Topic: foo_uie_lyrics3 (Read 519404 times) previous topic - next topic
foo_uie_lyrics3
Reply #1375
Evening all, i've been getting this error since the last update, it doesn't happen all the time.
<?xml version="1.0" encoding="UTF-8" ?>
<result errmsg="Search ID or Code error!" errcode="32006"></result>
Any one knows what might be causing this issue? This happens with the automatically search, with manual search (ie. "Next lyrics") it doesn't.
OK, so regarding this issue, it was related to "Online DB: Timestamped 2"
I've got this problem as well. It does however happen with manual search as well, if I choose lyrics from "Timestamped 2". What is "Timestamped 2" anyway? I mean what is the online source for that scraper? What db/webpage is it?
  • arabeh
foo_uie_lyrics3
Reply #1376
Hi, I think this is a really great plugin, and I am sure I will enjoy using it, but I was wondering if there is any way to disable the auto search/download of lyrics from the internet? I can remove all online sources in preferences, but then if I do want lyrics from the internet I need to manually re-enable them. What would be really neat is if I could leave the online sources there, and just set it to only search when I prompt it to (like through right click->search for lyric..).
Is there anyway to do this currently? If not, is there a possibility of it in the future?
Thank you for your hard work
i would like to see this option too
i would also like to see this option
  • weberesc
foo_uie_lyrics3
Reply #1377
I don't know why but when I was putting some timestamps on my lyrics, it started to show the timestamps as text, somebody know how to solve? I searched a lot about this problem but I didn't find any solution...
foo_uie_lyrics3
Reply #1378
syntax error or wrong format. could be a missing bracket or something
  • mzso
foo_uie_lyrics3
Reply #1379
I recently noticed I get huge CPU usage spikes which causes gui jerks/freezes and playback start hangs when I was switching between files that didn't have lyrics. For example nes files and movie soundtracks.
Files that already have lyrics are fine. I identified lyrics3 as the culprit when I looked at what threads are using the CPU with Process Explorer. I don't think it was like this earlier. maybe a recent update causes high cpu?
  • gorkha
foo_uie_lyrics3
Reply #1380
I have the same problem I think. At least the freezes occur when changing tracks.
  • The vern
foo_uie_lyrics3
Reply #1381
No problem here as far as I can tell. Can you find out which search source is causing this? It is probably the local file search, but its worth checking. If it is the local file search then adjusting your settings will help reduce the CPU - disabling searching of sub-directories is a good place to start.
HTH
  • mzso
foo_uie_lyrics3
Reply #1382
HTH
I see no such option. I only see a note about "local file search will be automatically enabled"
Found it. It's not enabled.
  • Last Edit: 20 April, 2014, 10:14:18 AM by mzso
  • mzso
foo_uie_lyrics3
Reply #1383
This probably doesn't help, but this is how it looks:
Also it's not just the playback start lyrics3 threads again max out the cpu somewhere mid playback once more.
PS:
What does the associations search do? Is it heavy?
  • mzso
foo_uie_lyrics3
Reply #1384
Okay. So moving local file search and tag search to the "available sources" area didn't help. So I guess that means it's not either of them.
After some experimenting, Spikes are rare until I have "lyrics.mirkforce.net" enabled. After that it gets bad.
  • xnor
foo_uie_lyrics3
Reply #1385
I have huge problems with this plugin.
Especially on track change the CPU usage randomly jumps to nearly 100% on one to all four cores. If all four cores are hit I even have complete audio dropouts. Skipping is sluggish, etc.
It's the same thread/address that mzso posted in the screenshot above.
"I hear it when I see it."
  • LL25255252
foo_uie_lyrics3
Reply #1386
I have many tracks I've downloaded from the web which have the UNSYNCED LYRICS tag stamped with generally the site's name encoded on the tag (for example LeakedEarly.com).
