:46 UTC)
   Run Command 1.1
foo_scheduler.dll (2011-01-19 19:38:16 UTC)
   Scheduler 4.06
foo_softplaylists.dll (2011-02-05 10:10:05 UTC)
   Soft Playlists 2011-02-05
foo_ui_columns.dll (2010-09-11 07:54:56 UTC)
   Columns UI 0.3.8.7
foo_ui_std.dll (2011-06-05 09:14:24 UTC)
foo_uie_biography.dll (2010-08-22 08:24:11 UTC)
   Biography View 0.4.2.2
foo_uie_esplaylist.dll (2011-05-03 15:03:22 UTC)
   EsPlaylist 0.1.3.8
foo_uie_lyrics3.dll (2011-08-20 07:37:42 UTC)
   Lyric Show Panel 3 0.1.2
foo_uie_wsh_panel_mod.dll (2010-08-22 08:38:42 UTC)
   WSH Panel Mod 1.3.6
foo_utils.dll (2010-12-25 17:39:38 UTC)
   Playlist Tools 0.6.2 beta 6
foo_vis_shpeck.dll (2010-08-22 20:21:46 UTC)
   Shpeck - Winamp vis plugins wrapper 0.3.7
  • Last Edit: 20 August, 2011, 05:03:08 AM by NEMO7538
  • The vern
  • Developer
foo_uie_lyrics3
@NEMO7538:
What were you doing just before it crashed?
  • Erich_2
foo_uie_lyrics3
@ Erich_2: Was the lyric you were playing saved in the tag? This would cause properties to open as the editor. If the lyric is saved as a file, it will open the external editor.
Ah, now it's clear to me.
  • NEMO7538
  • Developer
foo_uie_lyrics3
Reply #30
Just changing track....
  • Speech
foo_uie_lyrics3
Thanks for stepping up and taking over the lyrics panel.
I would like to see two things back and I have one question, the most important for me being the first one:
- The old lyrics panel had multiple search patterns, but this new one always seems to look for files called "artist - title" on the hard disk.  In my experience, this excludes files called only "title", either because the artist is unidentified, or because you have the same song interpreted by different artists.
- There is no button to import and export settings, especially from the lyrics panel 2. Is it possible for you to put it back?
- Where is the "Gradient fill background (you choose the colour of the corners of the panel)" option?
Keep up the good work!
  • The vern
  • Developer
foo_uie_lyrics3
Version 0.1.3 uploaded.
Changes:
- Potential crash fix for track change and closing lyric search during search (although it's difficult to know if I have actually solved it without the crash dumps, does anyone know how to get hold of them?)
- Added escape to close lyric search.
- Added double click to load lyrics.
@Speech:
I personally had a lot of problems with trying load lyrics by searching for just the title. As I said in my first post, I've made some changes to the file searching as the old system would load lyrics for the wrong song. The changes I've made will undoubtedly need to be edited to satisfy everyone's needs. I will look into seeing if I can do something about this.
The gradient background is in the 'Background' drop down box in the settings dialogue.
I removed the import/export buttons whilst moving GUI stuff around - I'll add it back ASAP.
  • Last Edit: 20 August, 2011, 06:48:59 AM by The vern
foo_uie_lyrics3
Reply #33
@The vern
Thx for your hard work, the ver.0.1.3 is more stable.
Another question:
In context menu, "Save" can not save timestamp offset I've just made by choosing "Adjust offset"?
  • Robertina
  • Banned
foo_uie_lyrics3
Reply #34
As far as I know you have to contact one of the HA admins via PM in order to get access to crash logs etc submitted in conjunction with your component.
By the way, congratulations on your new plugin!
Edit: typo
  • Last Edit: 20 August, 2011, 07:55:16 AM by Robertina
  • lvqcl
  • Developer
foo_uie_lyrics3
Reply #35
"Getting useful information out of crash reports" : http://www.hydrogenaudio.org/forums/index....showtopic=76296
  • mobyduck
foo_uie_lyrics3
Reply #36
Thanks for your work on this plugin.
A couple of feature requests:
- would it be possible to add lyricsdb to the list of online DB sources?
- I'd like to have the possibility to switch between currently playing and selected track to view/search lyrics. A configurable option (like albumart panel has) would be great: you can choose Left, Middle o Double click on the panel to change the behaviour.
And finally one question: can you briefly describe what are the Associations?
Regards.
