Topic: Crash while changing Stream automatica (Read 1179 times) previous topic - next topic
  • plinni
got one problem with fb2k when opening a stream. How can I describe...I tried to open a stream but fb2k couldn't load it 'cause it only streams from time to time. Playlist order is on random so fb2k tries to open the next stream and crashes. The console shows nothing according to this.
Is there any solution for this?
Installed components: audioscrobbler, discogs tagger, keep queue, playlist attributes, soft playlists, wsh panel mod, columns ui
  • marc2003
dodgy WSH panel mod script perhaps? if not then try a clean portable install of foobar with no components and see what happens then.
  • fbuser
Is there any crashlog?
  • plinni
Ok, seems to work with wsh panel mod 1.4.4