I want to make an autoplaylist which will find all those tracks so I can remove those "stamps". If I don't remove these stamps then foo_uie_lyrics3 plugin "thinks" the track has already the lyrics.
Displaying %UNSYNCED LYRICS% gives me a - "." (a point) to both those web "stamped" tracks and to tracks that the plugin has already downloaded their  lyrics.
Thanks in advance to anyone who addresses this issue.
  • Last Edit: 03 May, 2014, 03:13:58 PM by LL25255252
  • mzso
foo_uie_lyrics3
Reply #1387
Try removing lyrics.mirkforce.net. It helped for me.
  • huokok
foo_uie_lyrics3
Reply #1388
I've recently met a problem.
While I am viewing synced lyric, if I uncheck "Enable scroll (unsynced lyric)", after minimizing foobar's window, the lyric panel will stop scrolling.
I'am not sure whether this is just my particular case. I will be grateful if someone could reproduce what I did and tell me the result.
I've made a gif to show this situation
  • TheMorgod
foo_uie_lyrics3
Reply #1389
I have a question. For songs without lyrics, is it possible to mark them as lyricless in some way, to prevent it from searching for and adding lyrics to them?
  • pikashi
foo_uie_lyrics3
Reply #1390
Since it now has a lyrics editor, why not make it better?
It just need a realtime waveform seekbar and a hotkey for "synchronise selected line" button, then the lyrics editor goes to be perfect.
  • huokok
foo_uie_lyrics3
Reply #1391
This feature is by now not available.
My own solution is just type, e.g. title name into edit box to create a lyric file, in order to avoid potential mismatched online lyric download.
  • huokok
foo_uie_lyrics3
Reply #1392
You mean like aegisub?
From my own exprience, the waveform seek bar is not necessary since lrc is simple, and does not need that kind of expicity.
For most of the time, gaps between lines give enough time for me to react and give correct time stamp.
In case of extrmely short gap, I will manually edit the time stamps and it isn't very bothering actually.
foo_uie_lyrics3
Reply #1393
I'm noticing massive visual lagg in all of Foobar when Japanese Lyrics are scrolling (by visual lag I mean framerate drops from 100 to, say 1,5)
or whenever there are japanese characters in in side the lyrics window there will be lag whenever anything in the window updates visually
problem is also noticeable when no lyrics are found but the Song Title and/or Artist is written with japanese characters
however it seems to be somewhat fixable by using a different fallback font for when no lyrics are found
CPU usage also goes up a solid 10 to 35% whenever it animates
on an Intel Core i7 3770
actually looking a little closer, whenever japanese characters are shown CPU usage rises by 10%
and framerate is about 7 to 21
but when it animates/scrolls it goes up to 35%
the more characters the less preformance
  • OCULTO
foo_uie_lyrics3
Reply #1394
Please add support for RapGenius!
