Topic: True FLAC vs. Fake FLAC (Read 62927 times) previous topic - next topic
  • XeR0
I know the topic title sounds absolutely absurd but hear me out. I've tested my FLAC collection by encoding them into V0 MP3. I then decoded the MP3 back to WAV and then compressed it in FLAC. My question is: unless you've ripped the files yourself, how would you know the FLAC file you have is ACTUALLY lossless instead of an MP3 converted into FLAC? I've used the TEST option in FLAC frontend and it doesn't give a result. I have used Audiotester and it does say the file failed because it's TRUNCATED.
Bottom-line: Is there a sure-fire way of knowing that a FLAC file is truly lossless and not a derivative of a lossy file?
  • Last Edit: 29 June, 2011, 02:59:44 PM by XeR0
  • greynol
  • Global Moderator
Bottom-line on a "sure-fire way": no.
  • gottogo99
It's not guaranteed, but if you look at a file in spectral view and there is a sharp cutoff at say 15kHz, there's a very good chance the file was lossy.
  • greynol
  • Global Moderator
...recorded from the radio, or simply low-pass filtered.
There is also the real possibility that the CD was sourced from such data.  There have been examples of this happening with legitimate CDs posted on this forum and elsewhere.
  • XeR0
Yeah, I noticed the same thing and that was what I was using to make sure the FLAC's weren't lossy.
Which is why I wanted to know if there was a way. In any case at least there are methods that work 90% of the time. Thanks for your replies.
  • Rotareneg
Looking at a spectrogram of the audio is a good way to tell, but you need to look for more than just a low-pass filter.
Here are three spectrograms made with SoX that show what to look for:
First, the lossless original:
Next, Lame MP3 at -V5:
And lastly, Vorbis at -Q4:
The main thing I look for is the "holes" in the audio that the lossy compressors psycoacoustic model determined to be inaudible due to auditory masking.
  • ExUser
  • Read-only
My personal favourite anecdote was buying a music CD by Orbital from Hong Kong. It was silver and pressed, but had no catalog number and was audibly MP3 sourced. I later found the MP3s that they had sourced from. The artifacts matched.
  • Last Edit: 29 June, 2011, 04:30:05 PM by Canar
  • greynol
  • Global Moderator
That's a good one.
I was referring to some of the titles on the Century Media label available on Amazon.
  • XeR0
Rotareneg: Yeah, I use Sonic Visualizer and just go over to look for the holes you specified. Just ask greynol and he'll/she'll tell you how I was misguided by looking at spectrographs as the determining factor for audio quality instead of doing a proper ABX test
That sucks. The only only to really know (to my knowledge) if a CD is authentic is to buy it from the publisher themselves.
  • greynol
  • Global Moderator
Nice non sequitur.
I guess Century Media doesn't qualify as a publisher?
  • Last Edit: 29 June, 2011, 04:46:57 PM by greynol
  • DonP
  • Members (Donating)
Don't ya just hate it when a pirate publisher, doing enough volume for pressings,  is too cheap to buy the real CD for their source material?
  • XeR0
What I meant was this: Let's say for instance I wanted to buy an album called "Tales of the Inexpressible". A trustworthy publisher would be "Twisted Records" instead of "World Music of New Age". A good amount of research would show that the composers of the album founded Twisted Records and sell their music there. Therefore, the only real way to make sure that you're getting an authentic CD, would be to buy it from Twisted Records and not from any other obscure publisher.
  • greynol
  • Global Moderator
You're operating under the assumption that "Twisted Records" is competent in providing a CD that was sourced from lossless data.
  • XeR0
Given the fact that "Twisted Records" is run by the very composers of the album in question, I can safely assume the CD's I buy from them are sourced from lossless data. As a matter of fact, the closest you can get to the source is by downloading/buying from the creators themselves. At the end of the day however, you can only do so much before it's out of your hand.
  • greynol
  • Global Moderator
I regret to say I don't find that all composers are very tech-savvy.  As such, I wouldn't be so certain that you assumption is all that safe.
  • Last Edit: 29 June, 2011, 05:48:34 PM by greynol
  • XeR0
I don't disagree at all. Like I said, you can only do so much before you reach a point where things are out of your hand. If the composer him/her-self doesn't know much about tech, there's no one else in the world that can do a better job given that the source file is with the composer and the only access to the "source" elsewhere is through the CD albums they release which is of questionable quality. Therefore, the best you can do is to buy it from the publisher/composer themselves.
To contribute to the original topic, I would like to add that Audiotester from vuplayer.com has indicated that the "fake" FLAC file failed the test. So, besides checking the spectrographs of each FLAC file, Audiotester is a much more convenient alternative.
  • ExUser
  • Read-only
Knowing a bit more about Twisted Records would be reassuring. Simon Posford, the founder of Twisted Records and the primary member of Shpongle, is known for deeply technical audio wizardry.
  • Last Edit: 29 June, 2011, 06:09:42 PM by Canar
  • XeR0
My point exactly. However, I'm sure some people haven't had the pleasure of knowing Simon Posford as well as his expertise in audio production. In which case, I didn't feel was necessary to elaborate. The bottom-line: The best you can do to make sure you've got the best is to get it from the source or the closest thing to the source.
  • greynol
  • Global Moderator
...and would apparently instill a high degree of confidence that a CD obtained from them directly would be lossless; I clearly hadn't conducted a good amount of research.
After a bit of googling, I'm sure knowing him would be pleasurable, but I'm a bit skeptical I would derive much pleasure in his expertise in audio production.
  • Last Edit: 29 June, 2011, 08:09:07 PM by greynol
  • d_headshot
Not a very good publisher imo since they've consistently brickwalled all of their releases that I've bought
  • Last Edit: 30 June, 2011, 12:06:11 AM by d_headshot
  • Goratrix
Also, when you think about it, the OP's question really doesn't make sense. The result of a FLAC compression is a lossless image of the source. In case you input a mp3-compressed audio, does that make the resulting FLAC "non-lossless" or "fake"? No, it doesn't. It makes it a perfect lossless version of the source material, regardless of what the source material is :-)))))
On another note, if we are talking about identifing "fake FLAC" in files obtained by...ehm, questionable means, then AccurateRip comes in quite handy
  • Last Edit: 30 June, 2011, 04:38:40 AM by Goratrix
  • xnor
As well as creating flac files by ripping CDs you actually bought.
  • Last Edit: 30 June, 2011, 10:17:52 AM by xnor
"I hear it when I see it."
  • greynol
  • Global Moderator
Yeah, 'cause there's no way anyone would ever submit downloads back to the AR database.
  • Goratrix
Did I say it's 100% accurate? No, I didn't. Is it helpful and useful most of the time? Yes it in fact is, as the volume of fake and poisoned entries is very small compared to the geniune entries.
  • greynol
  • Global Moderator
You get a match against a verified yet errant submission from a download and it doesn't matter how many submissions from legitimate sources are made.
  • Last Edit: 30 June, 2011, 12:35:55 PM by greynol