Alessandro
  • sollniss
foo_uie_lyrics3
Reply #37
Is it possible to save the lyrics into an external DB like the playcount plugin does? I'd rather not have the lyrics written into my files.
The very act of observing, influences what happens.
  • marc2003
  • Developer
foo_uie_lyrics3
Reply #38
eh? by default, it saves lyrics for each track to a folder named lyrics inside your foobar2000 profile so your files won't get touched. it only saves to tags if you explicitly tell it to.
  • Last Edit: 20 August, 2011, 08:59:45 AM by marc2003
  • lokioki
foo_uie_lyrics3
Reply #39
How can I make the lyrics be still instead of moving ?
e. nvm layout editing mode didnt show the settings thing!
  • Last Edit: 20 August, 2011, 10:12:29 AM by lokioki
  • Andreasvb
foo_uie_lyrics3
Reply #40
Thank you very much for adding a blend with background option!
I'm using it as an album art panel with some song info and now it looks more clean compared to the previous component.
However, now I can't seem to turn off the lyrics in a panel, so an option for turning off lyrics and only use the fallback text for a specific panel would be nice.
  • The vern
  • Developer
foo_uie_lyrics3
Reply #41
This will be sorted in the next release.
I'll look into it.
This is unlikely to happen in the very near future, as it would require quite a substantial amount of effort and the benefits would be small. (That's not to say I won't add it later).
An association is essentially a link between a particular lyric and a song (saved in a xml file). If the association search is enabled, it will then load the lyric that the association points to. The lyric must be saved as a file. To add an association, click 'Associate lyrics' in the right click menu.
I didn't add this, it was already there....
using it as an album art panel.....can't seem to turn off the lyrics in a panel
This panel isn't really designed to do this, but you can disable lyric searching/loading by removing all the search sources and making sure the save method is 'Don't Save'.
  • Last Edit: 20 August, 2011, 02:29:32 PM by The vern
  • zaede
foo_uie_lyrics3
Reply #42
Same here. Sometimes crash after track change !!!
foobar2000 best player ever
  • The vern
  • Developer
foo_uie_lyrics3
Reply #43
Are you using the latest version (0.1.3)?
  • lo-fi
foo_uie_lyrics3
Reply #44
crash on track change. version 0.1.3
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 02CC25AEh
Access violation, operation: read, address: 0000001Ch
Call path:
entry=>app_mainloop
Code bytes (02CC25AEh):
02CC256Eh:  07 C7 45 84 01 00 00 00 C7 45 B4 02 00 00 00 8B
02CC257Eh:  55 B0 89 95 78 FF FF FF 89 7D 8C 89 7D 90 89 7D
02CC258Eh:  94 8B 4D B4 2B C1 50 89 85 7C FF FF FF 51 8D 45
02CC259Eh:  B8 50 8D 4D D4 C6 45 FC 0C E8 D4 9C FA FF 8B 16
02CC25AEh:  8B 52 1C 68 10 0E CC 02 8D 4D 8C 51 50 8B CE C6
02CC25BEh:  45 FC 0D FF D2 83 7D CC 08 C6 45 FC 0C 72 0C 8B
02CC25CEh:  45 B8 50 E8 46 28 00 00 83 C4 04 8B 4D 90 8B 45
02CC25DEh:  8C 2B C8 C1 F9 03 89 7D A4 85 C9 0F 84 35 01 00
Stack (0012F6B4h):
0012F694h:  E58CA6F8 00000000 0000000C BC082BF8
0012F6A4h:  0012FC50 00009A13 A9957B64 BF816B7E
0012F6B4h:  789705EC CE0417C0 02D5BC50 002A0601
0012F6C4h:  02D01418 0AF42238 0000012C 00000200
0012F6D4h:  0000012B 00000000 00000001 052675C0
0012F6E4h:  00000000 005A8BC8 00000000 00000000
0012F6F4h:  00000000 00000000 02D01AC8 039EE350
0012F704h:  00000001 00000001 00000050 00000000
0012F714h:  00000000 00000020 0012F730 7FFDF000
