Topic: Facets (foo_facets) (Read 796166 times) previous topic - next topic
Facets (foo_facets)
Reply #375
Prefereces > Media Library > Facets > Default sort order: %path_sort% ?
Thank you Sir, that did it
Only one little inconvenience left. I have Facets with 2 panes and every time I start foobar the second pane doesn't load. When I set the second pane to Title, then it loads everytime, but with Folder or Album it doesn't load. Sometimes it loads when I make a dosen clicks in the first pane, sometimes not. When I want to see the content of the second pane, then I have to change the columns filtering.
It even doesn't show the name of the filtering, but in the menu it's activated. Is there a fix for that?
Facets (foo_facets)
Reply #376
I noticed something similar happening to me, does it load if you resized the panel that is blank?
Facets (foo_facets)
Reply #377
Yeah, it loads when I resize the pane    I suppose I can live with that
So it's a common bug/problem?
Facets (foo_facets)
Reply #378
Hi, I was wondering if it was possible to use facets to search for artists albums. I can't wrap up my mind around the query syntax to come up with something that will filter albums and leave out single tracks with the artist name in the title...
Can anyone help ? Thanks
Facets (foo_facets)
Reply #379
Many use Album Artist = VA or Album Artist = Various Artists for compilations. Artist = individual track artist name. Filtering on VA is then simple.
Facets (foo_facets)
Reply #380
I'd still get all the tracks that are (feat. Pit Baccardi) from other artists. Is it possible to show results only if the string shows up in the directory name ?
Facets (foo_facets)
Reply #381
There should be an Album Artist option already, right click your Facets where it says Artist, goto Columns and it's under there, at least it is on mine.
Facets (foo_facets)
Reply #382
I am using Facets. After upgrading to 1.1.11, all my column panes have lost the ability to have bottom scroll bars even when the text is wider than the window. How do I get them back?
Facets (foo_facets)
Reply #383
Hi Frank,
here i tried a snippet that won't work but leaves to an empty pane. Maybe a bug?
Making it work would be a interesting feature to achieve compatibility with other players.
Facets (foo_facets)
Reply #384
Hi guys. Putting Foobar2000 on a new computer, want to restore my old setup.
It looked like this, and everything's good so far. However, I can't work out how to get my old main Facet back. It looked like my recreation in the top-right. All of the songs were listed in alphabetical order by artist, and then in alphabetical order by album, and then in sequential order by song. The songs listed duration and bit rate on the far right (year as well, but not pictured). I was able to click on the top area to choose which direction to sort artist in - A-Z or Z-A.
The issue is that I can't figure out how to get that setup back for the life of me. Anyone able to help?
Facets (foo_facets)
Reply #385
Wishlist item. Don't know if this is a facets specific.
I sort by folders, so I add 'superfolders' to the library. Like E:\1, E:\2, F:\3. Then displayed are the subfolders of these three.
Say, in F:\3 I have a F:\3\_Various_Artists , and I want to have the subfolders of this displayed too. I could of course move that from F:\3 to F:\, but I would like to just add it to the library: If F:\3 and F:\3\_Various_Artist are both monitored, then as of now, the latter makes no difference. I'd like to have the addition of a subfolder to overrule.
Facets (foo_facets)
Reply #386
Huh. Restarting and it worked that way? Puzzling. Sorry.
Facets (foo_facets)
Reply #387
Does anyone have a problem with having album cover to show up on several albums? I noticed that several of my album art doesn't show up. All are named folder.jpg. Nothing big deal but just wondering.
Facets (foo_facets)
Reply #388
Is there a way to display the total number of albums or tracks?
For example, if I have 10 albums by The Beatles, it shows "The Beatles (10)", just like in the default media library?
Facets (foo_facets)
Reply #389
i encouter the same issue, sometimes facets shows my stub picture alltough album art is present
this bugs me, but not enough to investigate further, but if i was interessed, i would check the size of the album arts that don't show up
i guess that facets chooses big over small ones, thus displaying the stub picture though album art is present
right click the column header > statistic > subitems and/or items
Facets (foo_facets)
Reply #391
Not sure if anyone can assist with this, I have an album tagged with two different artists separated by a semi-colon. Now I would like to show this album under each artist in an "album artist" pane. At the moment I instead get a separate entry for both artists, in a addition to the individual entry of each artist (see yellow highlights in screenshot below for clarification). Is there a way to get my desired layout which does not have the third, combined artists entry?
Facets (foo_facets)
Reply #393
Thanks! That seemed to have worked, although now the artist art doesn't display for the two artists in question. Is this a bug?
Facets (foo_facets)
Reply #394
That's not a bug - it's a feature! *lol*
I'm not quite sure, but I think that's because the artist picture is now not unique any more... But that's only a guess.
Facets (foo_facets)
Reply #395
Yes, I think you may be right in that respect. Although it seems silly to treat them as not being unique as isn't that the whole point of a multi-value field? I'm not sure whether this is something facets-related though or whether it's something to do with the foobar core.
Facets (foo_facets)
Reply #396
I am experiencing a crash problem similar to one posted earlier in this thread. When playing from the Library Selection Playlist, if I attempt to search or switch the selection using Facets, the entire UI freezes, when playback of the track continues, and the foobar2000 crashes completely shortly after the track ends. So basically it is unusable. This ONLY occurs during playback however.
I am using a Genre > Album Artist > Album facets combination, with SimPlaylist in the latest 1.1.12 beta 6 version of foobar2000 on Windows 7. I have about 65,000 tracks in my library
Facets (foo_facets)
Reply #397
I am too getting the same problem, earlier it was working fine with the same version of foobar( the latest stable one).
Facets (foo_facets)
Reply #398
just resolved it somehow, actually previously i was using playlistorganizer and it didn't swithiching playlist and suddenly freezes, Now after switching to simplaylist manager problem resolved.
Facets (foo_facets)
Reply #399
WOW - one of the best available plugins for Foobar - thanks a lot!
One remark: would it be possible to add an option to disable the automatic reordering of the items in a pane: when changing the width of a pane over a certain threshold then current Facets reorders the items in multiple columns (first 2, then 3...)
Nice feature but it would be even nicer if the user could decide if he wants that or not ;-)
