Topic: Thumbnails (Read 7834 times) previous topic - next topic
Thumbnails
Hello
How to enable displaying OGG files thumbnails instead default icon if the files have album art embedded?
I'm sure it was possible but I have lost it.
Thumbnails
You would need a Windows Shell Extension which provides this. Windows would not natively provide this.
Thumbnails
Are you sure that not?
I was seing OGG thumbnails ago.
I have
[HKEY_CLASSES_ROOT\.ogg]
@="ogmfile"
"Content Type"="application/ogg"
"PerceivedType"="audio"
[HKEY_CLASSES_ROOT\ogmfile\DefaultIcon]
@="C:\\Program Files (x86)\\Haali\\MatroskaSplitter\\splitter.ax"
How do I enable MatroskaSplitter?
Thumbnails
Careful with that keyboard you are hitting
Member who just replied to you, made those extension for most audio type (as part of his project IIRC)
Thumbnails
I have dbPoweramp installed, but even doesnot display thumbnail o  .ogg files.
But can see album picture in dbPoweramp tag viewer.
Where do I turn on displaying thumbnails?
Thumbnails
dBConfig.exe -> Thumbnail and Property Handler -> on.
Thumbnails
That`s strange I already had them enabled:
Also can dbPoweram show thumbnails for Tak files? I check  they`re not on exclude list -
Thumbnails
It is unlikely that dBpoweramp would read album art from a DirectShow codec. You also need to remove .ogg from the directshow list (where the directshow codec was setup, not on that exclusion page) and install the native ogg decoder for dbpoweramp.
Thumbnails
I`m not sure what you mean, I think I don`t have ogg as directshow filter. This is my directshow.txt:
/ add your extensions on new lines, ie .rm
.mp4v
.m4v
.vob
.tta
.rmvb
.ra
.on2
.rm
.ogv
.ogm
.mts
.mpc
.mqv
.mov
.mka
.m2p
.k3g
.ifo
.hdmov
.flv
.evo
.alac
.mkv
.divx
.axv
.axa
.spx
.ac3
.tak
.dts
Would you consider adding internal tagging and thumbnailing support for TAK format? It uses ape2 tags. Thanks.
Thumbnails
It is possibly this which is taking preference over dbpoweramp, try renaming 'DefaultIcon' key (folder) to 'DefaultIconxxxx' then restart your windows.
Tak support would require us to fully support the codec (decode and potentially encode).
Thumbnails
Thnks for pointing me at that, just reconfirming dbPoweramp options made the thumbnails work again.
I think it's not impossible using tak_deco_lib.dll and SDK both available from http://www.hydrogenaudio.org/forums/index....st&p=738550
