Topic: foo_uie_lyrics3 (Read 521746 times) previous topic - next topic
  • godrick
foo_uie_lyrics3
Reply #925
Beta 2 seems stable - I don't use the features that seem to have received the most attention in the betas, but I don't see any regression issues with the rest of the component.
I defer to you to prioritize or even consider the following, but it would be great if there was an additional feature to synchronizing lyrics in the lyrics editor.  Right now we can add a offset that globally adjusts all lines in a lyric, or adjust a single line with "synchronize selected line", but I find myself wishing there was a way to "synchronize selected and adjust all subsequent lines" or "adjust all subsequent lines" to efficiently deal with lyrics that are off by different amounts as a song progresses.  If there is a way to do this with existing functionality other than manually adjusting each and every subsequent line, please let me know how.  I tried inserting a line of [offset:-1000] in the middle of a lyric to see if that would act on just the lines that follow, but the editor applied it globally.
Also, I think I recall that prior to your excellent editor features, one could manually drag the lyric display to focus on another line, but double click in the display to return focus to the proper line.  Double clicking (or the context menu) now brings up the editor.  If there is a way to return the panel display focus to the current line with a click or context menu that I've missed, please let me know, and if not, it would be great to have a way with a context menu to do so.  Thanks again for your efforts!
  • Last Edit: 09 August, 2012, 12:03:52 PM by godrick
  • The vern
foo_uie_lyrics3
Reply #926
You can reset the offset of the lyrics with: right click->reset offset.
Your suggestion about the lyric editor is interesting, I'll have a think about it.
  • godrick
foo_uie_lyrics3
Reply #927
Yes, "reset offset" repositions the display, but I believe it also wipes out any global offset (if I'm incorrect on this, please let me know).  It would be great to be able to refocus the display to the current timestamp without setting the global offset to zero.  Thanks!
  • The vern
foo_uie_lyrics3
Reply #928
That is how the dragging/scrolling works, by changing the global offset. It doesn't save the value of the offset before dragging/scrolling so there's no way of reverting to how it was (unless you remember it yourself).
  • godrick
foo_uie_lyrics3
Reply #929
Thanks for explaining.  It would not be worth it to change the "reset offset" selection or create anything new to do what I suggested for refocusing, especially if you can do something like "adjust current and all subsequent lines" (which, if used on the first line of a lyric, could be used instead of a global offset and thus avoid the loss of a global offset when using the "reset offset" selection).
  • j_t
foo_uie_lyrics3
Reply #930
- Changes to the fading of the lyric lines - they actually now fade (I'd broken it previously). It also now fades the next line whilst the current line is fading out - so there shouldn't be problems with no line being highlighted if there's a long time gap between different lines. Also at very slow scroll speeds, no fading occurs.
With 0.3.6 beta 2 my highlighting issues at slow scroll speeds are completely fixed! Thank you very much!
  • StealthX
foo_uie_lyrics3
Reply #931
I was using the last stable version and it just shows a blank page for darklyrics.com lyrics even though they are there and it used to display them fine. Just installed 0.3.6 beta 2 and it is still not displaying lyrics from darklyrics.com just a blank page. Also going to about current lyrics it shows the correct URL for the lyrics but it just doesn't show any text on foobar.
  • Last Edit: 09 August, 2012, 10:36:02 PM by StealthX
foo_uie_lyrics3
Reply #932
@supercoolman
fixed is: displaying wrong saved lyrics, if %album% + %title% are the same (to make it clearer)
come to think of it: all my saved lyrics will be found; there's not one lyric that I've saved, that won't be displayed
                            maybe you should run "batch association" once more
good luck
you only said "%album% + %title% are identical". now that you provided more info, I think we are talking two different issue.
I've uploaded 0.3.6 beta 2 to the google code page: http://code.google.com/p/foo-uie-lyrics3/downloads/list
Changelog:
- Hopeful fix for the album and title file search problems.
- The local file search is no longer forceably enabled if you are saving to file (this is not necessary anymore).
tested beta2 and didn't find any regression. it found all local LRC files just like 0.3.4. I don't use online search, so I can't speak for that part.
the artist and title are picked up properly in the "lyrics search panel", but album column remains empty. not sure if that's expected. however, "lyrics search panel" is able to find LRC files.
"lyrics search panel" can only pick up LRC file for some songs through "Association Search", but I didn't set any association. Not sure why "Local File Search" doesn't pick up anything for those songs
  • The vern
foo_uie_lyrics3
Reply #933
@StealthX:
Thanks for reporting, it's now fixed.