0012F724h:  00000000 00000001 00000007 00000000
0012F734h:  0AF40048 00040000 000017C0 0012F760
0012F744h:  00000072 00000077 CE0417C0 789705EC
0012F754h:  0012FA10 02CF54CE 0000000C 0012FA1C
0012F764h:  02CB9F1C FFFFFF00 78970890 00000000
0012F774h:  02D5BC50 002A0608 00000000 00000000
0012F784h:  0012F808 00000000 000C0000 0012F808
0012F794h:  0012F77C 0012F808 0000004E 002405E6
0012F7A4h:  0012F788 FFFFFFFF 0012F8F8 00E73800
0012F7B4h:  00E78238 FFFFFF00 0112F7F0 00000000
0012F7C4h:  00000000 00000000 0012F808 00000000
Registers:
EAX: 0012F718, EBX: 00000000, ECX: 00000000, EDX: 00000000
ESI: 02D5D928, EDI: 00000000, EBP: 0012F760, ESP: 0012F6B4
Crash location:
Module: foo_uie_lyrics3
Offset: 825AEh
Loaded modules:
foobar2000                      loaded at 00400000h - 005F3000h
ntdll                            loaded at 7C910000h - 7C9C8000h
kernel32                        loaded at 7C800000h - 7C903000h
snxhk                            loaded at 64D00000h - 64D34000h
COMCTL32                        loaded at 773A0000h - 774A3000h
DSOUND                          loaded at 73E90000h - 73EEC000h
ole32                            loaded at 774B0000h - 775EE000h
WINMM                            loaded at 76B00000h - 76B2E000h
UxTheme                          loaded at 5B150000h - 5B188000h
dbghelp                          loaded at 5D4B0000h - 5D551000h
SHELL32                          loaded at 7E6A0000h - 7EEC1000h
zlib1                            loaded at 5A4C0000h - 5A4D4000h
imagehlp                        loaded at 76C50000h - 76C78000h
COMDLG32                        loaded at 76360000h - 763AA000h
CRYPT32                          loaded at 77A50000h - 77AE6000h
MSASN1                          loaded at 77AF0000h - 77B02000h
gdiplus                          loaded at 4EBA0000h - 4ED4B000h
IMM32                            loaded at 76340000h - 7635D000h
RocketDock                      loaded at 00E30000h - 00E42000h
PSAPI                            loaded at 76BB0000h - 76BBB000h
AnvirHook54                      loaded at 00E70000h - 00E86000h
WINTRUST                        loaded at 76BF0000h - 76C1E000h
wdmaud                          loaded at 72CA0000h - 72CA9000h
msacm32                          loaded at 72C90000h - 72C98000h
msctfime                        loaded at 75160000h - 7518E000h
KatMouseS                        loaded at 01010000h - 0101F000h
vlmshlp                          loaded at 01040000h - 01047000h
mhook                            loaded at 01050000h - 01057000h
foo_uie_albumlist                loaded at 01160000h - 011A3000h
foo_scheduler                    loaded at 011D0000h - 012AB000h
POWRPROF                        loaded at 74A60000h - 74A68000h
foo_fileops                      loaded at 012D0000h - 01317000h
foo_audioscrobbler              loaded at 01340000h - 01373000h
foo_uie_wsh_panel_mod            loaded at 013A0000h - 01459000h
OLEAUT32                        loaded at 770F0000h - 7717B000h
Msimg32                          loaded at 76330000h - 76335000h
foo_jesus                        loaded at 014B0000h - 014CA000h
foo_masstag                      loaded at 015F0000h - 01644000h
foo_input_monkey                loaded at 01670000h - 016B9000h
foo_input_std                    loaded at 016E0000h - 01849000h
foo_run                          loaded at 01870000h - 018CF000h
foo_uie_biography                loaded at 018F0000h - 01947000h
