Topic: foo_uie_lyrics3 (Read 902302 times) previous topic - next topic
Re: foo_uie_lyrics3
Reply #2075
@veksha thanks for the new release!! Everything seems ok now :-)
Re: foo_uie_lyrics3
Reply #2076
good. now the proxy. Do you really need this functionality? it is not implemented and as far as I know it will not work with system proxy settings, but you can try. I never worked with proxies/vpn so it will take time if I decide to implement it.
Re: foo_uie_lyrics3
Reply #2077
Oh I don't need the proxy at all, It was only for testing purpose !  And I'm very happy with the current features :-)
Re: foo_uie_lyrics3
Reply #2078
@veksha ,   Getting a crash when i  set a large playlist to scan for lyrics. (using your latest version  but happened in previous ver also ).  Dont know if this dump file any use.   Working fine under play/ small search
This is great plugin   :D
This is a dump from yesterday so probably on previousversion think i only went to latest to-day.   The error is the same looking at a dump from to-day
If you need any more info give me a shout.
Re: foo_uie_lyrics3
Reply #2079
my lyric show panel cant't find even one lyric...
i dont't know what i do wrong...
someone can help me?
Re: foo_uie_lyrics3
Reply #2080
@sonvolt
thanks for your feedback.
can you search for artist "Shyy" and title "Her, Her Landscape".
metallum source crashes on it with v0.54. I will fix it in v0.55
can it be the cause of your crash?
Re: foo_uie_lyrics3
Reply #2083
@veksha:  running .54 have noticed an issue with Deezer;  whenever it produces a hit, it becomes near-impossible to "Next lyrics" past it to another source.  Sometimes after hitting "Next lyrics" 10+ times will finally get the next source to be called up.  Sometimes, it will cycle between slightly different Deezer lyrics versions but remains stuck. This is reproducible each time;  I didn't see this in .52  Could you check it please?  Thanks!
Re: foo_uie_lyrics3
Reply #2084
I did the test above (with "Shyy"):
- v0.54 => metallum crash
- v0.55 => no crash.
This confirms the fix works! Thanks!!
Re: foo_uie_lyrics3
Reply #2085
nice. I hope @sonvolt's crash was of the same nature :)
thanks for testing, @zafer, can you confirm what @sveakul said about deezer is failing for you too? because I can not reproduce it.
Re: foo_uie_lyrics3
Reply #2086
as we all know :) since version .51 we have multiple results from each source. when you press "Next lyrics" LSP will load next deezer result. there can be a lot of deezer results for popular songs. are you sure that it actually stuck like "request is waiting for response"? sorry for stupid question, i have to make sure. :D
Re: foo_uie_lyrics3
Reply #2087
veksha:  just updated to .55 and still same issue with Deezer.  It DOES sometimes pull multiple slightly different results for the same song as designed to do, but whether this happens or there is only one  version, it still will resist "Next lyrics" for 10+ times before finally allowing things to move on.  I guess it's possible it's just still trying to get more results for the same song before it "hands over" which makes it APPEAR stuck.  I'm going to roll back to .52 and see what happens there, I don't recall this behavior at all with that version.  But hey maybe I got into some bad ale, haha..  I'll let you know later what happens with .52, it might be a little while.
Re: foo_uie_lyrics3
Reply #2088
@veksha ,
Sorry my crash is different I'm afraid  , updated to 55 and reran my scan  crashed after about 20 mins  , dump attatched for you
Probably doesn't help you much , but bug wasn't present when i came onboard at  rel 42 , ran thru my entire collection without a crash.
Re: foo_uie_lyrics3
Reply #2089
veksha:  actually .52 shows the same behavior on Deezer so I must have just hit some exceptions previously.  Now, I had it immediately advance after finding a Rush song, but on another after finding 2 versions it did the "stall" again.  My guess is the the finding multiple versions procedure sometimes makes it stall/wait long/enter a queue, depending on the complexity of the search and/or server load at Deezer.
So I'm just updating to .55 and moving Deezer to the bottom of the search list, so when lyrics are only found there, I'll know there's no REASON to do "Next lyrics" for that song.  That'll work for me.  BTW, Minilyrics working fine now, thanks!
Re: foo_uie_lyrics3
Reply #2090
@sveakul the behavior you're describing seems the consequence of retrieving multiple lyrics from a single source. It was introduced in 0.52 or just before. It is an important feature imho.
Re: foo_uie_lyrics3
Reply #2091
@veksha I hope this doesn't double post with above, I tried to edit but it appears it didn't take the edits. So here is what I wrote:
I confirm that Minilyrics and Deezer (especially) are the two problematic sources, because they retrieve many lyrics.
There seem to be no way to filter repeated or bad lyrics. Disabling multiple lyrics is not a good solution because chances are we'll miss the good lyrics... So the workaround found by @sveakul (putting Deezer at the end) seems the best solution.
However, I could not reproduce when Deezer retrieves 1 source because when I use the Lyrics Search window, I always get many results from Deezer (still searching for a song for which deezer finds only 1 lyrics, but that seems impossible)... So I really think that the impression of stalling is due to having many lyrics that are exact copies of  each other.
Re: foo_uie_lyrics3
Reply #2092
@veksha ,  ran your prepared version  , but don't have a  foo_mulitisource.log file  anywhere , looked in both my foobar2000  folder under program files(x86) and the one under users/appdata/roaming ..
Re: foo_uie_lyrics3
Reply #2093
@veksha ,    sorry mulit  jut  typo , was looking for correct file ,   my  foobar   ee file is in my program files(x86) dir sorry no log file there.
Started scan of entire library , refreshed program (x86) dir   definately  no log file  ,
will  redownload and do delete before installing ..
Re: foo_uie_lyrics3
Reply #2094
Run foobar2000.exe as Administrator.
(You can answer me in Private Messages)
I should've make it write to %temp% directory. if you are afraid of launching foobar2000 with admin rights, tell me - i will prepare another version that writes to temp dir.
Re: foo_uie_lyrics3
Reply #2095
Yep, have been well aware of that (.51 had it first).
Yes, I agree with you that the explanation may be that Deezer often has a LOT of copies of the identical lyrics--they must allow users to upload at will and then they store everything.  Sometimes you can "Next" through multiple copies where not one word changes.  I also agree that the multiple lyrics feature on its own is too valuable to get rid of because of just one site, and so far I'm perfectly happy with the solution of just keeping Deezer as the last place looked at.
Re: foo_uie_lyrics3
Reply #2098
@veksha
Dump  from hung search
Presume it's to big over 100mb  zipped
Re: foo_uie_lyrics3
Reply #2099
Runningg Foobar as Admin can cause other Problems. E.g. Artist and Album Images are not shown in in the Mod-UI DarkOne4Mod by tedgo.
I reverted back to Multisource 0.50, because Minilyrics is still working here in my Region.
