Topic: XLD: verify with AR / detect offset feature... (Read 5196 times) previous topic - next topic
  • Jedi82
guys, i also discovered these two amazing features of XLD but so hard for me to understand them. If i understand it write, it's a way to test and correct old rip. So i pick some old rip that i made: tracks for all of them where not present in AccurateRip database but now testing them they are...
1) here is the log
List of alternate offset correction values
   (1) 658 (confidence 84)
   (2) -226 (confidence 3)
AccurateRip Summary
   Track 01 : OK (AR2, confidence 11, with different offset)
   Track 02 : OK (AR2, confidence 11, with different offset)
   [b]Track 03 : OK (AR2, confidence 11, with different offset)[/b]
   Track 04 : OK (AR2, confidence 11, with different offset)
   Track 05 : OK (AR2, confidence 11, with different offset)
   Track 06 : OK (AR2, confidence 11, with different offset)
   Track 07 : OK (AR2, confidence 11, with different offset)
   Track 08 : OK (AR2, confidence 11, with different offset)
   Track 09 : OK (AR2, confidence 11, with different offset)
   Track 10 : OK (AR2, confidence 11, with different offset)
   Track 11 : OK (AR2, confidence 11, with different offset)
   Track 12 : OK (AR2, confidence 11, with different offset)
   Track 13 : OK (AR2, confidence 11, with different offset)
   Track 14 : OK (AR2, confidence 11, with different offset)
       ->All tracks accurately ripped.
All Tracks
   Album gain            : -8.21 dB
   Peak                  : 0.996429
   CRC32 hash            : C970A6A3
   CRC32 hash (skip zero) : 5ECFE413
Track 01
   Track gain            : -9.19 dB
   Peak                  : 0.994904
   CRC32 hash            : C045E483
   CRC32 hash (skip zero) : C41438EA
   AccurateRip signature  : 16BB25A1
     [b]  ->Accurately ripped! (AR2, confidence 11)
         (matched with the different offset correction value;
           calculated using an additional offset of 658;
           the signature after correction is: C2C73A14)[/b]
in this case, what am i supposed to do with my old rip? If i select "detect offset" i receive -->
[a href=\"http://imageshack.us/photo/my-images/52/schermata20110708a04392.png/\" target=\"_blank\"]
2) here is the log
X Lossless Decoder version 20110703 (135.1)
XLD AccurateRip checking logfile
TOC of the selected file
     Track |  Start  |  Length  | Start sector | End sector
       1  | 00:00:00 | 02:32:35 |        0    |    11434
       2  | 02:32:35 | 03:14:20 |    11435    |    26004
       3  | 05:46:55 | 03:52:27 |    26005    |    43431
       4  | 09:39:07 | 03:15:35 |    43432    |    58091
       5  | 12:54:42 | 04:31:28 |    58092    |    78444
       6  | 17:25:70 | 03:52:65 |    78445    |    95909
       7  | 21:18:60 | 04:19:12 |    95910    |  115346
       8  | 25:37:72 | 03:50:30 |    115347    |  132626
       9  | 29:28:27 | 04:12:10 |    132627    |  151536
       10  | 33:40:37 | 03:47:48 |    151537    |  168609
       11  | 37:28:10 | 03:00:50 |    168610    |  182159
       12  | 40:28:60 | 03:50:74 |    182160    |  199483
       13  | 44:19:59 | 03:49:31 |    199484    |  216689
       14  | 48:09:15 | 03:11:57 |    216690    |  231071
       15  | 51:20:72 | 04:47:46 |    231072    |  252642
       16  | 56:08:43 | 02:59:38 |    252643    |  266105
AccurateRip Summary
   [b]Track 01 : OK (AR2, confidence 5)
   Track 02 : OK (AR2, confidence 6)
   Track 03 : OK (AR2, confidence 6)
   Track 04 : OK (AR2, confidence 6)
   Track 05 : OK (AR2, confidence 5)
   Track 06 : OK (AR2, confidence 5)
   Track 07 : OK (AR2, confidence 5)[/b]
   Track 08 : OK (AR2, confidence 5)
   Track 09 : OK (AR2, confidence 6)
   Track 10 : OK (AR2, confidence 5)
   Track 11 : OK (AR2, confidence 5)
   Track 12 : OK (AR2, confidence 5)
   Track 13 : OK (AR2, confidence 3)
   Track 14 : OK (AR2, confidence 3)
   Track 15 : OK (AR2, confidence 3)
   Track 16 : OK (AR2, confidence 3)
All Tracks
   Album gain            : -9.50 dB
   Peak                  : 1.000000
   CRC32 hash            : 52F73D73
   CRC32 hash (skip zero) : 11C08918
Track 01
   Track gain            : -10.28 dB
   Peak                  : 1.000000
   CRC32 hash            : 07D6540F
   CRC32 hash (skip zero) : 51E76320
   AccurateRip signature  : 50F24C1E
       ->Accurately ripped! (AR2, confidence 5)
when i ripped this disc this was the log:
 Peak level 100.0 %
     Track quality 100.0 %
     Test CRC 137613F2
     Copy CRC 137613F2
     Track not present in AccurateRip database
so, in this case otherwise, it's ok like this and i can archive it or what?