http://rapgenius.com
  • Hakubo
foo_uie_lyrics3
Reply #1395
I've been seeing crashes when running fb2k under Wine (sorry if this configuration is intentionally unsupported). Here's an example:
Illegal operation:
Code: 80000101h, flags: 00000001h, address: F77BC430h
Call path:
lyric_searcher::SearchProc=>lyric_searcher::SearchThread=>ReadInternetText=>do=>while
Code bytes (F77BC430h):
F77BC3F0h:  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F77BC400h:  58 B8 77 00 00 00 CD 80 90 8D B4 26 00 00 00 00
F77BC410h:  B8 AD 00 00 00 CD 80 90 90 8D B4 26 00 00 00 00
F77BC420h:  51 52 55 89 E5 0F 34 90 90 90 90 90 90 90 CD 80
F77BC430h:  5D 5A 59 C3 00 2E 73 68 73 74 72 74 61 62 00 2E
F77BC440h:  68 61 73 68 00 2E 64 79 6E 73 79 6D 00 2E 64 79
F77BC450h:  6E 73 74 72 00 2E 67 6E 75 2E 76 65 72 73 69 6F
F77BC460h:  6E 00 2E 67 6E 75 2E 76 65 72 73 69 6F 6E 5F 64
Stack (0FACDE44h):
0FACDE24h:  00000000 0FACFB40 00000000 00000000
0FACDE34h:  0000005B 00000000 0000006E F1D00010
0FACDE44h:  0FACE058 00000006 000077BB F741D827
0FACDE54h:  F759A000 0FACDEF4 F7420C53 00000006
0FACDE64h:  0FACDE74 00000000 F7466248 0FACDEB0
0FACDE74h:  00000020 00000000 00000000 00000000
0FACDE84h:  00000000 00000000 00000000 00000000
0FACDE94h:  00000000 00000000 00000000 00000000
0FACDEA4h:  00000000 00000000 00000000 00000000
0FACDEB4h:  00000000 00000000 00000000 00000000
0FACDEC4h:  00000000 00000000 00000000 00000000
0FACDED4h:  00000000 00000000 00000000 00000000
0FACDEE4h:  00000000 00000000 00000000 00000000
0FACDEF4h:  F7000000 00000000 F74184E2 F7539CB3
0FACDF04h:  7D9C7014 FFFFFFFF 00000000 555F6E65
0FACDF14h:  54552E53 FFFFFFFF F7463535 7E28FF30
0FACDF24h:  F75B2130 0F5DD6D8 00000004 F759B144
0FACDF34h:  F7417780 F74328D1 F759A000 F755301D
0FACDF44h:  F7222EC3 F1D00010 F745D70E F759A960
0FACDF54h:  F755301D 00000001 F759A000 F75505E5
Registers:
EAX: 00000000, EBX: 00007758, ECX: 000077BB, EDX: 00000006
ESI: F75C0000, EDI: F759A000, EBP: 0FACE058, ESP: 0FACDE44
Crash location:
Module: [vdso].so
Offset: 430h
Symbol: "__kernel_vsyscall" (+10h)
Loaded modules:
avrt                            loaded at F6D60000h - F6D65000h
usp10                            loaded at F2690000h - F26CF000h
windowscodecs                    loaded at F26E0000h - F278C000h
winepulse                        loaded at F6D70000h - F6D94000h
mmdevapi                        loaded at F7120000h - F713C000h
scilexer                        loaded at 053A0000h - 05442000h
d3dx9_36                        loaded at 04FE0000h - 05389000h
d3dx9_42                        loaded at F7140000h - F7156000h
opengl32                        loaded at F6DD0000h - F6EC0000h
wined3d                          loaded at F6ED0000h - F7000000h
d3d9                            loaded at F7160000h - F7193000h
frontend_direct3d9              loaded at 04F90000h - 04FE0000h
foo_unpack                      loaded at 04D40000h - 04D6F000h
foo_discogs                      loaded at 04BB0000h - 04C2F000h
foo_uie_albumlist                loaded at 04A50000h - 04A93000h
foo_ui_std                      loaded at 04830000h - 0493D000h
foo_facets                      loaded at 04560000h - 04715000h
