I finished a script to do just that a few days ago. Are you on Linux? Here it is:
#! /usr/bin/env tclsh8.5
# mclone.tcl <in_dir> <out_dir>
# music file cloner by David Gravereaux
# Sat Apr 30 21:56:53 PDT 2011
# Generate MP3 clones of the whole music collection
# for my &^$% Samsung BD-C5500 player because it doesn't
# understand FLAC nor does it work with MediaTomb's
# transcoding feature. Its DLNA certification is a joke.
package require Tcl 8.5 ;# for {expand}
# requires LAME 3.99, too
if {$argc != 2} {
puts stderr "barfed! need FROM and TO directories as args"
exit 1
set from [file normalize [lindex $argv 0]]
set to [file normalize [lindex $argv 1]]
proc tryexec {args} {
global done
#puts "% calling: $args"
set pipe [open "|$args |& [info name] cat.tcl" r]
#puts "pid(s) [pid $pipe] started... please wait..."
fconfigure $pipe -buffering line -blocking 0
fileevent $pipe readable [list gotpipereadable $pipe]
set done 0
vwait done
#puts "% done!"
proc gotpipereadable {pipe} {
global done
set got [gets $pipe]
if {[string length $got]} {
#puts "*** $got"
### check for incompleted lines
if {[fblocked $pipe]} {
#puts -nonewline "*** [read -nonewline $pipe]"
#flush stdout
if {[eof $pipe]} {
set done 1
fconfigure $pipe -blocking 1
set status [catch {close $pipe} result]
if {$status == 0} {
# The command succeeded, and wrote nothing to stderr.
} elseif {[string equal $::errorCode NONE]} {
# The command exited with a normal status, but wrote something
# to stderr, which is included in $result.
puts "% stderr was: $result"
} else {
switch -exact -- [lindex $::errorCode 0] {
CHILDKILLED {
foreach { - pid sigName msg } $::errorCode break
# A child process, whose process ID was $pid,
# died on a signal named $sigName. A human-
# readable message appears in $msg.
puts "pid $pid died on signal $sigName: $msg"
exit 1
CHILDSTATUS {
foreach { - pid code } $::errorCode break
# exited with a non-zero exit status, $code.
puts "pid $pid exited with code: $code"
puts "stderr: $result"
exit 1
CHILDSUSP {
# has been suspended because of a signal named
# $sigName. A human-readable description of the
# signal appears in $msg
puts "pid $pid has been suspended for $sigName: $msg"
exit 1
POSIX {
foreach { - errName msg } $::errorCode break
# One of the kernel calls to launch the command
# failed. The error code is in $errName, and a
# human-readable message is in $msg.
puts "Can't start executable because of $errName: $msg"
exit 1
proc forceInt { x } {
set count [scan $x %d%s n rest]
if { $count <= 0 || ( $count == 2 && ![string is space $rest] ) } {
return -code error "not an integer: \"$x\""
return $n
# reference links:
# [url=http://www.id3.org/id3v2.3.0]http://www.id3.org/id3v2.3.0[/url]
# [url=http://xiph.org/vorbis/doc/v-comment.html]http://xiph.org/vorbis/doc/v-comment.html[/url]
# [url=http://musicbrainz.org/doc/Picard_Tag_Mapping]http://musicbrainz.org/doc/Picard_Tag_Mapping[/url]
# return id3v2.3 data
# This routine only needs to be good enough to let MBP
# do a rescan on the output later and fill the data properly
proc gen_metacmds {metafile} {
set cmd [list]
if {[catch {set f [open $metafile r]}]} {
return [list]
set metaList [split [read $f] \n]
foreach meta $metaList {
if {$meta ne ""} {
foreach {name value} [split $meta =] break
switch -- [string toupper $name] {
"ALBUM" {lappend cmd --tl $value}
"TITLE" {lappend cmd --tt $value}
"ARTIST" {lappend cmd --ta $value}
"DATE" {
if {[string length $value] == 4} {
# year only
lappend cmd --ty $value
} else {
if {![catch {set seconds [clock scan $value]}]} {
lappend cmd --ty [clock format $seconds -format "%Y"]
lappend cmd --tv TDAT=[clock format $seconds -format "%d%m"]
"ORIGINALDATE" {
lappend cmd --tv TORY=[clock format [clock scan $value] -format "%Y"]
"TRACKNUMBER" {lappend cmd --tn [set track [forceInt $value]]}
"TRACKTOTAL" {set total [forceInt $value]}
"ALBUMARTIST" {lappend cmd --tv "TPE2=$value"}
"PERFORMER" {}
"COPYRIGHT" {}
"LICENSE" {}
"ORGANIZATION" {lappend cmd --tv "TOWN=$value"}
"DESCRIPTION" {lappend cmd --tc $value}
"GENRE" {}
"LOCATION" {}
"CONTACT" {}
"ISRC" {
# see [url=http://www.ifpi.org/isrc/]http://www.ifpi.org/isrc/[/url]
lappend cmd --tv "TSRC=$value"
default {
# this *REQUIRES* lame 3.99 or better
lappend cmd --tv "TXXX=$meta"
return $cmd
proc convert {input output} {
if {[file exists $output]} {
puts "skipping [file tail $input]"
return
puts "% About to convert: $input"
tryexec flac --force --decode $input --output-name=temp.wav
tryexec metaflac --export-tags-to=temp.meta $input
#tryexec metaflac --block-number=3 --export-image-to=Cover_front.jpg $input
# we don't know what the image file format really is, but let convert
# change it to really be a jpg
#tryexec convert -resize 500x500 -quality 75 Cover_front.jpg Cover_front.jpg
set dir [file dirname $output]
if {![file exists $dir]} {
file mkdir $dir
tryexec lame -m s -V 0 -q 0 --preset insane --replaygain-accurate \
--tg 79 --add-id3v2 {*}[gen_metacmds temp.meta] \
temp.wav $output
file delete temp.wav temp.meta
proc scanAndConvert {fromD toD} {
if {[file exists [file join $fromD skip]]} {
puts "% skipping $fromD"
return
set dirs [lsort [glob -nocomplain -tails -directory $fromD -type d *]]
foreach dir $dirs {
# yes, this is recursion
scanAndConvert [file join $fromD $dir] [file join $toD $dir]
set files [lsort [glob -nocomplain -tails -directory $fromD *.flac]]
foreach f $files {
convert [file join $fromD $f] [file join $toD [file rootname $f]].mp3
scanAndConvert $from $to
You'll need this too, called cat.tcl in the same directory as mclone.tcl
# cat.tcl
fconfigure stdin -buffering none -translation binary -blocking 0
fconfigure stdout -buffering none -translation binary
proc DoIt {} {
set got [read stdin]
puts -nonewline stdout $got
flush stdout
if {[eof stdin]} {set ::done 1}
fileevent stdin readable DoIt
set done 0
vwait done
