Topic: ReplayGain: Foobar2000 results differ from MP3Gain and MetaFLAC ones (Read 7146 times) previous topic - next topic
I ran some tests with different softwares and found that the replaygain values may significantly differ.
Here are the results I got in the following format
  OS / software : track gain, track peak, album gain, album peak
Al Di Meola - Elegant Gypsy - Flight over Rio (MP3)
WXP  / FB2k :         -3.95, 1.029111, -3.40, 1.076560
LMDE / wine + FB2k :  -3.95, 1.029111, -3.40, 1.076560
LMDE / MP3Gain :      -4.75, 1.029080, -4.20, 1.076527
LMDE / SndC + FB2k :  -3.94, 1.000000, -3.40, 1.000000
LMDE / SndC + mtfl :  -4.75, 1.000000, -4.20, 1.000000
Al Di Meola - Elegant Gypsy - Elegant Gypsy Suite (MP3)
LMDE / wine + FB2k :  -4.42, 1.076560, -3.40, 1.076560
LMDE / SndC + FB2k :  -4.42, 1.000000, -3.40, 1.000000
LMDE / SndC + mtfl :  -4.68, 1.000000, -4.20, 1.000000
LateNightTales - Cinematic Orchestra - Ritournelle (FLAC)
WXP  / FB2k :         -7.86, 0.909882, -4.88, 1.000000
LMDE / wine + FB2k :  -7.86, 0.909882, -4.88, 1.000000
LMDE / mtfl :         -6.11, 0.909882, -5.13, 1.000000
LateNightTales - Cinematic Orchestra - Auntie's Harp (FLAC)
LMDE / wine + FB2k :  -3.48, 0.991547, -4.88, 1.000000
LMDE / mtfl :         -4.47, 0.991547, -5.13, 1.000000
Legends
WXP :  Windows XP SP3
LMDE : Linux Mint Debian Edition
wine : Windows on Linux 1.0.1
FB2k : Foobar2000 1.1.6
MP3G : MP3Gain 1.5.1
mtfl : Command-line FLAC metada editor 1.2.1
SndC : Gnome SoundConverter 1.4.4
flac : Command-line FLAC encoder/decoder 1.2.1
Conclusions
  • Foobar2000 on Windows and on Linux gives the same results. So, wine doesn't alter the computation.
  • Reincoding the original MP3 file to FLAC doesn't changes the gains but do change the peak values. Why is that?
  • There is a difference between the gains computed by Foobar2000 and MP3Gain/MetaFLAC. In my test run, it can be as big as a 1.75dB difference! Why is that?
Can anybody explain those differences? What software is the more precise?
Regards,
Olivier
assuming foobar 1.1.6 or later:
http://www.foobar2000.org/changelog
ReplayGain scanner now uses libebur128 for improved accuracy.
I guess you did not read the foobar2000 change log. The Replay Gain system has changed. It uses now a different algorithm. I don't know if the new system is better or worse than the old.
A quote from the change log:
EDIT
marc2003 posted  while I was copying the quote...
IMHO, "improved accuracy" is unproven. Most of the discussion here has been about the technical implementation.
It would probably be very difficult to organize a comprehensive listening test.
The peaks that go over 0 dBFS (aka 1.0 in foobar2000) are truncated because the PCM content is not stored in a float format in FLAC files. Usually this kind of "lossy" peaks exist only here and there and have very short durations (only a few samples for each) and thus they do not have a significant effect to the measured replay gain value.
EDIT
By "lossy" peaks I mean the increased peak values that are byproducts of the lossy encoding/decoding process. They are one kind of lossy encoding artifacts, though usually inaudible even when brutally truncated because of their extremely short duration.
Makes me worry since I have been waiting for foobar2000 1.1.7 stable, since I will re-scan my entire library.
There are 100's of posts in the appropriate threads going over every nuance of this issue. What is there to worry about?
Leave your files as they were or re-scan - meh.
For the vast majority of tracks, if not your whole library, you not notice a difference. That is, you will not hear a difference. The numbers may change.
As before, there will always be Edge cases where the gain is noticeably not be where you would like it. Which files are edge cases may or may not change.
What is there to worry about? (...) - meh
Unproven "improved accuracy" is a strong statement, that's all.
Thanks for the infos.
I didn't read the release log of Foobar2000 for a long time. Mea culpa.
I ran some tests with different softwares and found that the replaygain values may significantly differ. (...)
I've had the same problems.  I think someone mentioned in the thread that you can't hear the difference.  Maybe I'm extremely picky, but I can definitely hear the difference when wearing headphones.  I need a more precise software too.  Has anyone found a better software for reincoding?
Then rescan with the updated foobar.
What are you reencoding exactly?  Could you explain what you're trying to do, would make it easier to answer your question
Sartoga,
Thanks for your response.  I rescanned with the updated foobar.  It sounds a lot better.  Maybe it was just my headphones playing tricks on me.  I tried a new pair of headphones.  Between the new headphones and rescanning with the updated foobar, I can tell a big difference.  Disregard my second question.  I don't think I will need another software now that I have this all figured out.
Thanks again Sartoga!
