Topic: foo_dsp_spxresample (Read 11836 times) previous topic - next topic
foo_dsp_spxresample
Binary
Source code
Resampling 44100 Hz WAV (total length: 49:16.320) to 11025 Hz
PPHS (Normal): 942.989x realtime
PPHS (Ultra): 178.291x realtime
SoX (Normal): 920.140x realtime
SoX (Best): 710.291x realtime
Speex (Q0): 1037.345x realtime
Speex (Q3 - VoIP): 540.334x realtime
Speex (Q4 - Default): 444.844x realtime
Speex (Q5 - Desktop): 381.972x realtime
Speex (Q10): 74.390x realtime
was done mainly to see what libspeex's resampler is like, nothing more.
Requires SSE, though I doubt thats a problem these days....
foo_dsp_spxresample
Hi. I've got some strange clicks on a left chanel after converting this sample to 32-bit float/48 kHz with spxresample (quality 10).
🇺🇦 Glory to Ukraine!
foo_dsp_spxresample
Hmmm, sample's 404ed. Any chance of a link, so I can forward the problem to jmvalin?
foo_dsp_spxresample
Any stereo signal is enough. For example, sweep://10-22000,50 and "Convert mono to stereo" DSP before the resampler.
I'm not sure that the problem is in speexdsp lib. Several months ago I took SoX resampler plugin and replaces SoX with Speex library, and it works without problems.
foo_dsp_spxresample
k, thanks, must be a issue then with my buffering...
foo_dsp_spxresample
k, a year later, was buffering indeed. fixed in Git.