foo_musicbrainz                  loaded at 01970000h - 019CB000h
foo_converter                    loaded at 019F0000h - 01A6B000h
foo_abx                          loaded at 01A90000h - 01AC2000h
foo_benchmark                    loaded at 01AF0000h - 01B1D000h
foo_wlm                          loaded at 01B40000h - 01B61000h
foo_unpack                      loaded at 01B90000h - 01BBE000h
foo_bitcompare                  loaded at 01BE0000h - 01C08000h
foo_verifier                    loaded at 01C30000h - 01C73000h
foo_ui_std                      loaded at 01CA0000h - 01DB9000h
foo_uie_playlists_dropdown      loaded at 01DE0000h - 01E1C000h
foo_albumlist                    loaded at 01E40000h - 01E9D000h
foo_stopafteralbum              loaded at 01EC0000h - 01EF5000h
foo_utils                        loaded at 01F20000h - 01F64000h
foo_freedb2                      loaded at 01F90000h - 01FD0000h
foo_playcount                    loaded at 01FF0000h - 0202E000h
foo_texttools                    loaded at 02050000h - 02084000h
foo_vis_shpeck                  loaded at 020B0000h - 020F1000h
foo_uie_console                  loaded at 02120000h - 0213A000h
foo_input_tak                    loaded at 02160000h - 021A4000h
tak_deco_lib                    loaded at 021C0000h - 021E0000h
foo_wave_seekbar                loaded at 022F0000h - 024BA000h
WS2_32                          loaded at 71A30000h - 71A47000h
WS2HELP                          loaded at 71A20000h - 71A28000h
foo_playlist_tree_mod            loaded at 024E0000h - 02559000h
foo_quicksearch                  loaded at 02580000h - 025D7000h
WindowsCodecs                    loaded at 4CCE0000h - 4CD93000h
foo_out_asio                    loaded at 02600000h - 02636000h
foo_uie_lyrics2                  loaded at 02660000h - 0274E000h
WININET                          loaded at 3FA00000h - 3FAE6000h
Normaliz                        loaded at 02760000h - 02769000h
urlmon                          loaded at 44430000h - 44563000h
iertutil                        loaded at 400A0000h - 40289000h
foo_uie_color                    loaded at 029A0000h - 029BF000h
foo_customdb                    loaded at 029E0000h - 02A85000h
foo_dsp_std                      loaded at 02AA0000h - 02AE8000h
foo_navigator                    loaded at 02B10000h - 02B44000h
foo_uie_tagger_mod              loaded at 02B70000h - 02BB1000h
foo_uie_vis_peakmeter_spectrum  loaded at 02BE0000h - 02C1F000h
foo_uie_lyrics3                  loaded at 02C40000h - 02D40000h
foo_dsp_BassExciter_EN          loaded at 02D60000h - 02D85000h
foo_uie_ptb                      loaded at 02DB0000h - 02DD5000h
foo_burninate                    loaded at 02E00000h - 02E3E000h
foo_rgscan                      loaded at 02E60000h - 02EAB000h
foo_ui_columns                  loaded at 02ED0000h - 03060000h
USP10                            loaded at 74D20000h - 74D8B000h
foo_cdda                        loaded at 03090000h - 030DE000h
foo_dop                          loaded at 03100000h - 032D0000h
SETUPAPI                        loaded at 778F0000h - 779E7000h
QUARTZ                          loaded at 747A0000h - 7490F000h
foo_softplaylists                loaded at 03300000h - 03368000h
CLBCATQ                          loaded at 76F90000h - 7700F000h
COMRes                          loaded at 77010000h - 770E0000h
SXS                              loaded at 76980000h - 76A31000h
appHelp                          loaded at 77B10000h - 77B32000h
