Topic: foorbar 2000 v.0.8.3. cue sheet creator (Read 6301 times) previous topic - next topic
  • crox
Hi- im new here but have frequently visited and always found valuable information.
I would like to create cuesheets from flac/wav files in foorbar 2000 v.0.8.3.
i found this link http://www.hydrogenaudio.org/forums/lofive...php/t58827.html
im not sure if it is the right addon to use and how to use it. In which folder of foobar do i place the unzipped files in?
please provide me with simple steps as i am not that knowledgable!
thank you.
the player called foobar2000, not fooRbar 2000. ))
  • Erich_2
...\Foobar2000\user-components\foo_cuesheet_creator
  • crox
Erich_2
thank you for your reply.
do you mean i drop the said dll in C:\Program Files\foobar2000\components ?
I did, and im gettign this error when opening foobar:
thsi application has failed to start because shared.dl was not found.Re-installing the application may fix this problem.
  • Last Edit: 07 May, 2011, 09:16:52 AM by crox
  • lvqcl
You need older version: http://www.hydrogenaudio.org/forums/index....st&p=310279
Yes, put this  .dll to componets folder.
  • crox
i put "foo_cuesheetcreator_0.3.4" in said folder [it comes without the .dll extension... when i added the extension it gave an arror on atartupm of foobar] ....what's next?!
  • lvqcl
It's zip file. Unpack it.
  • crox
I am placing the unzipped/unpacked file [i.e. "foo_cuesheetcreator_0.3.4"]
  • Last Edit: 07 May, 2011, 10:36:51 AM by crox
  • foo_peter
Version of 2007 !!! (0.4.6)
klick
  • crox
klick
0.4.6 is the version i tried first from the link in first post.
im getting an error at startup with it.
  • tpijag
You take some random file, change it's extension and expect something to work?
Your're kidding, right?
You were pointed to Post 6 that has a link to a very old thread. In that thread is a link to a file
This post has been edited by Synthetic Soul: Jul 4 2005, 05:40
Attached File(s)
This file does indeed have a .dll file inside it.
  • lvqcl
You downloaded foo_cuesheetcreator_0.3.4.zip. If it really was without the extension, add .zip extension to it. Unpack it. Now you should have foo_cuesheetcreator.dll file. Put it to components folder.
  • crox
tpijag...the older version foo_cuesheetcreator_0.3.4 *DOES NOT HAVE AN EXTENSION*. So i tried adding the ".ddl" extension. lvqcl...I never said that to the zip file having no extension! None are working. maybe im ding somethign wrong, but i wish to know what it is at this point.
  • Last Edit: 07 May, 2011, 11:52:06 AM by crox
  • tpijag
No need to yell.
I have no idea what you are doing. Maybe you ought to step away from the computer
Go to post 5 in this thread
Click on link.
You are now in post 12 from a 2005 Thread.
Download file at the end of that message. I have just downloaded.
Please do not then tell me it has no .dll file inside.
  • lvqcl
You said that foo_cuesheetcreator_0.3.4 is a file without extension. But: foo_cuesheetcreator_0.3.4 is a name of the .zip file.
  • tpijag
crox
is there any chance you have your system set to not show extensions.?
  • crox
the link was to post #13.
I downloaded file from post #12. No, it does not have the .dll extension. It is unrecognized by Windows.
  • Last Edit: 07 May, 2011, 12:10:18 PM by crox
  • tpijag
It is post 12.
File has .dll
You appear to be clueless.
These Forums are for support of current foobar.
I will let others take you by the hand.
  • Last Edit: 07 May, 2011, 12:14:15 PM by tpijag
  • crox
crox
No, system shows extensions.
I thank you for your comments.
