Topic: The Best Way to Make Backup of Audio CD? (Read 2961 times) previous topic - next topic
  • Antigen
Hi to all,
I want to do a full lossless backup of my Audio CD.
Here and into other forum I have seen that a solution is the use of EAC.
But the problem is that this software is only for Windows.
There is a full and complete Guide as for EAC for XLD?
The result of XLD for MAC is the same of EAC?
Or is a better solution to rip all with EAC on Windows?
I think that a solution is use ALAC but i know that AIFF can be better---------------> but AIFF support cover art and id tag?
P.S: the solution of iTunes + ALAC is good'
  • Last Edit: 12 July, 2011, 04:14:36 AM by Antigen
  • db1989
  • Global Moderator
There are plenty of previous threads (probably including most of yours) with information on these topics; a search would be very informative.
  • DVDdoug
Better???  Since tagging is more standardized for ALAC, I'd say it's "better"!    When it comes to audio quality, all lossless formats are equal.  When you read/decode any lossless file the bits/bytes of the PCM audio data is identical.  (That's what  lossless means...  No data is lost and no data is altered in any way.)
  • db1989
  • Global Moderator
I’m sure the community has already explained that to Antigen umpteen times.
I think we’re into diminishing returns now, so anything besides recommending a search is probably not worth the effort.