ashShell                        loaded at 64E40000h - 64E62000h
msi                              loaded at 06150000h - 06591000h
GROOVEEX                        loaded at 49460000h - 49869000h
MSVCR90                          loaded at 78520000h - 785C3000h
MSVCP90                          loaded at 78480000h - 7850E000h
ATL90                            loaded at 78E20000h - 78E4B000h
office                          loaded at 06680000h - 06A9A000h
GrooveIntlResource              loaded at 06AD0000h - 07350000h
cscui                            loaded at 779F0000h - 77A45000h
CSCDLL                          loaded at 765B0000h - 765CD000h
browseui                        loaded at 75F30000h - 7602D000h
d3d9                            loaded at 4FD10000h - 4FEB6000h
d3d8thk                          loaded at 6DEA0000h - 6DEA6000h
d3dx9_42                        loaded at 078E0000h - 07AC5000h
d3dx10_42                        loaded at 07530000h - 075A0000h
dciman32                        loaded at 73B40000h - 73B46000h
CFNetwork                        loaded at 07DD0000h - 07E69000h
CoreFoundation                  loaded at 07E80000h - 07F4B000h
MSVCR80                          loaded at 78130000h - 781CB000h
pthreadVC2                      loaded at 07F60000h - 07F70000h
WSOCK32                          loaded at 71A50000h - 71A5A000h
objc                            loaded at 07F70000h - 07F8D000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
libdispatch                      loaded at 07FA0000h - 07FAE000h
icuin40                          loaded at 094C0000h - 095BD000h
icuuc40                          loaded at 095D0000h - 096B1000h
icudt40                          loaded at 4AD00000h - 4BA5E000h
ASL                              loaded at 096D0000h - 096E1000h
SQLite3                          loaded at 09700000h - 09763000h
iphlpapi                        loaded at 76D20000h - 76D39000h
xpsp2res                        loaded at 09A10000h - 09CE6000h
iTunesMobileDevice              loaded at 09CF0000h - 09E31000h
mswsock                          loaded at 719D0000h - 71A10000h
hnetcfg                          loaded at 66740000h - 66799000h
wshtcpip                        loaded at 71A10000h - 71A18000h
asio4all                        loaded at 0A460000h - 0A593000h
KSUSER                          loaded at 73E60000h - 73E64000h
RASAPI32                        loaded at 76EA0000h - 76EDC000h
rasman                          loaded at 76E50000h - 76E62000h
NETAPI32                        loaded at 597F0000h - 59845000h
TAPI32                          loaded at 76E70000h - 76E9F000h
rtutils                          loaded at 76E40000h - 76E4E000h
USERENV                          loaded at 76630000h - 766E5000h
sensapi                          loaded at 72250000h - 72255000h
cryptdll                        loaded at 76750000h - 7675C000h
rasadhlp                        loaded at 76F80000h - 76F86000h
DNSAPI                          loaded at 76EE0000h - 76F07000h
mdnsNSP                          loaded at 64000000h - 64021000h
Address: 02D01418h (foo_uie_lyrics3+C1418h)
Address: 005A8BC8h (foobar2000+1A8BC8h)
Address: 02D01AC8h (foo_uie_lyrics3+C1AC8h)
Address: 02CF54CEh (foo_uie_lyrics3+B54CEh)
Address: 02CB9F1Ch (foo_uie_lyrics3+79F1Ch)
Address: 00E73800h (AnvirHook54+3800h)
Address: 00E78238h (AnvirHook54+8238h)
Address: 00E731DBh (AnvirHook54+31DBh), symbol: "ExtendSaveDialogs" (+994h)
