Topic: DTS-HD MA decoder (Read 29490 times) previous topic - next topic
  • _m²_
DTS-HD MA decoder
Is there any software decoder for it?
Preferably a free one.
  • lvqcl
  • Developer
DTS-HD MA decoder
  • _m²_
DTS-HD MA decoder
Sorry, I wasn't precise enough.
I meant something that can decode DTS-HD MA to PCM, so I can treat it with WavPack or FLAC later.
I checked Arcsoft MediaConverter and it seems it doesn't support it.
  • Last Edit: 10 May, 2011, 12:59:00 PM by _m²_
  • Kef
DTS-HD MA decoder
eac3to and arcsoft dts ma decoder does the job.
  • _m²_
DTS-HD MA decoder
Great, thanks!
ADDED:
It seems that eac3to supports only extraction of the lossy part of DTS-HD MA, right?
  • Last Edit: 10 May, 2011, 01:08:52 PM by _m²_
  • Kef
DTS-HD MA decoder
That's why you need the arcsoft decoder. Eac3to can use the arcsoft directshow filters.
  • Last Edit: 10 May, 2011, 01:12:53 PM by Kef
  • andy o
DTS-HD MA decoder
It depends on the version too. I don't think the codecs in TMT5 or TMT 3 .190 can be used externally. TMT3.190 I think downsamples, at least when used with MPC-HC. The one I'm using is from TMT3.185
  • 06_taro
DTS-HD MA decoder
After installed TMT,
Step 1. Open mpc-hc.exe in a hex editor (i recommend HxD) and replace the two occurences of the hex string "33806DE046DBCF11B4D100805F6CBBEA" with "578F49F699B3434AA6FAF694AD42B9BE" in the file and save.
Step 2. Add
[HKEY_LOCAL_MACHINE\SOFTWARE\ArcSoft\MPEG Codec\Decoder Setting\]
AudioOutputMode=17
AudioDynamicRange=0
in %windir%\win.ini
For a 7.1ch 24bit 96kHz HDMA as an example, by finishing step 1 you can only get a downsampled 5.1ch output with MPC-HC & TMT. After done step 2 the 7.1ch 24bit data will be exactly decoded. At least when I test 5.0.1.87 and link it with ffdshow raw audio filter, I can see the tray icon show the input is a 7.1ch 96000Hz uncompressed PCM.
Another alternative is to use LAV Audio Decoder version 0.26 or newer, and put dtsdecoderdll.dll from the TMT3/5 Codecs directory into LAV Audio's directory. Then LAV Audio will use the ArcSoft DTS decoder to decode DTS-HD with no limitation. And there's no need to modify mpc-hc's binary or win.ini any more.
  • Last Edit: 27 May, 2011, 06:20:36 AM by 06_taro
  • andy o
DTS-HD MA decoder
That's for playing with MPC-HC, but for extraction with eac3to the previous posts still apply.
I don't know what your "step 1" does though. "step 2" doesn't make the file not downsample, it's just for setting the output format to 7.1. If you don't do that, then you have to set it manually every time you open MPC-HC, and that was the main reason we didn't use the Arcsoft decoder for DTS-HD MA for a long time, even though it worked technically, before someone figured that out. You also need a special checkactivate.dll, but as you said nevcairiel at doom9 added the functionality to LAV audio so all that is moot now, for playing in a directshow player.
That the file is downsampled or not when using the arcsoft decoder, depends on the version.
  • 06_taro
DTS-HD MA decoder
A simple test:
eac3to v3.24
command line: eac3to  "E:\HDC\DTS HD DEMo Blu-ray x264.DTS.1080P-Re.MClub.mkv" HDMA-test.flac
MKV, 1 video track, 1 audio track, 0:00:21, 30p /1.001
1: h264/AVC, English, 1080p30 /1.001
2: DTS Master Audio, 7.1 channels, 24 bits, 96kHz
   (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48kHz)
Track 2 is used for destination file "HDMA-test.flac".
[a02] Extracting audio track number 2...
[a02] Decoding with ArcSoft DTS Decoder...
[a02] Encoding FLAC with libFlac...
[a02] Creating file "HDMA-test.flac"...
[a02] The original audio track has a constant bit depth of 24 bits.
Video track 1 contains 529 frames.
eac3to processing took 13 seconds.
Done.
Then see info of encoded flac file:
eac3to v3.24
command line: eac3to  HDMA-test.flac
FLAC, 7.1 channels, 0:00:21, 24 bits, 7127kbps, 96kHz
And -test to check the version of ArcSoft DTS Decoder I used:
eac3to v3.24
command line: eac3to  -test
eac3to (v3.24) is up to date
Nero Audio Decoder (Nero 7) works fine
ArcSoft DTS Decoder (1.1.0.8) works fine
Sonic Audio Decoder (3.24.0.0) doesn't seem to be installed
Haali Matroska Muxer (2011-03-03) is installed
Actually my TMT5 version number is 5.0.1.87.
DTS-HD MA decoder
Where do you download the version that extracts the Lossless part?
  • Last Edit: 22 November, 2011, 07:39:29 PM by RandyOsbourne
DTS-HD MA decoder
Make sure you read this thread over at Doom9
http://forum.doom9.org/showthread.php?t=125966&page=570
DTS-HD MA decoder
So the Arcsoft dtsdecoderdll.dll ver 1.1.0.0 can extract the Master Audio Lossless?
Seems when I use it with eac3to I get 768kbps for 6ch wav files, and when using the switch -core its 1152kbps 6ch wav files, does that make any sense?
Then 4608kbps when only decoding to a single wav file.
Format                          : DTS
Format/Info                      : Digital Theater Systems
Format profile                  : MA / Core
File size                        : 1.58 GiB
Duration                        : 1h 49mn
Overall bit rate                : 2 059 Kbps / 1 510 Kbps
Audio
Format                          : DTS
Duration                        : 1h 49mn
Bit rate mode                    : Variable
Bit rate                        : 2 059 Kbps / 1 510 Kbps
Channel(s)                      : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Sampling rate                    : 48.0 KHz
Bit depth                        : 16 bits
Compression mode                : Lossless / Lossy
  • Last Edit: 23 November, 2011, 02:26:39 PM by RandyOsbourne
  • ramicio
  • Banned
DTS-HD MA decoder
ASAudioHD.ax is the filter that does the actual decoding, and it DOES work.
