Topic: foo_uie_lyrics3 (Read 519568 times) previous topic - next topic
foo_uie_lyrics3
Reply #1350
not sure about the lyrics saving part, but you can change artist field to [$replace(%artist%,\,,/,,*,,?,,",,<,,>,,|,,:,)] and title field to [$replace(%title%,\,,/,,*,,?,,",,<,,>,,|,,:,)] for lyrics search. I've been using this organization since day one
sure, thanks, but there must be a neater way.
but, the title doesn't have to be based on the filename, and vice versa.
i just want to load a lrc that has the name filename as the audio file, just the same way that i am saving the lyrics.
i don't want the tags to play any part in saving the lrc (they do not), or looking for the lrc (it seems it does).
-edit. i am sure the plugin supports what i do, i just don't know how to do it...
for the saving screen, a preview is shown, where the file will be saved to based on your current input.
it would be nice if that was done for loading, since i cannot see where i am making the mistake.
also, why is the associations option always active, i cannot remove it? i assume it is faster to use the association then to search for a file each time, but, surely it is not mandatory to make us use it?
(i hate to be critical, i am so happy with this plugin, it is the plugin i look at, use the most, so i really appreciate all the work you have put into this, thanks the vern)
default is to change all invalid characters for filename to nuderscore, the conditions I put is to simply remove those characters for search. it depends on what you want to do with illegal characters in song title
  • diypig
foo_uie_lyrics3
Reply #1351
sure i understand what you are doing, just i want to load the lrc files based on the audio filenames, not the metadata.
the vern sent me a message and says he thinks he has fixed the issue, so maybe it was a bug, and that it should have been working for me... or maybe i was simply using the program wrong ha, we'll see
  • aeidein
foo_uie_lyrics3
Reply #1352
If a preferred version of the lyrics is found, I'd like it autosaved to the tag, overwriting the current tag contents (e.g. unsynced lyrics are embedded in the tag, but upon playing the song, synced lyrics are found; the synced lyrics would be automatically written to the tag).
I'd also like selected versions of lyrics saved to the tag automatically - e.g. when Next Lyrics or Lyrics Search → select → Load are selected.
Thanks for this component!
  • gorkha
foo_uie_lyrics3
Reply #1353
Every time I make a change like syncing some lyrics and press OK the work is just gone and doesn't get saved even though it supposed to be saved to the tag.
Auto save is on. using version 0.4.4
I don't know what more I can do to make it save?
  • The vern
foo_uie_lyrics3
Reply #1354
@aeidein:
It already does half of what you are asking. It will save a lyric if it matches your preferred type of lyric e.g. you prefer synced lyrics and have a non-synced saved in the tag, if the search finds a synced lyric it will save it (overwriting if necessary). The same goes for the lyric search dialogue - it will only overwrite a lyric if it's a 'better' match (i.e. synced or not). If you're trying to replace a synced lyric with another synced lyric you will have to right click the panel and click save (which will always overwrite anything that's present).
@gorkha:
It's working fine here - do the changes you are making appear in the panel before you change the track?
  • Last Edit: 25 February, 2014, 04:07:48 PM by The vern
  • gorkha
foo_uie_lyrics3
Reply #1355
@aeidein:
@gorkha:
yes, the changes appears in the panel.
I think the file might have been in use by another program - but no warnings
  • aeidein
foo_uie_lyrics3
Reply #1356
@aeidein:
@gorkha:
I must have misunderstood "Note: The automatic save will not overwrite existing lyrics."  Thanks.
As for the second part, I'd love an option to save automatically when loaded (even overwriting pre-existing lyrics) - often the wrong lyrics will come up, and having to save the lyrics after another one is loaded / Next Lyrics is selected adds an extra step.  Perhaps a "Save & Close" button in the Lyrics Search dialog would help?
  • PeteSapai
foo_uie_lyrics3
Reply #1357
Hi, I love lyric show 3, i've been using it for quite some time now. I noticed that at some point, a small bug seems to have snuck in. I was using a version from 2013-03-05 or earlier (that's the date of the last of my saved lyrics) and just updated to the latest version; 0.4.4. Running Win7 x64.
The Save Method 'user defined dir' doesn't seem to work. When I use "C:\Program Files (x86)\foobar2000\lyrics\[%artist%-][%album%]\"* as custom directory and "[%tracknumber%-][%title%]" for Filename, nothing gets saved. Moving "[%artist%-][%album%]\" to the filename doesn't work here.
When I switch to 'Save to configuration folder' (which is the same folder) and use "[%artist%-][%album%]\[%tracknumber%-][%title%]" for filename, it does get saved.
