Topic: Graphical browser with different jpg files names (Read 3662 times) previous topic - next topic
Hi to everyone, i have a little doubt with the graphical browser, the default setting read only the filed named cover.*, of course in my library there are many other covers with different names.
How i can do to make read the other names?
//cover sources, if you add more sources please add more $draw_image functions below
$puts(cpath1,$replace(%path%,%filename_ext%,folder.*))
$puts(cpath2,$replace(%path%,%directory%\%filename_ext%,folder.*))
i tryied with:
$puts(cpath1,$replace(%path%,%filename_ext%,*))
$puts(cpath2,$replace(%path%,%directory%\%filename_ext%,*))
but of course read a rando image on the path folder
Any suggestion??
as mentioned in the comments of your code above, you need multiple $draw_image statements....
$draw_image(4,4,$sub(%gb_width%,5),$sub(%gb_height%,5),$directory_path(%path%)\cover.jpg)
$draw_image(4,4,$sub(%gb_width%,5),$sub(%gb_height%,5),$directory_path(%path%)\folder.jpg)
just remember that if there are multiple images, one will get drawn over the top of the other so any preference you have should go last in the list.
is the same thing, some cover are showed and some not
what exactly are you saying? the filenames match the pattern but aren't showing? or you haven't accounted for all the different filenames? if i was you i'd find and rename them all to something universal.
I've find the solutizion adding these lines to the default code:
$puts(cpath1,$replace(%path%,%filename_ext%,*cover*.*))
$puts(cpath2,$replace(%path%,%filename_ext%,*folder*.*))
$puts(cpath3,$replace(%path%,%filename_ext%,*front*.*))
//$puts(cpath2,$replace(%path%,%directory%\%filename_ext%,*))
//no cover source, remember to change this if needed
$puts(nocover,components\default.png)
//other image sources
$puts(glareImage,components\glareyo0.png)
$puts(playIcon,components\Play-icon256-by-nagaya.png)
//frame drawing
$if(%gb_focused%,
$set_pen(255-128-0)
$set_brush(255-128-0)
$puts(frameD,$eval(%gb_height%-6))
$round_rect(3,3,$get(frameD),$get(frameD),3,3),
$set_pen(0-0-0)
$set_brush(0-0-0)
$puts(frameD,$eval(%gb_height%-8))
$round_rect(4,4,$get(frameD),$get(frameD),3,3)
$puts(coverD,$eval(%gb_height%-12))
//add more cover sources here
$if3(
$draw_image(6,6,$get(coverD),$get(coverD),$get(cpath1),255,nokeepaspect),
$draw_image(6,6,$get(coverD),$get(coverD),$get(cpath2),255,nokeepaspect),
$draw_image(6,6,$get(coverD),$get(coverD),$get(cpath3),255,nokeepaspect),
$draw_image(6,6,$get(coverD),$get(coverD),$get(nocover),255,nokeepaspect)
$put(isNoCover,1)
//glare and isplaying images
$draw_image(6,6,$get(coverD),$get(coverD),$get(glareImage),50,nokeepaspect)
$if(%gb_isplaying%,
$draw_image(6,6,$get(coverD),$get(coverD),$get(playIcon),128)
$if($get(isNoCover),
$gp_set_font(Tahoma,9,b)
$gp_set_pen(255-0-0-0,2,,round)
$gp_set_brush(255-255-255-255)
$gp_set_string_format(center,center)
$gp_set_smoothing_mode(1)
$gp_draw_string_path(%gb_group%,14,,6,6,$get(coverD),$get(coverD))
$if(%gb_mouse_over%,
$gp_set_brush(128-255-255-255,0,0,0-255-255-255,%gb_width%,%gb_height%)
$gp_fill_rectangle(0,0,%gb_width%,%gb_height%)
