Topic: Prefernces -> General (?) (Read 2890 times) previous topic - next topic
  • Seraid
hi,
i've downloaded a foobar skin and the description says i have to go to Preferences --> General.
But i don't have this menu item. I'm using foobar2000 1.1.7 without any modifications...
What have i to change to see "General" in the menu? I have also looked at screenshots from foobar2000.org and their was General in the menu.
  • Last Edit: 12 June, 2011, 03:42:51 AM by Seraid
  • Alexxander
There's no menu item called General nor a General section in Preferences menu.
  • tpijag
That is from version 9.6. Been many changes since. Instead of wasting time looking for a preference area TITLE, why not mention exactly which preference setting you need to change. Or use a skin that is not using an old version of foobar.
Or ask the developer of the skin directly. That is your best avenue as skins are not supported here.
  • TomBarlow
There used to be, the options that were there have been moved around. What was the option you need to change?