So, no big deal for me (I've even been not saving lyrics for a year and didnt notice! ), since it works, but I thought I'd post it.
* Copy-pasted the dir from my explorer to rule out a typo.
  • pentax
foo_uie_lyrics3
Reply #1358
Hi, I think this is a really great plugin, and I am sure I will enjoy using it, but I was wondering if there is any way to disable the auto search/download of lyrics from the internet? I can remove all online sources in preferences, but then if I do want lyrics from the internet I need to manually re-enable them. What would be really neat is if I could leave the online sources there, and just set it to only search when I prompt it to (like through right click->search for lyric..).
Is there anyway to do this currently? If not, is there a possibility of it in the future?
Thank you for your hard work
foo_uie_lyrics3
Reply #1359
i would like to see this option too
  • gwarah
foo_uie_lyrics3
Reply #1360
Hi, I'm a begginer in lyrics show.
I suggest these new functionalities to improve it:
1) Create an criteria tab to avoid download lyrics according user options (Ex: tag=instrumental, artist, title ...).
2) In tab lyric search allow modify order of available sources list (buttons up, down)
3) Lyrics Saving: Save in txt or lrc extension
4) Lyrics edited/created by user could be optionally uploaded to some remote database
Well, that's all folks!
singing the beauty of being an eternal learner (Gonzaguinha)
  • The vern
foo_uie_lyrics3
Reply #1361
@PeteSapai:
That's because you've got a trailing slash in your file path. I've fixed it on my version, but you can just remove it in your preferences as a quick fix.
@gwarah:
1) This doesn't exist at present and is unlikely to happen very soon (due to my time constraints)
2) Have you checked the preferences page?
3) This is done automatically depending on whether the lyric is timestamped or not (although I am aware of a bug involving copy and pasted lyrics in the editor)
4) Too much effort
  • Last Edit: 05 March, 2014, 02:25:48 PM by The vern
  • huokok
foo_uie_lyrics3
Reply #1362
I hope this function could be implemented, if Vern's time permited.
Instrumental tracks and BGMs are always matched with irrelavent lyrics.
Maybe create a rule that a lyric will only be downloaded when there is an exact match (both artists and title are matched).
  • Last Edit: 05 March, 2014, 05:26:11 PM by huokok
  • Forfit
foo_uie_lyrics3
Reply #1363
Do have a option to avoid automatically search?
  • StealthX
foo_uie_lyrics3
Reply #1364
Not displaying or even finding lyrics that are on the site it suppose to be displaying from. Example: http://lyrics.wikia.com/Kevin_Matisyn:Saw_Red does not display and also is not found when I click the search button.
  • StealthX
foo_uie_lyrics3
Reply #1365
Won't let me edit it, but it appears to be showing now.
  • Mertandur
foo_uie_lyrics3
Reply #1366
Again.
The search does not show results from Timestamped 3.
foo_uie_lyrics3
Reply #1367
There are problemas again with the minilyrics timestamped search (Probably because minilyrcs was changing some things), I don't know exactly which problem is causing this issue
  • Last Edit: 16 March, 2014, 11:58:18 AM by Jorchking
  • NokTham
foo_uie_lyrics3
Reply #1368
Evening all, i've been getting this error since the last update, it doesn't happen all the time.
<?xml version="1.0" encoding="UTF-8" ?>
<result errmsg="Search ID or Code error!" errcode="32006"></result>
Any one knows what might be causing this issue? This happens with the automatically search, with manual search (ie. "Next lyrics") it doesn't.
  • Last Edit: 18 March, 2014, 06:19:14 PM by NokTham
foo_uie_lyrics3
Reply #1369
How to do "manual search"?
  • maxim7191
foo_uie_lyrics3
Reply #1370
same problem here
foo_uie_lyrics3
Reply #1371
Timestamped 3 doesn't work , why ?
  • NokTham
foo_uie_lyrics3
Reply #1372
Right-Click on the lyric screen and choose "Next Lyrics" (by automatic search, i meant the initial search that it does once you start playing the song) or you can use the "Lyric Search" function to get lyrics.
  • Last Edit: 22 March, 2014, 01:51:19 PM by NokTham
  • mire777
foo_uie_lyrics3
Reply #1373
I have same error with new version 0.4.4 :
*This also happen with previous version..
Edit:
Found what causes this, when i remove: ''Online DB: lyrics.mirkforce.net''
All is ok..
  • Last Edit: 23 March, 2014, 03:27:51 PM by mire777
  • NokTham
foo_uie_lyrics3
Reply #1374
OK, so regarding this issue, it was related to "Online DB: Timestamped 2"
  • Last Edit: 24 March, 2014, 05:13:27 PM by NokTham