foo_abx                          loaded at 04410000h - 04442000h
powrprof                        loaded at F71A0000h - F71AA000h
foo_autoupdate                  loaded at 03A30000h - 03A7C000h
foo_dsp_eq                      loaded at 038E0000h - 03916000h
foo_uie_vis_channel_spectrum    loaded at 03790000h - 037CD000h
foo_dsp_std                      loaded at 03640000h - 03676000h
foo_burninate                    loaded at 034F0000h - 0352E000h
avutil-fb2k-52                  loaded at 635C0000h - 6362A000h
avcodec-fb2k-55                  loaded at 643C0000h - 64593000h
foo_input_std                    loaded at 03280000h - 033D8000h
foo_playcount                    loaded at 03130000h - 0316E000h
foo_rgscan                      loaded at 02FC0000h - 0301B000h
tak_deco_lib                    loaded at 02E90000h - 02EB1000h
foo_input_tak                    loaded at 02E40000h - 02E86000h
foo_uie_playlists_dropdown      loaded at 02CF0000h - 02D2C000h
foo_jesus                        loaded at 00340000h - 0035A000h
foo_out_wasapi                  loaded at 02AA0000h - 02AC9000h
foo_converter                    loaded at 02900000h - 02985000h
mpr                              loaded at F71B0000h - F71D2000h
wininet                          loaded at F71E0000h - F724E000h
foo_uie_lyrics3                  loaded at 02840000h - 028FE000h
foo_freedb2                      loaded at 026E0000h - 0272E000h
msvcr120                        loaded at 025F0000h - 026DE000h
msvcp120                        loaded at 02570000h - 025E1000h
foo_wave_seekbar                loaded at 023C0000h - 02569000h
foo_fileops                      loaded at 02260000h - 022AB000h
setupapi                        loaded at F7260000h - F72BF000h
foo_out_ks                      loaded at 003D0000h - 003FA000h
foo_simplaylist                  loaded at 01AB0000h - 01BFC000h
foo_albumlist                    loaded at 01940000h - 0199A000h
foo_input_monkey                loaded at 017E0000h - 01828000h
foo_vis_shpeck                  loaded at 01680000h - 016C1000h
foo_masstag                      loaded at 01510000h - 01564000h
msimg32                          loaded at F75D0000h - F75E0000h
foo_simplaylist_manager          loaded at 01320000h - 013F8000h
foo_dsp_resampler                loaded at 00E10000h - 00ED5000h
imm32                            loaded at F72D0000h - F72E4000h
winex11                          loaded at 7D8B0000h - 7D93C000h
winhttp                          loaded at 7DBF0000h - 7DC24000h
oleaut32                        loaded at 7DC40000h - 7DD5A000h
gdiplus                          loaded at 7DD70000h - 7DDE4000h
ws2_32                          loaded at 7DDF0000h - 7DE1A000h
iphlpapi                        loaded at 7DE20000h - 7DE40000h
netapi32                        loaded at 7DE50000h - 7DE6D000h
secur32                          loaded at 7DE70000h - 7DEA0000h
crypt32                          loaded at 7DEB0000h - 7DF6F000h
winspool                        loaded at 7E2D0000h - 7E308000h
comdlg32                        loaded at 7DF80000h - 7E05A000h
imagehlp                        loaded at 7E3F0000h - 7E401000h