3) here is the log
       1  | 00:00:00 | 01:50:13 |        0    |    8262
       2  | 01:50:13 | 07:51:30 |      8263    |    43617
       3  | 09:41:43 | 05:10:57 |    43618    |    66924
       4  | 14:52:25 | 05:09:58 |    66925    |    90157
       5  | 20:02:08 | 05:58:02 |    90158    |  117009
       6  | 26:00:10 | 05:28:09 |    117010    |  141618
       7  | 31:28:19 | 07:01:46 |    141619    |  173239
       8  | 38:29:65 | 05:05:21 |    173240    |  196135
       9  | 43:35:11 | 12:15:66 |    196136    |  251326
   (1) 12 (confidence 25)
   (2) -18 (confidence 16)
AccurateRip Summary
   Track 01 : OK (AR2, confidence 23)
   Track 02 : OK (AR2, confidence 23)
   Track 03 : OK (AR2, confidence 23)
   Track 04 : OK (AR2, confidence 23)
   Track 05 : OK (AR2, confidence 23)
   Track 06 : OK (AR2, confidence 23)
   Track 07 : OK (AR2, confidence 23)
   Track 08 : OK (AR2, confidence 23)
   Track 09 : OK (AR2, confidence 23)
All Tracks
   Album gain            : -4.57 dB
   Peak                  : 1.000000
   CRC32 hash            : 46E4DBF2
   CRC32 hash (skip zero) : 2165271D
Track 01
   Track gain            : -5.06 dB
   Peak                  : 1.000000
   CRC32 hash            : D77E5B8F
   CRC32 hash (skip zero) : 63D82480
   AccurateRip signature  : AB1893AC
       ->Accurately ripped! (AR2, confidence 23)
Track 02
   Track gain            : -4.34 dB
   Peak                  : 1.000000
   CRC32 hash            : CB933C5D
   CRC32 hash (skip zero) : A0F8B0C9
   AccurateRip signature  : 3E7D1CB9
same here, when i was ripping the disc it's was no AR verified but now it is...it's ok like this or not?
So hard to understand this things!!!!!!!!!!
  • fracai
When you "modify and save" what XLD is actually doing is resaving the audio with samples added and removed from the beginning or end of the file.
CDs that originally indicate that the disc is not present in the AR database may be checkable later once they have been added. This occurs often when you rip a newly released album.
  • Jedi82
Ok perfect, now i red a lot about Offset and so on and i found some of my log where the offset correction was NO set so i think i MUST use the function of XLD to' correct and save but usong it i discovered that the program save a unique corrected file despite single flac file...it is normal and if no how can i rerip all the tracks correctly?
  • greynol
  • Global Moderator
What gives you reason to believe they weren't ripped correctly in the first place?
Do you have some other summary report suggesting there might be a problem? What you've provided so far strongly indicates the rip was error-free.
  • Jedi82
Ummm don't know maybe because i red the log and all thr options Are there and perfectly settings and zero error occured...but there is this offset value one Time no set, in another log wrongly set
  • greynol
  • Global Moderator
Do you have any evidence to support the idea that this may have happened in any of these specific instances?
