Topic: Recording Impulse responses? (Read 2877 times) previous topic - next topic
  • HTS
I read that when recording Impulse responses I have to pad the beginning of the file (before the click) with zeros because a lot of the programs can mess it up and start recording a few frames after the click.
Is that true?
  • saratoga
When recording the impulse response of something, you will always have silence before hand unless you've somehow synchronized the impulse and DAC down to the microsecond.
  • HTS
I was told this:
When the click happens, the first sample should be at full loudness, but most plugins mess this up so some zero padding is needed at the beginning, which is to be removed later.
Is that outdated?
No, that's not outdated.
  • HTS
Please elaborate?
What you've been told is true: start of the playback/recording is a place with least reliable streaming, prone to drop-outs or complete skipping (depending on the playback device and software).
  • Last Edit: 04 July, 2011, 11:48:29 AM by Alexey Lukin
  • HTS
So when recording the programs do it automatically?
