Topic: Ripping and drive offset (Read 8045 times) previous topic - next topic
I'm trying to rip a few Audio CDs that I want to make sure that they are bit perfect. I'm using a sony 7240, 7260 and a Samsung SH224. The two sony drives returned identical results from EAC, but the samsung drive has a different offset and returned different crc values for a half of the tracks. (in total on all cds, averages 1/2 tracks per cd as well). I don't know what to do now, since half of the tracks did return identical CRCs, should i just assume that the rest of the tracks are solely affected by the varying offsets?
The offset values in the Accurip database didn't help.
Also, once they are ripped, what format should they be stored in? Does win7 have any kind of file integrity record for raw wav files? If not, then should I archive them in compressed audio formats like FLAC or simply use winrar on them?
If your drives are configured correctly, correcting the different offsets, they should rip the same data with same CRC*. However, I think you may be trying to rip a "Copy Controlled" CD or maybe just a damaged or badly manufactured CD in this case. Try some other CD's to see if they behave the same way.
Also, maybe try ripping in Secure mode.
* Disclaimer: I have to state that under certain very uncommon and rare circumstances, this may not be true.
In the case drives with different offsets which cannot overread (or one can overread and the other cannot), this is not at all uncommon.  This only affects either the first and/or last tracks on a disc, however.
HTS, please provide some logs illustrating your problem.
What format should it be in?
Just do what this poster did with the second log presented (ignore the one generated by Nero):
http://www.hydrogenaudio.org/forums/index....showtopic=86761
Exact Audio Copy V1.0 beta 1 from 15. November 2010
Used drive  : TSSTcorpCDDVDW SH-S243D  Adapter: 3  ID: 1
Read mode              : Secure
Utilize accurate stream : Yes
Defeat audio cache      : No
Make use of C2 pointers : Yes
Read offset correction                      : 48
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks  : No
Null samples used in CRC calculations      : No
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Not detected, thus appended to previous track
Used output format : Internal WAV Routines
Sample format      : 44.100 Hz; 16 Bit; Stereo
TOC of the extracted CD
    Track |  Start  |  Length  | Start sector | End sector
        1  |  0:00.00 | 18:15.47 |        0    |    82171
        2  | 18:15.47 |  9:05.38 |    82172    |  123084
        3  | 27:21.10 | 11:08.37 |    123085    |  173221
        4  | 38:29.47 |  2:43.00 |    173222    |  185446
        5  | 41:12.47 |  1:54.28 |    185447    |  194024
        6  | 43:07.00 |  2:08.67 |    194025    |  203691
        7  | 45:15.67 |  2:26.45 |    203692    |  214686
        8  | 47:42.37 |  1:32.18 |    214687    |  221604
        9  | 49:14.55 |  0:59.37 |    221605    |  226066
      10  | 50:14.17 |  1:24.73 |    226067    |  232439
      11  | 51:39.15 |  2:36.07 |    232440    |  244146
      12  | 54:15.22 |  4:40.58 |    244147    |  265204
      13  | 58:56.05 |  0:38.67 |    265205    |  268121
      14  | 59:34.72 |  1:11.05 |    268122    |  273451
      15  | 60:46.02 |  0:59.15 |    273452    |  277891
      16  | 61:45.17 |  1:03.25 |    277892    |  282641
      17  | 62:48.42 |  1:16.40 |    282642    |  288381
Track  1
    Peak level 33.8 %
    Extraction speed 7.7 X
    Track quality 100.0 %
    Test CRC 5F883763
    Copy CRC 5F883763
    Copy OK
Track  2
    Peak level 19.1 %
    Extraction speed 9.4 X
    Test CRC 1BD2A231
    Copy CRC 1BD2A231
    Copy OK
Track  3
    Peak level 85.9 %
    Extraction speed 10.4 X