shared                          loaded at 10000000h - 1002B000h
msvcrt                          loaded at 7E320000h - 7E3B0000h
zlib1                            loaded at 62E80000h - 62E9F000h
shell32                          loaded at 7E070000h - 7E28D000h
psapi                            loaded at 7E3C0000h - 7E3C4000h
dbghelp                          loaded at 7E410000h - 7E469000h
uxtheme                          loaded at 7E470000h - 7E4A0000h
shlwapi                          loaded at 7E4B0000h - 7E51A000h
msacm32                          loaded at 7E520000h - 7E545000h
rpcrt4                          loaded at 7E550000h - 7E5C6000h
ole32                            loaded at 7E5E0000h - 7E702000h
winmm                            loaded at 7E710000h - 7E7BC000h
dsound                          loaded at 7E7C0000h - 7E805000h
version                          loaded at 7EFF0000h - 7F000000h
advapi32                        loaded at 7E810000h - 7E877000h
gdi32                            loaded at 7E880000h - 7E994000h
user32                          loaded at 7E9B0000h - 7EAEE000h
comctl32                        loaded at 7EB00000h - 7EBF5000h
kernel32                        loaded at 7B810000h - 7BA5B000h
ntdll                            loaded at 7BC10000h - 7BCDB000h
foobar2000                      loaded at 00400000h - 005CE000h
Stack dump analysis:
Address: F741D827h (libc.so.6+2E827h), symbol: "raise" (+47h)
Address: F759A000h (libc.so.6+1AB000h)
Address: F7420C53h (libc.so.6+31C53h), symbol: "abort" (+143h)
Address: F7466248h (libc.so.6+77248h), symbol: "malloc" (+58h)
Address: F74184E2h (libc.so.6+294E2h)
Address: F7539CB3h (libc.so.6+14ACB3h)
Address: F7463535h (libc.so.6+74535h)
Address: F75B2130h (libpthread.so.0+E130h), symbol: "recv" (+50h)
Address: F759B144h (libc.so.6+1AC144h)
Address: F7417780h (libc.so.6+28780h)
Address: F74328D1h (libc.so.6+438D1h), symbol: "vfprintf" (+11h)
Address: F755301Dh (libc.so.6+16401Dh)
Address: F7222EC3h (wininet+42EC3h)
Address: F745D70Eh (libc.so.6+6E70Eh), symbol: "_IO_file_sync" (+Eh)
Address: F759A960h (libc.so.6+1AB960h), symbol: "_IO_2_1_stderr_" (+0h)
Address: F75505E5h (libc.so.6+1615E5h)
Address: F74D6AF8h (libc.so.6+E7AF8h), symbol: "mmap" (+38h)
Address: F7420B17h (libc.so.6+31B17h), symbol: "abort" (+7h)
Address: F7416977h (libc.so.6+27977h)
Address: F7224953h (wininet+44953h)
Address: F7416A27h (libc.so.6+27A27h)
Address: F7554B94h (libc.so.6+165B94h)
Address: F7222EBCh (wininet+42EBCh)
Address: F74169D6h (libc.so.6+279D6h), symbol: "__assert_fail" (+6h)
Address: F7236000h (wininet+56000h)
Address: F71FA27Fh (wininet+1A27Fh)
Address: F71FA2C6h (wininet+1A2C6h)
Address: F71FA691h (wininet+1A691h)
Address: 7BC37239h (ntdll+27239h), symbol: "RtlLeaveCriticalSection" (+19h)
Address: F71FBEA3h (wininet+1BEA3h)
Address: F71FC621h (wininet+1C621h)
Address: 7BC3714Bh (ntdll+2714Bh), symbol: "RtlEnterCriticalSection" (+1Bh)
Address: F71FCA39h (wininet+1CA39h)
Address: F7208B9Bh (wininet+28B9Bh)
Address: F720F841h (wininet+2F841h), symbol: "InternetReadFile" (+61h)
Address: 10002836h (shared+2836h)
Address: 028C290Ch (foo_uie_lyrics3+8290Ch)