Address: 7E3EB02Ch (USER32+5B02Ch), symbol: "GetRawInputDeviceInfoA" (+11Fh)
Address: 00E73131h (AnvirHook54+3131h), symbol: "ExtendSaveDialogs" (+8EAh)
Address: 7E3A8EECh (USER32+18EECh), symbol: "DefWindowProcW" (+1CCh)
Address: 7E3A8EFCh (USER32+18EFCh), symbol: "DefWindowProcW" (+1DCh)
Address: 7C91E473h (ntdll+E473h), symbol: "KiUserCallbackDispatcher" (+13h)
Address: 7E3EAFCEh (USER32+5AFCEh), symbol: "GetRawInputDeviceInfoA" (+C1h)
Address: 7E3994BEh (USER32+94BEh), symbol: "GetWindowLongA" (+61h)
Address: 7E3C215Bh (USER32+3215Bh), symbol: "DeregisterShellHookWindow" (+1E9Bh)
Address: 00E729FCh (AnvirHook54+29FCh), symbol: "ExtendSaveDialogs" (+1B5h)
Address: 00E727D6h (AnvirHook54+27D6h)
Address: 7E3AB401h (USER32+1B401h), symbol: "CallNextHookEx" (+3Bh)
Address: 00E73455h (AnvirHook54+3455h), symbol: "ExtendSaveDialogs" (+C0Eh)
Address: 7E3B1923h (USER32+21923h), symbol: "UnhookWinEvent" (+77h)
Address: 7E3AB330h (USER32+1B330h), symbol: "MoveWindow" (+92h)
Address: 7E398B26h (USER32+8B26h), symbol: "GetWindowThreadProcessId" (+A6h)
Address: 02CAC7A0h (foo_uie_lyrics3+6C7A0h)
Address: 02CF49B5h (foo_uie_lyrics3+B49B5h)
Address: 02CAC7E7h (foo_uie_lyrics3+6C7E7h)
Address: 7E398734h (USER32+8734h), symbol: "GetDC" (+6Dh)
Address: 7E3A3CE4h (USER32+13CE4h), symbol: "EnumDisplaySettingsA" (+27Dh)
Address: 7E3C048Fh (USER32+3048Fh), symbol: "DeregisterShellHookWindow" (+1CFh)
Address: 7E3A3D08h (USER32+13D08h), symbol: "EnumDisplaySettingsA" (+2A1h)
Address: 7E3A3B30h (USER32+13B30h), symbol: "EnumDisplaySettingsA" (+C9h)
Address: 7E3A3D3Ah (USER32+13D3Ah), symbol: "DefDlgProcW" (+0h)
Address: 7E3AB326h (USER32+1B326h), symbol: "MoveWindow" (+88h)
Address: 7E3A3D5Ch (USER32+13D5Ch), symbol: "DefDlgProcW" (+22h)
Address: 7E398816h (USER32+8816h), symbol: "GetDC" (+14Fh)
Address: 7E398830h (USER32+8830h), symbol: "GetDC" (+169h)
Address: 7E3A8EA0h (USER32+18EA0h), symbol: "DefWindowProcW" (+180h)
Address: 7E3AB317h (USER32+1B317h), symbol: "MoveWindow" (+79h)
Address: 7E3A8EB0h (USER32+18EB0h), symbol: "DefWindowProcW" (+190h)
Address: 7E3A7562h (USER32+17562h), symbol: "CallMsgFilterW" (+54h)
Address: 7E3A8E53h (USER32+18E53h), symbol: "DefWindowProcW" (+133h)
Address: 7E3994D2h (USER32+94D2h), symbol: "GetWindowLongA" (+75h)
Address: 7E3A8F10h (USER32+18F10h), symbol: "DefWindowProcW" (+1F0h)
Address: 7E3991C6h (USER32+91C6h), symbol: "GetMessageW" (+0h)
Address: 7C91FE30h (ntdll+FE30h), symbol: "RtlSetLastWin32Error" (+0h)
Address: 7E3989F0h (USER32+89F0h), symbol: "GetWindowLongW" (+14Ah)
Address: 7E398A10h (USER32+8A10h), symbol: "DispatchMessageW" (+Fh)
Address: 0046E571h (foobar2000+6E571h)
Address: 0046F4C2h (foobar2000+6F4C2h)
Address: 0057FDACh (foobar2000+17FDACh)
Address: 0057FD90h (foobar2000+17FD90h)
Address: 0057FD74h (foobar2000+17FD74h)
Address: 7C9201DBh (ntdll+101DBh), symbol: "RtlAllocateHeap" (+117h)
Address: 7C91E920h (ntdll+E920h), symbol: "strchr" (+113h)
Address: 7C9201E0h (ntdll+101E0h), symbol: "RtlAllocateHeap" (+11Ch)
Address: 00539C1Ch (foobar2000+139C1Ch)
Address: 0054084Dh (foobar2000+14084Dh)
Address: 7ED7C28Fh (SHELL32+6DC28Fh)
Address: 00433440h (foobar2000+33440h)
Address: 0053DC60h (foobar2000+13DC60h)
Address: 7E9D05C7h (SHELL32+3305C7h)
Address: 0055B3FBh (foobar2000+15B3FBh)
Address: 00575C2Ch (foobar2000+175C2Ch)
Address: 1000281Eh (shared+281Eh), symbol: "uCallStackTracker::uCallStackTracker" (+31h)
Address: 0046F6DCh (foobar2000+6F6DCh)
Address: 00543A27h (foobar2000+143A27h)
