Topic: foo_seek.dll (Read 68086 times) previous topic - next topic
foo_seek.dll
Seek
foo_seek.dll
Works with CUI/DUI
actual version: 1.2
Features:
  • Preview - Listen to parts of consecutive tracks
  • Loop - Repeat part of current track
  • Rewind - Monitor during seek
  • Fast Forward - Monitor during seek
Mainmenu commands:
Menu | Playback | Seek Control | Preview length (6s-20s, Default)
Menu | Playback | Seek Control | Loop length (6s-20s, Default, End point mode, Set end point, Remove end point)
Menu | Playback | Seek Control | Preview (ON/OFF)
Menu | Playback | Seek Control | Loop (ON/OFF)
Menu | Playback | Seek Control | Rewind (5s-30s) (ON/OFF)
Menu | Playback | Seek Control | Fast Forward (5s-30s) (ON/OFF)
Advanced Preferences:
Preferences | Advanced | Playback | Seek | Automatic start/stop (ON/OFF)
Preferences | Advanced | Playback | Seek | FF/RW | FF/RW playback time [ms]
Preferences | Advanced | Playback | Seek | Loop | Loop length [ms]
Preferences | Advanced | Playback | Seek | Loop | Playback position loop
Preferences | Advanced | Playback | Seek | Loop | Reset next track to playback position loop (ON/OFF)
Preferences | Advanced | Playback | Seek | Preview | Playback position preview
Preferences | Advanced | Playback | Seek | Preview | Preview length [ms]
Preferences | Advanced | Playback | Seek | Preview | Reset next track to playback position preview (ON/OFF)
Preferences | Advanced | Playback | Seek | Preview | Skip shorter tracks in preview (ON/OFF)
[attachment=7874:foo_seek_1.2.zip][attachment=7875:foo_seek_1.2_src.zip]
foo_seek.dll
Seek 0.6
ADD: Advanced Preferences option: Reset new track to playback position preview (for "Preview" only) (ON/OFF)
ADD: Advanced Preferences option: Automatic start/stop (ON/OFF)
foo_seek.dll
Seek 0.8
FIX: Loop at end of track
ADD: Preferences | Advanced | Playback | Seek | Loop | Reset next track to playback position loop (ON/OFF)
ADD: Menu | Playback | Seek Control | Preview length (6s-20s) (ON/OFF)
ADD: Menu | Playback | Seek Control | Loop length (6s-20s) (ON/OFF)
CHG: reorganisation of Advanced Preferences entries
foo_seek.dll
Seek 0.9
CHG: Preview stops now, if "stop after current" was enabled
CHG: Preview/Loop length radiobuttons
ADD: "Default" command for Preview/Loop length. "Default" takes value from Advanced Preferences "Preview/Loop length [ms]"
foo_seek.dll
Seek 1.0
ADD: New mode to set loop length manually:
commands
  • End point mode
  • Set end point
  • Remove end point
usage
  • Enable end point mode
  • Start loop
  • Seek to start position of loop in seekbar
  • wait
  • Set end point of loop (with shortcut)
--> endless loop between start and end point
download: see first post