Address: F720F7EBh (wininet+2F7EBh), symbol: "InternetReadFile" (+Bh)
Address: 10002884h (shared+2884h)
Address: 0284C3DEh (foo_uie_lyrics3+C3DEh)
Address: 028C1AF2h (foo_uie_lyrics3+81AF2h)
Address: 028C2A4Ch (foo_uie_lyrics3+82A4Ch)
Address: 028C28A0h (foo_uie_lyrics3+828A0h)
Address: 7BCBF000h (ntdll+AF000h)
Address: 7BC4983Ch (ntdll+3983Ch)
Address: 7BC4B629h (ntdll+3B629h), symbol: "RtlAllocateHeap" (+729h)
Address: 028C1B00h (foo_uie_lyrics3+81B00h)
Address: 004B0000h (foobar2000+B0000h)
Address: 0288C2A2h (foo_uie_lyrics3+4C2A2h)
Address: 02842A7Ah (foo_uie_lyrics3+2A7Ah)
Address: 02842BB6h (foo_uie_lyrics3+2BB6h)
Address: 02842BD8h (foo_uie_lyrics3+2BD8h)
Address: 02842A32h (foo_uie_lyrics3+2A32h)
Address: 02842762h (foo_uie_lyrics3+2762h)
Address: 028A39E0h (foo_uie_lyrics3+639E0h)
Address: 0284BD65h (foo_uie_lyrics3+BD65h)
Address: 028C3FDCh (foo_uie_lyrics3+83FDCh)
Address: 028C4140h (foo_uie_lyrics3+84140h)
Address: 02861985h (foo_uie_lyrics3+21985h)
Address: 028C4300h (foo_uie_lyrics3+84300h)
Address: 7BC48A86h (ntdll+38A86h)
Address: 00581890h (foobar2000+181890h)
Address: 7BC30000h (ntdll+20000h)
Address: 7BC4A68Bh (ntdll+3A68Bh), symbol: "RtlFreeHeap" (+1FBh)
Address: 028582F2h (foo_uie_lyrics3+182F2h)
Address: 7EA13A90h (user32+63A90h), symbol: "PostMessageW" (+0h)
Address: 7B8779D0h (kernel32+679D0h), symbol: "SetLastError" (+0h)
Address: 00462F04h (foobar2000+62F04h)
Address: 0288BF7Eh (foo_uie_lyrics3+4BF7Eh)
Address: 02855003h (foo_uie_lyrics3+15003h)
Address: 028550A9h (foo_uie_lyrics3+150A9h)
Address: 028A7621h (foo_uie_lyrics3+67621h)
Address: 02856C03h (foo_uie_lyrics3+16C03h)
Address: 028E34A0h (foo_uie_lyrics3+A34A0h)
Address: 7DAA9FAFh (libexpat.so.1+11FAFh)
Address: 028A569Bh (foo_uie_lyrics3+6569Bh)
Address: 028569DFh (foo_uie_lyrics3+169DFh)
Address: 028A560Eh (foo_uie_lyrics3+6560Eh)
Address: 0288C678h (foo_uie_lyrics3+4C678h)
Address: 028924E0h (foo_uie_lyrics3+524E0h)
Address: 0288C7A0h (foo_uie_lyrics3+4C7A0h)
Address: 7BC799B0h (ntdll+699B0h), symbol: "call_thread_func_wrapper" (+Ch)
Address: 7BC7C93Dh (ntdll+6C93Dh), symbol: "call_thread_func" (+7Dh)
Address: 0288C724h (foo_uie_lyrics3+4C724h)
Address: 7BC90DC0h (ntdll+80DC0h)
Address: 7B83B730h (kernel32+2B730h), symbol: "UnhandledExceptionFilter" (+0h)
Address: 7BCC7BE0h (ntdll+B7BE0h)
Address: F75232C9h (libc.so.6+1342C9h)
Address: F751C5A5h (libc.so.6+12D5A5h)
Address: 7BC4E26Fh (ntdll+3E26Fh), symbol: "call_dll_entry_point" (+15Fh)
Address: 7BC9A78Ch (ntdll+8A78Ch)
Address: 7BC50F63h (ntdll+40F63h)
Address: 7BCDACDCh (ntdll+CACDCh)
Address: 7BC7C8C9h (ntdll+6C8C9h), symbol: "call_thread_func" (+9h)
Address: 7BC7998Eh (ntdll+6998Eh), symbol: "RtlRaiseException" (+22h)
Address: 7BC82DCEh (ntdll+72DCEh)
Environment:
App: foobar2000 v1.3.3 beta 2
UI: Default User Interface 0.9.5
Components:
Core (2014-07-05 11:52:46 UTC)
   foobar2000 core 1.3.3 beta 2
foo_abx.dll (2009-06-07 12:25:26 UTC)
   ABX Comparator 1.3.4
foo_albumlist.dll (2014-07-05 11:46:48 UTC)
   Album List 4.5
foo_autoupdate.dll (2010-04-19 21:21:14 UTC)
   Automatic Updater 1
foo_burninate.dll (2011-03-02 20:24:09 UTC)
   Audio CD Writer 3.0.3
foo_converter.dll (2014-07-05 12:40:02 UTC)