Address: 005AB3A0h (foobar2000+1AB3A0h)
Address: 0053D46Ah (foobar2000+13D46Ah)
Address: 00539EEEh (foobar2000+139EEEh)
Address: 00539EE8h (foobar2000+139EE8h)
Address: 7ED7C3E7h (SHELL32+6DC3E7h)
Address: 005677B4h (foobar2000+1677B4h)
Address: 005677B8h (foobar2000+1677B8h)
Address: 005642B1h (foobar2000+1642B1h)
Address: 7E9D0BB7h (SHELL32+330BB7h)
Address: 0055B9CDh (foobar2000+15B9CDh)
Address: 0053B2A2h (foobar2000+13B2A2h)
Address: 00400000h (foobar2000+0h)
Address: 7ED7C33Fh (SHELL32+6DC33Fh)
Address: 7E9D0B17h (SHELL32+330B17h)
Address: 7C817077h (kernel32+17077h), symbol: "RegisterWaitForInputIdle" (+49h)
Address: 7C817080h (kernel32+17080h), symbol: "RegisterWaitForInputIdle" (+52h)
Address: 0053B2F5h (foobar2000+13B2F5h)
Address: 0057005Ch (foobar2000+17005Ch)
Address: 004E0049h (foobar2000+E0049h)
Address: 004F0044h (foobar2000+F0044h)
Address: 00530057h (foobar2000+130057h)
Address: 005C0073h (foobar2000+1C0073h)
Address: 01CB29DEh (foo_ui_std+129DEh)
Address: 004B0063h (foobar2000+B0063h)
Address: 00530022h (foobar2000+130022h)
Address: 00500069h (foobar2000+100069h)
Address: 01CBF9F4h (foo_ui_std+1F9F4h)
Address: 00410072h (foobar2000+10072h)
Address: 00540079h (foobar2000+140079h)
Address: 00430022h (foobar2000+30022h)
Address: 005C003Ah (foobar2000+1C003Ah)
Address: 00490057h (foobar2000+90057h)
Address: 0044004Eh (foobar2000+4004Eh)
Address: 0057004Fh (foobar2000+17004Fh)
Address: 005C0053h (foobar2000+1C0053h)
Address: 0053006Eh (foobar2000+13006Eh)
Address: 00530078h (foobar2000+130078h)
Address: 004D005Ch (foobar2000+D005Ch)
Address: 004D005Fh (foobar2000+D005Fh)
Address: 0057002Eh (foobar2000+17002Eh)
Address: 0047002Eh (foobar2000+7002Eh)
Address: 005F0066h (foobar2000+1F0066h)
Address: 005F0077h (foobar2000+1F0077h)
Address: 004D002Eh (foobar2000+D002Eh)
Address: 005F0036h (foobar2000+1F0036h)
Address: 005F0073h (foobar2000+1F0073h)
Address: 005F0039h (foobar2000+1F0039h)
Environment:
App: foobar2000 v1.1.8 beta 4
CPU: AMD Athlon™ Processor LE-1640, features: 3DNow!ex MMX SSE SSE2 SSE3
Audio: HD Audio rear output 2; C-Media USB Audio
UI: Columns UI 0.3.8.8
Components:
Core (2011-08-07 07:01:02 UTC)
   foobar2000 core 1.1.8 beta 4
foo_abx.dll (2009-06-07 12:25:26 UTC)
   ABX Comparator 1.3.4
foo_albumlist.dll (2011-08-07 06:59:30 UTC)
   Album List 4.5
foo_audioscrobbler.dll (2010-06-04 14:27:04 UTC)
foo_benchmark.dll (2009-01-01 01:23:04 UTC)
   Decoding Speed Test 1.1
foo_bitcompare.dll (2008-12-05 21:08:02 UTC)
   Binary Comparator 1.2
foo_burninate.dll (2011-02-25 23:13:30 UTC)
   Audio CD Writer 3.0.3
foo_cdda.dll (2011-08-07 06:59:24 UTC)
foo_converter.dll (2011-08-07 06:59:08 UTC)
   Converter 1.5
foo_customdb.dll (2010-03-04 18:10:54 UTC)
   Custom Database 0.1.0_beta1
foo_dop.dll (2011-05-27 23:44:50 UTC)
   iPod manager 0.6.9.4
foo_dsp_BassExciter_EN.dll (2011-01-11 17:38:18 UTC)
   Real Bass Exciter EFX Module (en-US) 1.0
foo_dsp_std.dll (2011-08-07 06:59:34 UTC)
foo_fileops.dll (2011-08-07 06:58:34 UTC)
foo_freedb2.dll (2011-08-07 06:58:34 UTC)
   freedb Tagger 0.6.4
foo_input_monkey.dll (2011-02-25 23:13:30 UTC)
   Monkey's Audio Decoder 2.1.5
foo_input_std.dll (2011-08-07 06:59:14 UTC)
foo_input_tak.dll (2010-01-10 01:11:58 UTC)
   TAK Decoder 0.4.4
foo_jesus.dll (2010-09-25 20:16:46 UTC)
   Autosave & Autobackup 10
foo_masstag.dll (2009-09-18 15:01:36 UTC)
   Masstagger 1.8.4
foo_musicbrainz.dll (2011-06-03 16:55:13 UTC)
   MusicBrainz Tagger 0.3 beta 2