    Test CRC 49690297
    Copy CRC 49690297
    Copy OK
Track  4
    Peak level 65.8 %
    Extraction speed 10.5 X
    Test CRC 1E203610
    Copy CRC 1E203610
    Copy OK
Track  5
    Peak level 41.0 %
    Test CRC 382733AE
    Copy CRC 382733AE
    Copy OK
Track  6
    Peak level 40.5 %
    Extraction speed 11.0 X
    Test CRC 4248872A
    Copy CRC 4248872A
    Copy OK
Track  7
    Peak level 33.8 %
    Test CRC 1DC6009F
    Copy CRC 1DC6009F
    Copy OK
Track  8
    Peak level 62.0 %
    Extraction speed 11.1 X
    Test CRC F5B189C3
    Copy CRC F5B189C3
    Copy OK
Track  9
    Peak level 43.5 %
    Extraction speed 10.2 X
    Test CRC F1CC61DD
    Copy CRC F1CC61DD
    Copy OK
Track 10
    Peak level 43.4 %
    Extraction speed 10.6 X
    Test CRC E7F864B3
    Copy CRC E7F864B3
    Copy OK
Track 11
    Peak level 92.2 %
    Extraction speed 11.6 X
    Test CRC 3ED7AE69
    Copy CRC 3ED7AE69
    Copy OK
Track 12
    Peak level 52.5 %
    Extraction speed 12.3 X
    Test CRC A82A9FDC
    Copy CRC A82A9FDC
    Copy OK
Track 13
    Peak level 14.5 %
    Extraction speed 5.2 X
    Track quality 99.4 %
    Test CRC ECCA7311
    Copy CRC ECCA7311
    Copy OK
Track 14
    Peak level 17.4 %
    Extraction speed 7.1 X
    Track quality 99.7 %
    Test CRC ABAD8252
    Copy CRC ABAD8252
    Copy OK
Track 15
    Peak level 22.3 %
    Extraction speed 10.7 X
    Test CRC CC64A95F
    Copy CRC CC64A95F
    Copy OK
Track 16
    Peak level 17.3 %
    Extraction speed 10.8 X
    Test CRC 2FA54800
    Copy CRC 2FA54800
    Copy OK
Track 17
    Peak level 15.1 %
    Extraction speed 11.7 X
    Test CRC 1BAEC2EE
    Copy CRC 1BAEC2EE
    Copy OK
No errors occurred
Used drive  : Optiarc DVD RW AD-7240S  Adapter: 0  ID: 1
Read mode              : Secure
Combined read/write offset correction      : 0
Gap handling                                : Appended to previous track
Track  1
    Pre-gap length  0:00:02.00
    Peak level 33.8 %
    Extraction speed 21.9 X
    Test CRC 79D2EE8C
    Copy CRC 79D2EE8C
    Copy OK
Track  2
    Pre-gap length  0:00:06.35
    Peak level 19.1 %
    Extraction speed 27.3 X
    Test CRC 4339CA92
    Copy CRC 4339CA92
    Copy OK
Track  3
    Pre-gap length  0:00:03.35
    Peak level 85.9 %
    Extraction speed 30.6 X
    Test CRC 0BDED5CA
    Copy CRC 0BDED5CA
    Copy OK
Track  4
    Pre-gap length  0:00:00.50
    Peak level 65.8 %
    Extraction speed 32.1 X
    Test CRC F6552473
    Copy CRC F6552473
    Copy OK
Track  5
    Pre-gap length  0:00:02.17
    Peak level 41.0 %
    Extraction speed 29.5 X
    Test CRC 83376822
    Copy CRC 83376822
    Copy OK
Track  6
    Pre-gap length  0:00:03.65
    Peak level 40.5 %
    Extraction speed 32.0 X
    Test CRC A2BB02F4
    Copy CRC A2BB02F4
    Copy OK
Track  7
    Pre-gap length  0:00:00.40
    Peak level 33.8 %
    Extraction speed 31.3 X
    Test CRC C750098C
    Copy CRC C750098C
    Copy OK
Track  8
    Pre-gap length  0:00:03.10
    Peak level 62.0 %
    Extraction speed 33.5 X
    Test CRC 9840D67D
    Copy CRC 9840D67D
    Copy OK
Track  9
    Pre-gap length  0:00:02.25
    Peak level 43.5 %
    Extraction speed 28.3 X
    Test CRC F86BC747
    Copy CRC F86BC747
    Copy OK
Track 10
    Pre-gap length  0:00:03.70
    Peak level 43.4 %
    Extraction speed 30.3 X
    Test CRC CA0D0958
    Copy CRC CA0D0958
    Copy OK
Track 11
    Pre-gap length  0:00:02.65
    Peak level 92.2 %
    Extraction speed 33.3 X
    Test CRC 2758FF4F
    Copy CRC 2758FF4F
    Copy OK
Track 12
    Pre-gap length  0:00:02.22
    Peak level 52.5 %
    Extraction speed 35.4 X
    Test CRC CFA0A6CE
    Copy CRC CFA0A6CE
    Copy OK
Track 13
    Pre-gap length  0:00:01.73
    Peak level 14.5 %
    Test CRC 25DB8A75
    Copy CRC 25DB8A75
    Copy OK
Track 14