   Converter 1.5
foo_discogs.dll (2014-07-12 20:10:29 UTC)
   Discogs Tagger 1.32
foo_dsp_eq.dll (2014-07-05 11:46:52 UTC)
   Equalizer 1.0
foo_dsp_resampler.dll (2011-11-03 14:05:14 UTC)
   SoX Resampler 0.7.6
foo_dsp_std.dll (2014-07-05 11:46:46 UTC)
   Standard DSP Array 1.3
foo_facets.dll (2011-08-18 16:06:16 UTC)
   Facets 1.0
foo_fileops.dll (2014-07-05 11:45:44 UTC)
   File Operations 2.2.1
foo_freedb2.dll (2014-07-05 11:45:46 UTC)
   Online Tagger 0.7
foo_input_monkey.dll (2013-07-20 03:19:45 UTC)
   Monkey's Audio Decoder 2.1.7
foo_input_std.dll (2014-07-05 11:52:46 UTC)
   Standard Input Array 1.0
foo_input_tak.dll (2013-07-20 03:20:08 UTC)
   TAK Decoder 0.4.7
foo_jesus.dll (2010-09-22 22:34:06 UTC)
   Autosave & Autobackup 10
foo_masstag.dll (2009-09-18 07:01:36 UTC)
   Masstagger 1.8.4
foo_out_ks.dll (2006-08-04 18:54:58 UTC)
   Kernel Streaming Output 1.2.2
foo_out_wasapi.dll (2013-07-20 03:20:21 UTC)
   WASAPI output support 3.2.3
foo_playcount.dll (2011-07-13 07:47:18 UTC)
   Playback Statistics 3.0.2
foo_rgscan.dll (2014-07-05 11:46:30 UTC)
   ReplayGain Scanner 2.2.1
foo_simplaylist.dll (2011-08-18 16:01:36 UTC)
   SimPlaylist 1.0
foo_simplaylist_manager.dll (2011-08-18 17:03:02 UTC)
   SimPlaylist Manager 1.0
foo_ui_std.dll (2014-07-05 11:52:46 UTC)
foo_uie_albumlist.dll (2009-06-13 22:49:19 UTC)
   Album list panel 0.3.5
foo_uie_lyrics3.dll (2014-02-06 19:03:22 UTC)
   Lyric Show Panel 3 0.4.4
foo_uie_playlists_dropdown.dll (2009-09-23 21:44:46 UTC)
   Playlists Dropdown 0.7.6
foo_uie_vis_channel_spectrum.dll (2008-05-17 23:02:12 UTC)
   Channel Spectrum panel 0.17.2
foo_unpack.dll (2014-07-05 11:46:04 UTC)
   ZIP/GZIP/RAR Reader 1.6
foo_vis_shpeck.dll (2009-09-28 09:32:16 UTC)
   Shpeck - Winamp vis plugins wrapper 0.3.7
foo_wave_seekbar.dll (2014-07-12 05:12:23 UTC)
   Waveform seekbar 0.2.45
Recent events:
Loading DLL: D:\foobar2000\user-components\foo_playcount\foo_playcount.dll
Loading DLL: D:\foobar2000\components\foo_input_std.dll
Loading DLL: D:\foobar2000\user-components\foo_burninate\foo_burninate.dll
Loading DLL: D:\foobar2000\components\foo_dsp_std.dll
Loading DLL: D:\foobar2000\user-components\foo_uie_vis_channel_spectrum\foo_uie_vis_channel_spectrum.dll
Loading DLL: D:\foobar2000\components\foo_dsp_eq.dll
Loading DLL: D:\foobar2000\user-components\foo_autoupdate\foo_autoupdate.dll
Loading DLL: D:\foobar2000\user-components\foo_abx\foo_abx.dll
Loading DLL: D:\foobar2000\user-components\foo_facets\foo_facets.dll
Loading DLL: D:\foobar2000\components\foo_ui_std.dll
Loading DLL: D:\foobar2000\user-components\foo_uie_albumlist\foo_uie_albumlist.dll
Loading DLL: D:\foobar2000\user-components\foo_discogs\foo_discogs.dll
Loading DLL: D:\foobar2000\components\foo_unpack.dll
Components loaded in: 0:00.146249
Pre config read
Configuration read in: 0:00.022841
Starting playlist loading
Could not acquire volume control interface: Unknown error code (0x80070057)
Watching: D:\Music
RegisterShellHookWindow failure
User Interface initialized in: 0:00.804040
Processing commandline
initquit::init entry
initquit::init exit
Startup time : 0:03.917041
Seekbar: taking GDI path.