So far it seems likely that you have a perfectly good rips and one of them may have simply originated from a pressing that wasn't present in the AR database.
  • Last Edit: 16 July, 2011, 05:46:00 AM by greynol
  • Jedi82
The log:
Used drive  : HL-DT-STRW/DVD GCC-4247N   Adapter: 1  ID: 0
Read mode              : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : [u][b]6[/b][/u]
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks  : No
Null samples used in CRC calculations      : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 320 kBit/s
Quality                        : High
Add ID3 tag                    : No
Command line compressor        : C:\Program Files\FLAC\flac.exe
Additional command line options : -V -8 -T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" %s
TOC of the extracted CD
       1  |  0:00.00 |  4:27.02 |        0    |    20026
       2  |  4:27.02 |  4:18.01 |    20027    |    39377
       3  |  8:45.03 |  3:49.71 |    39378    |    56623
       4  | 12:34.74 |  5:06.27 |    56624    |    79600
       5  | 17:41.26 |  3:58.05 |    79601    |    97455
       6  | 21:39.31 |  4:04.30 |    97456    |  115785
       7  | 25:43.61 |  5:31.28 |    115786    |  140638
       8  | 31:15.14 |  3:42.05 |    140639    |  157293
       9  | 34:57.19 |  3:47.21 |    157294    |  174339
       10  | 38:44.40 |  5:02.62 |    174340    |  197051
       11  | 43:47.27 |  4:00.45 |    197052    |  215096
       12  | 47:47.72 |  4:52.15 |    215097    |  237011
       13  | 52:40.12 |  3:24.38 |    237012    |  252349
       14  | 56:04.50 |  5:23.18 |    252350    |  276592
       15  | 61:27.68 |  3:48.71 |    276593    |  293763
       16  | 65:16.64 |  7:41.48 |    293764    |  328386
Track  1
     Filename I:\Adema - 2005 - Planets\01 - Shoot The Arrows.wav
     Pre-gap length  0:00:02.00
     Peak level 98.8 %
     Test CRC B82E2694
     Copy CRC B82E2694
     Copy OK
Track  2
     Filename I:\Adema - 2005 - Planets\02 - Barricades In Time.wav
     Pre-gap length  0:00:01.17
     Peak level 98.8 %
     Track quality 99.9 %
     Test CRC 19FF9E10
     Copy CRC 19FF9E10
     Copy OK
Track  3
     Filename I:\Adema - 2005 - Planets\03 - Tornado.wav
     Peak level 98.8 %
     Test CRC B004256B
     Copy CRC B004256B
     Copy OK
i think all good except the offset value that XLD, damn good program, evidence like this:
[a href=\"http://imageshack.us/photo/my-images/818/schermata20110716a14340.png/\" target=\"_blank\"]
i don't want to say, give reasons or don't know what else, i just red a lot of stuff about, test with my rips and ask to all of you triing to understand
  • greynol
  • Global Moderator
The log indicating the drive and offset configured was the crucial part that was missing.
Without it, the other information you provided from XLD was simply not enough to determine that the offset was configured incorrectly, no matter how good the program is.
  • Jedi82
ummm ok soooo?  What's the answer?
  • Jedi82
Greynol, what i still don't understand is:
when i have old old rip of mine done with EAC like the one here, when there wasn't the AR function (but the T&C feature set to ON), how can i check (i'm on a mac now) if i made a good rip or not? I would like to recheck all these rip so that i can not to rerip all of them!