@SUPERCOOLMAN:
I'm glad the searching issues are fixed. Yes, the album columns are meant to be empty. Associations are set automatically at the end of a track or when a lyric is saved, you can edit them in preferences.
foo_uie_lyrics3
Reply #934
@StealthX:
@SUPERCOOLMAN:
This is my setting, do you know where/when is association saved/created? I only want "Local File Search" or "Tag Search". If both of them failed, then either I made a mistake for LRC on the songs or there are issues in foo_uie_lyrics3.
  • StealthX
foo_uie_lyrics3
Reply #935
@StealthX:
Thanks! When will the new version be out, and is there a webpage now or something with the latest version?
foo_uie_lyrics3
Reply #936
Maybe I'm doing something wrong, but when I edit lyrics, it seems like they don't get saved? Is this a permissions issue maybe? I'm on Win7.
  • michtar
foo_uie_lyrics3
Reply #937
In beta:
- saving lyrics now works
- small problem: first line of the lyrics is always highlighted
  • StealthX
foo_uie_lyrics3
Reply #938
Can you put out a beta that fixes the Dark Lyrics problems?
  • The vern
foo_uie_lyrics3
Reply #939
I'm about to, just working on other things atm (the sdk)
  • Last Edit: 14 August, 2012, 12:21:19 PM by The vern
  • The vern
foo_uie_lyrics3
Reply #940
0.3.6 beta 3 uploaded. http://code.google.com/p/foo-uie-lyrics3/downloads/list
Changes:
- Fixed dark lyrics.
- Fixed the problem with always highlighting the first lyric line with slow scrolling speeds.
- Essentially finished the sdk (required a fairly large number of changes to all of the sources).
I've also uploaded a different component to test the sdk (called foo_lyricsource). This should be installed as a completely separate fb2k component and should add a new source to the list in lyrics3 preferences. The source itself doesn't actually do anything useful (it just displays part of a google search for the lyrics), but merely exists to confirm the sdk is working properly. I would very much appreciate any feedback from testing this (as I've never written an sdk before so it's new territory for me!)
  • Last Edit: 14 August, 2012, 01:16:31 PM by The vern
  • BrutuZ
foo_uie_lyrics3
Reply #941
I was eager to test the SDK to fetch from custom sources, but then I installed and re-read it to find out I can't program the custom sources yet. Damn you anxiety xD
Thanks for the updates The Vern, looking forward to release version of the SDK
  • godrick
foo_uie_lyrics3
Reply #942
No regression issues so far, so great job!  I dutifully added "My custom 1" as a source to test it, then forgot about it until I noticed web page source code happily scrolling in the panel, whereupon I noticed that all of the songs I played without any previously saved lyrics tags in the last few hours had all saved the html gibberish of the test source to tags - just like I told it to.  Easily deleted, and I feel comfortable stating the search, display and save-to-tag portions seem to work pretty well for the new code!
  • culinko
foo_uie_lyrics3
Reply #943
thanks The vern, i could finally update from the 0.3.4. debug version  no issues so far, great work!
  • Last Edit: 16 August, 2012, 11:47:07 PM by culinko
  • The vern
foo_uie_lyrics3
Reply #944
Many thanks for the feedback.
I've uploaded the SDK: http://code.google.com/p/foo-uie-lyrics3/downloads/list
The zip uploaded includes the lyric source sdk and the source of foo_lyricsource, both of which have loads of comments explaining the code. If you have any queries/problems let me know.
  • Last Edit: 17 August, 2012, 12:06:00 PM by The vern
  • The vern
foo_uie_lyrics3
Reply #945
New version of both the SDK and lyrics3 uploaded (0.3.6 beta 4).
This is to fix crashes when using sources built with the SDK in older versions of lyrics3. Any sources built with the old SDK will not work with this or later versions of lyrics3.
  • Emerelle
foo_uie_lyrics3
Reply #946
Any chance that manipulation of text size is possible somehow or will be implemented?
  • The vern
foo_uie_lyrics3
Reply #947
@Emerelle:
You can do this already through either your UI's settings or the panels own settings page (right click on the panel->Panel Preferences)
  • Emerelle
foo_uie_lyrics3
Reply #948
Oops, I missed that one in the preferences! I'm sorry, must be the heat over here.
  • dgemu12
foo_uie_lyrics3
Reply #949
I think I've seen this before, but is there anyway of appending the offset to the actually number inside the brackets.
e.g.
offset synch of 36000
would lead to
[01:13.34] to [00:38:00]
[01:17.16] to [00:40:00]
and all other lines within the lrc.
This would allow, certain player able to render this, while playing.  I thought this was already encoded but don't see an option only reset offset which just renders the offset to 0, but no other changes.
  • Last Edit: 20 August, 2012, 05:34:44 PM by dgemu12