Seekbar: Frontend initialized.
Opening track for playback: "D:\Music\Juan Prophet Organization\2005 - The Carrot and the Stick\22 Empty2.ogg"
Opening track for playback: "D:\Music\Juan Prophet Organization\2005 - The Carrot and the Stick\23 Tiphook Maneuver.ogg"
Autosave (T) skipped, last saved less than 30 seconds ago.
Machine specifications:
OS: wine-1.6.2, on: Linux / 3.13.0-30-generic
CPU: Intel® Core™ i7-3630QM CPU @ 2.40GHz, features: MMX SSE SSE2 SSE3 SSE4.1 SSE4.2
CPU threads: 8
Audio: Pulseaudio
Any ideas?
foo_uie_lyrics3
Reply #1396
This is a great addon but I am having one issue. I'm having text files be created to hold downloaded lyrics and I would imagine that local searches would be pretty quick, especially if I'm pointing right to them through the local search function, but they're still taking about the same time as searches where the lyrics have to be taken from a website. Does anyone know any way to fix this? Why would local searches for saved lyrics take the same amount of time as searching on the internet for them? I have local search at the top of the list and everything.
Here's my local search options: https://dl.dropboxusercontent.com/u/4870035...LyricsSetup.jpg
That code works for saving lyrics so I assume it would work for searching for them. Also what does the association search do? It lists all the lyrics I have saved so far and their locations.
foo_uie_lyrics3
Reply #1397
Will the upload fix the issues in lyrics plugin? Timestamped again is the problem (Minilyrics lyrics database)
  • Wolfbane
foo_uie_lyrics3
Reply #1398
Would it be possible to make changes to "Synchronise selected line" and instead of when you press it it ads the time for "NOW" but instead "Now -+ X"
Where is X is editable.
So if Im listening to the song, and I press the Sync button every time I hear the line started.
So in reality, the person singing sings the line, then my ear has to register the line, then I have to react to it, and press the button.
Long story short when I press the button the line has already started prob 0,5sec ago or something.
And I could write [offset:XX] added to each song, even if it would work it still would be "wrong"
Ofc I can manually go back and edit the numbers. but to do that on each song is rather waste of time when this feature could just be added.
that would save alot of people alot of time and make the timestamps more accurate instead.
  • kanuac
foo_uie_lyrics3
Reply #1399
I must be very obtuse here because I can't get the common sense to use this plugin properly.
Why doesn't it check in the search paths (no spaces or special characters) for the lyrics before trying to download them once and again?
Every time a track is played it walkthroughs the search order -avoiding local file search-.
Even when changing to save to tag.
It saves the lyrics to the tag, I check they're there, tag search is there first in order and... no way. Redownloads all like it doesn't care.
Edited: Albricias!  It was the 'search for this type of lyric' setting. The 'prefer synced' means the one you have has to be synced or else it will go through the list to check if there are synced ones to get (in case the one you have isn't) for this condition to get validated.
So, set this to no preference and it will work just perfect.
  • Last Edit: 18 August, 2014, 07:04:38 PM by kanuac