It's enough to open the cue file of the album with XLD and make a Accurate Rip test? And at the end, if i see a log like this:
1  | 00:00:00 | 03:30:22 | 0 | 15771
2  | 03:30:22 | 03:15:53 | 15772 | 30449
3  | 06:46:00 | 04:28:45 | 30450 | 50594
4  | 11:14:45 | 03:25:40 | 50595 | 66009
5  | 14:40:10 | 04:15:20 | 66010 | 85154
6  | 18:55:30 | 03:16:10 | 85155 | 99864
7  | 22:11:40 | 04:54:67 | 99865 |  121981
8  | 27:06:32 | 03:57:30 | 121982 |  139786
9  | 31:03:62 | 03:21:60 | 139787 |  154921
  10  | 34:25:47 | 04:10:08 | 154922 |  173679
  11  | 38:35:55 | 04:33:52 | 173680 |  194206
  12  | 43:09:32 | 03:29:20 | 194207 |  209901
  13  | 46:38:52 | 09:07:38 | 209902 |  250964
(1) -10 (confidence 2)
AccurateRip Summary
Track 01 : OK (AR2, confidence 11)
Track 02 : OK (AR2, confidence 11)
Track 03 : OK (AR2, confidence 11)
Track 04 : OK (AR2, confidence 11)
Track 05 : OK (AR2, confidence 11)
Track 06 : OK (AR2, confidence 11)
Track 07 : OK (AR2, confidence 11)
Track 08 : OK (AR2, confidence 11)
Track 09 : OK (AR2, confidence 11)
Track 10 : OK (AR2, confidence 11)
Track 11 : OK (AR2, confidence 11)
Track 12 : OK (AR2, confidence 11)
Track 13 : OK (AR2, confidence 11)
All Tracks
Album gain : -9.95 dB
Peak   : 0.992096
CRC32 hash : 50AFD421
CRC32 hash (skip zero) : 7EC40FF8
Track 01
Track gain : -10.99 dB
Peak   : 0.988556
CRC32 hash : 097F9AE4
CRC32 hash (skip zero) : 963DF605
AccurateRip signature  : 0EAE378B
Track 02
Track gain : -9.33 dB
Peak   : 0.992096
CRC32 hash : E6A66B34
CRC32 hash (skip zero) : 130E8605
AccurateRip signature  : EC11CEFA
Track 03
Track gain : -10.32 dB
Peak   : 0.988556
CRC32 hash : C673233E
CRC32 hash (skip zero) : D96D5987
AccurateRip signature  : 3C744965
Track 04
Track gain : -9.73 dB
Peak   : 0.988556
CRC32 hash : 4753F3EF
CRC32 hash (skip zero) : AC71BFD7
AccurateRip signature  : A1D36A64
Track 05
Track gain : -9.92 dB
Peak   : 0.988556
CRC32 hash : 0CD155AA
CRC32 hash (skip zero) : DAFF1A82
AccurateRip signature  : C2815E57
Track 06
Track gain : -10.06 dB
Peak   : 0.988556
CRC32 hash : DA3C52E4
CRC32 hash (skip zero) : 59FFBE9B
AccurateRip signature  : 9AFFBB76
Track 07
Track gain : -8.49 dB
Peak   : 0.988556
CRC32 hash : 81B0FB39
CRC32 hash (skip zero) : 7BC20315
AccurateRip signature  : ADB295DF
Track 08
Track gain : -9.64 dB
Peak   : 0.988556
CRC32 hash : 08000086
CRC32 hash (skip zero) : F8077F3A
AccurateRip signature  : 81563CD3
Track 09
Track gain : -9.43 dB
Peak   : 0.988556
CRC32 hash : 71BA4A4D
CRC32 hash (skip zero) : D33C60EE
AccurateRip signature  : 79484A9D
Track 10
Track gain : -9.74 dB
Peak   : 0.988556
CRC32 hash : 79372438
CRC32 hash (skip zero) : 71AA58AE
AccurateRip signature  : 1E1D4C02
Track 11
Track gain : -9.90 dB
Peak   : 0.988556
CRC32 hash : 614E5283
CRC32 hash (skip zero) : 119FB02D
AccurateRip signature  : FC2B1753
Track 12
Track gain : -9.98 dB
Peak   : 0.988556
CRC32 hash : AA38A273
CRC32 hash (skip zero) : 9DA198C6
AccurateRip signature  : 1E9B99DB
Track 13
Track gain : -9.56 dB
Peak   : 0.988556
CRC32 hash : 0649587C
CRC32 hash (skip zero) : FA1FD4EA
AccurateRip signature  : 8CE5C333
End of status report
i can assume that all went good?
  • Last Edit: 04 May, 2012, 07:12:01 PM by db1989