    Pre-gap length  0:00:01.45
    Peak level 17.4 %
    Extraction speed 30.1 X
    Test CRC 2BE0CBED
    Copy CRC 2BE0CBED
    Copy OK
Track 15
    Pre-gap length  0:00:01.62
    Peak level 22.3 %
    Extraction speed 28.0 X
    Test CRC 037B1C36
    Copy CRC 037B1C36
    Copy OK
Track 16
    Peak level 17.3 %
    Extraction speed 28.5 X
    Test CRC A336132B
    Copy CRC A336132B
    Copy OK
Track 17
    Pre-gap length  0:00:01.20
    Peak level 15.1 %
    Extraction speed 36.9 X
    Test CRC 5F06396F
    Copy CRC 5F06396F
    Copy OK
No errors occurred
Here's your problem:
...and odyssey was right as well:
If your drives are configured correctly, correcting the different offsets, they should rip the same data with same CRC.
...though I don't care so much that your drives aren't calibrated to one another.  You were misled into thinking you had tracks that were ripped the same because of the no use of null samples in CRC calculations setting.  It's a horrible option and should be removed from EAC; that the default is checked makes it even worse!
Let this thread serve as a warning to anyone who suggests omitting null samples from CRC calculations is a good thing because it allows you to compare rips with different offsets.  It doesn't work all that well, now does it?!?
What can I do about the different offsets? Your wiki has this to say about Accuraterip
Accuracy
Determining the actual read offset of a drive is difficult. The measurements Andre Wiethoff used to calibrate the AccurateRip database were challenged in late 2006, and strong evidence was presented to support a claim that the reference is actually off by 30 samples. That is, the offsets are 30 samples too low, or the correction values are 30 samples too high, however you want to look at it. Weithoff feels that it's too late to change to a different calibration now that the database is populated.
Wow, that gives the impression that Andre Wiethoff was responsible for AccurateRip which is completely wrong.
Anyway, don't worry about it, just let AccurateRip do its thing.
It just happened to one of the CDs. Only the last track got returned with different crcs. What can I do in this case?
Nothing.  Again, don't worry about it.
So are both of them considered equally perfect? So I can just arbitrarily pick the rip from one drive and archive that?
No that's true, but then I could go on with all the possibilities, and it didn't sound like it was only the first and last track.
Anyway, some great advice you gave there with the settings!
When EAC says that "there were errors", it doesn't tell you where the errors were at if you close the program. Is it possible for the errors during read/write to be consistent? In other words, on the log file they show identical CRC values, but both of them were consistently wrong.
If this is what I think you're asking, yes, it is possible to get test and copy CRCs that match but still have an error.  When you get this with two dissimilar drives it becomes less likely.  When you get a positive match from AccurateRip it is even less likely still, unless your disc has copy protection or was subject to a consistent manufacturing defect.
This is all for Audio CDs. What about file CDs (just disks with sound files on them and you drag them into your hdd)?
Just drag the files as you have been doing. Data CDs have much better error checking/correction (by necessity), so no double-checking is needed unless the CD (or drive) are badly damaged/defective; and they have no issues with offsets.
What about storing the files you have already copied? Do you have to use some archiving program (like winrar) to implement error checking and recovery capabilities? Do raw wav files sitting in folders have error checking/reporting features?