foo_navigator.dll (2010-02-20 01:13:12 UTC)
   Navigator 0.64
foo_out_asio.dll (2011-07-29 18:00:28 UTC)
   ASIO support 1.2.7
foo_playcount.dll (2011-07-13 16:59:32 UTC)
foo_playlist_tree_mod.dll (2010-01-09 14:15:56 UTC)
   Playlist Tree Mod Panel 3.0.6.3 NoScheme [Jan  9 2010 - 15:15:40]
foo_quicksearch.dll (2011-05-29 20:50:57 UTC)
foo_rgscan.dll (2011-08-07 06:59:14 UTC)
foo_run.dll (2009-06-07 20:15:18 UTC)
   Run services 0.3.7
foo_scheduler.dll (2011-01-22 17:42:08 UTC)
   Scheduler 4.06
foo_softplaylists.dll (2011-02-10 18:22:01 UTC)
foo_stopafteralbum.dll (2011-06-04 18:49:07 UTC)
   Stop after album 3.0
foo_texttools.dll (2010-09-02 17:21:35 UTC)
   Text Tools 1.0.5
foo_ui_columns.dll (2011-03-07 04:30:30 UTC)
   Columns UI 0.3.8.8
foo_ui_std.dll (2011-08-07 06:59:36 UTC)
foo_uie_albumlist.dll (2009-06-13 22:49:19 UTC)
   Album list panel 0.3.5
foo_uie_biography.dll (2010-06-28 02:50:10 UTC)
foo_uie_color.dll (2011-06-21 19:05:48 UTC)
   Color 0.4
foo_uie_console.dll (2009-08-29 16:06:24 UTC)
   Console panel 0.4
foo_uie_lyrics2.dll (2010-04-13 01:19:24 UTC)
   Lyric Show Panel 2 0.4.6.15
foo_uie_lyrics3.dll (2011-08-20 17:02:32 UTC)
   Lyric Show Panel 3 0.1.3
foo_uie_playlists_dropdown.dll (2009-09-24 05:44:46 UTC)
   Playlists Dropdown 0.7.6
foo_uie_ptb.dll (2008-02-16 07:45:33 UTC)
   Playback Toolbars 0.2
foo_uie_tagger_mod.dll (2009-09-20 21:49:42 UTC)
   Tagger Mod Panel Window 1.1.0.6 [Sep 20 2009 - 23:33:24]
foo_uie_vis_peakmeter_spectrum.dll (2008-04-20 02:18:50 UTC)
   Peakmeter Spectrum Visualisation 0.2.0.0 beta
foo_uie_wsh_panel_mod.dll (2010-09-09 07:35:08 UTC)
   WSH Panel Mod 1.3.7
foo_unpack.dll (2011-08-07 06:58:48 UTC)
   ZIP/GZIP/RAR Reader 1.6
foo_utils.dll (2008-02-09 05:26:58 UTC)
foo_verifier.dll (2009-10-05 16:39:20 UTC)
   File Integrity Verifier 1.1
foo_vis_shpeck.dll (2011-01-06 16:47:56 UTC)
foo_wave_seekbar.dll (2010-04-25 05:35:42 UTC)
   Waveform seekbar 0.2.12
foo_wlm.dll (2010-09-20 04:25:50 UTC)
   Windows Live Messenger Notifier 1.1.7
Recent events:
Custom Database: index url_idx already exists (1)
Custom Database: Completed
Seekbar: taking Direct3D9 path.
Seekbar: Frontend initialized.
Autoplaylists initialized in: 0:00.342756
"Recientes" : 0:00.342721
Startup time : 0:04.902240
iPod manager: Error: AMDeviceNotificationSubscribe returned E8000063
Opening track for playback: "D:\Musica\Ariel Pink's Haunted Graffiti\(2010) Before Today\01. Hot Body Rub.tak"
Opening track for playback: "D:\Musica\Ariel Pink's Haunted Graffiti\(2010) Before Today\02. Bright Lit Blue Skies.tak"
last.fm/user/boces
  • ortin
foo_uie_lyrics3
Reply #45
The vern
What is used as a source of cover art? Coz it seems to show only folder.jpg and not using foobar's Album art settings.
  • The vern
  • Developer
foo_uie_lyrics3
Reply #46
The vern
It may be that it is using the old version of the album art retriever. I haven't really changed that bit of code, so I'm not sure, I'll look into it.
  • Falstaff
foo_uie_lyrics3
Reply #47
T H A N K  Y O U  ! ! !
  • maXelo
foo_uie_lyrics3
Reply #48
thanks for the component....looks and works like a charm!
  • Falstaff
foo_uie_lyrics3
Reply #49
bug report : when playing and lyrics scrolling, if i select the context menu entry 'Panel preferences', a glitch is displayed and may flash on the top left corner of the panel, see screenchot below (stay displayed a few seconds before vaporing...)
it looks like the %artist% info normaly displayed when no lyrics are found ...
